Question about Dell (8N816) Motherboard
I have a dell inspiron 1501 and when i turn it on no lights come on nothing happens. i checked the battery and it has full life. what else can it be.
I just took my daughters Dell 1501 apart this week end for the same problem. Found a burnt component under the proccessor's cooling unit. it was shorting out the incoming power from the AC adapter.Trying to find out if this is a common problem or maybe a design flaw.
Posted on Dec 06, 2010
  • slcwhit Dec 06, 2010
    Here is a picture of the burnt component. This could be caused by condinsation from the cooling unit, don't know?
    Sorry can't seem to post pic from comments. The burnt component is under the cooling unit for the proccessor. Maybe getting condensation from cooling unit dripping on board and causing corrosion.
I have a Dell Inspiron 1501 and it will not charge. I have plugged it in multiple times and nothing is happening.
Remove the battery and then plug it in and power up. If it then powers up put the battery back.
Jan 09, 2010 | Dell Inspiron 5100 Notebook
DELL 1501 INSPIRON THAT SHUT DOWN AND WANT POWER UP
Short or broken lil jack on the mother board. Needs a professional to look at it.
Oct 11, 2009 | Dell Inspiron 1501 Notebook
Dell 1501 Error- AC Adapter is not recognized
myabe the battery is faulty have you tried replacing it?
Sep 07, 2009 | Dell Inspiron 1501 Notebook
When I turn on my dell inspiron 1501 the light next to the start button with the letter A flashes but nothing else happens. I have my life on this flippin computer - HELP!
Your data is probably ok so don't worry about the data portion.
You can try swapping / reseatting the memory and booting the computer with the battery out.
If you don't have any success then it points to a motherboard problem, most likely.
If it is indeed the motherboard, I would seriously consider a new Dell since they're only about $200-400 for decent laptops.
You can remove the hard drive and place it into a usb enclosure to remove your personal files.
Hope this info helps.
Jun 15, 2009 | Dell InspironTM 1501 Notebook
I get the message ''The model number for the primary battery cannot be determined.This will prevent any battery present from charging i've flashed the new bios recommended by dell to stop the battery...
The Battery LED is indicating a battery failure. So the next step is to replace it. The battery life is generally 300 to 500 discharge/recharge cycles. So it appears a replacement battery is due.
Apr 16, 2009 | Dell Inspiron 1501 Notebook
Dell inspiron 1501 work fine turn off last night now wont turn on
You mentioned trying a different battery, try a different AC adapter.
When plugging in the ac adapter to the wall, see if the POWER LED comes on on the adapter, then when you connect it to the computer, see if the LED stays on.
If the issue occurs with both AC adapters (No battery installed) then the motherboard has failed. If one ac adapter works but the other doesn't then the adapter is bad
Feb 01, 2009 | Dell Inspiron 1501 Notebook
MY INSPIRON 1501 WONT START!
Do you mean to say there's No power or wont boot into Windows ?
Did you check your RAM and made sure the're properly seated ?
Try tapping on F8 while rebooting to go to Safe Mode and selecting "Last Known Good Configuration"
If you would like to perform a system test consult the Dell Support site with full instruction
Jan 04, 2009 | Dell Inspiron 1501 Notebook
Replacement battery for Dell Inspiron 1501 won't charge
If your old battery was doing the same (not charging), then is is because the charger is not charging the battery. Do you have a friend with a Dell laptop? Maybe you can use a borrowed charger to test and see if it will charge the batteries. To answer your question , no Dell does not have anything built in to prevent you from using a 3rd party battery.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 28, 2008 | Dell Inspiron 1501 Notebook
Dell (8N816) Motherboard Logo
94 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
