Question about HP 1010 Plain Paper Inkjet Fax
What is TAM mode? I want my FAX to allow the answering machine to pick up when there is a telephone call. I thought TAM mode allowed this?
4 Suggested Answers
SOURCE: Hooking up a fax machine on home telephone line
Well... the problem is that you are running two machines on one line. ONE of them has to take predominance. Both machines should have settings for "number of rings to answer at". It sounds like you currently have the fax set to less than the answering machine, so the fax picks up after two rings, while your answering machine might be set to more, which it never gets to, because the fax answered the call already(It doesn't matter if you answer the phone, or the fax picks up, once the line is open, the answering machine is taken out of the equation). Even if you set the answering machine to answer first, you're then taking the fax service out of the loop. I'm not sure how you're going to juggle that, since both types of machines each need control over the line to work properly. That's why we (business machine folk) always recommend a dedicated line for fax service.
Posted on Jan 24, 2007
jimnfl
  • 17 Answers
SOURCE: external answering machine
When you have two machines that "require" control of a single phone line, this is what you run into. Either the settings allow the fax to answer every call, even regular calls, OR the answering machine. Both can not have pre-dominance at the same time. You are either going to have to have a dedicated line for the fax service, or do as you have been doing.
Posted on Jan 28, 2007
POCBM
  • 121 Answers
SOURCE: How do I keep my fax machine from picking up incoming calls ?
Try This:
http://welcome.solutions.brother.com/BSC/Public/files/dlf/doc000239/T8_UG_US_1.pdf
Hope it helps
Posted on Mar 14, 2009
1. Machine is on telephone line shared with a 3 handset cordless Uniden system so telephone may be answered around the house. The machine no longer rings when calls come in so we only here the Uniden...
These machines come with several receiving modes that can be programmed ... mostly by design but quite often ... by accident.
I would check the User Manual for Ring Patterns, Silent Reception and Fax Priority.
You can always see or print out the Option Settings of your facsimile. There it will show the exact picture of what the fax must know before answering the incoming call.
Does it have Fax Tone Detection? Is it set for automatic answering? Faxback? Polling?
Maybe a power hickup might have scrambled some of the programmed features?
Obviously nobody in the location monkeyed around with tha fax buttons, right?
By George. Of course not!
Please feel free to contact me anytime.
Feb 14, 2011 | Canon FAXB840 Plain Paper Bubblejet Fax
When having phone conversation fax goes off...how do I fix this?
On fax machine there should be a answer mode settings on them. For an example phone, fax, or tam mode. The tam mode is when the fax machine will pick up if there is incoming fax automatically if hooked up behind the answering machine. Try doing some troubleshooting, by changing the it to phone only, and see if that works. Then if that works try the tam mode.
Aug 11, 2009 | Canon MX700 Office All-In-One InkJet...
Recording a greeting
You need to be in Tam fax mode firstly.
1, {#} {0} {0} {1}:= “TAM/FAX” (default)
2,
Press {RECORD} repeatedly to display “TAM GREETING”.
3,
Press {SET}. A long beep will sound.
Speak clearly about 20 cm ( 8 inches ) away from the microphone.
The display will show the remaining
recording time.
5 When finished recording, press {STOP}.
The unit will repeat your message.
To erase and start again
Tam/fax mode again.
2 Press {ERASE} repeatedly to display “TAM GREETING”.
3 Press {SET}.
To cancel erasing, press {STOP}.
4 Press {SET}.
should be good now.
Regards
Richard.
Apr 24, 2009 | Panasonic KX-FPG376 Plain Paper Thermal...
Panafax UF332 on one line with ansering macine
No, the machine does not have that option.
Radio Shack may still sell FAX PHONE SWITCHES.
Feb 10, 2009 | Panasonic Panafax UF-550 Plain Paper Laser...
Canon MP530 receive fax issues
Receive Mode Settings Select from the following receive mode options to suit your needs. Once you've decided on which receive mode to use, follow the below instructions to set the receive mode using the operation panel. Receive Mode Setting
  1. Press the <FAX> button to enter Fax mode.
  2. Press <Menu>.
  3. Press the right or left arrow button to select [Receive mode settings], then press the <OK> button.
  4. Press the up or down arrow to select the receive mode that best suits your needs, then press <OK>.
Types of receive mode
Select the receive mode according to your needs.
Receive mode
Purpose
FAX/TEL AUTO SW When you want to receive faxes automatically as well as voice calls. FAX ONLY MODE When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only. DRPD When you have subscribed to a DRPD service with your telephone company. MANUAL MODE When you receive mainly voice calls and sometimes faxes, or want to receive faxes manually. ANS.MACHINE MODE When you want to receive voice messages on your answering machine and receive faxes automatically. FAX/TEL auto switch
FAX :
The machine does not ring but will receive the fax automatically. Voice call :
The phone attached to the machine will ring. Pick up the handset to answer the call. Note:
  • Ring start timing and Telephone ring length can be specified in FAX/TEL auto switch in the Receive mode settings.
  • If you want the telephone to ring when it receives a fax, connect a telephone to your machine and enable the Incoming ring settings in RX settings.
  • The phone attached to the machine may not ring depending on the telephone type you are using.
FAX only
FAX * :
The telephone does not ring. The machine will receive the fax automatically. Voice call :
You will not be able to answer the call. * If you want the telephone to ring, connect the telephone to your machine and enable the Incoming ring settings in RX settings menu.
DRPD
FAX :
Your telephone line will ring according to the ring pattern you have chosen and receive the fax automatically. Voice call :
Your telephone line will ring according to the ring pattern you have chosen. Pick up the handset to answer the call. Note: Specify the FAX pattern in the DRPD: Set FAX ring pat. in RX settings menu.
Manual RX
FAX :
The telephone attached to the machine will ring. Pick up the handset and if you hear a beep tone, press the <Color> or <Black> button on the machine to receive the fax. Voice call :
The telephone attached to the machine will ring. Pick up the handset to answer the call. Note: If you are far from your machine, you can use the remote receiving function to receive faxes. Pick up the handset of the telephone connected to the machine and press 25 (the remote receiving ID).
Ans. machine connect
FAX :
First the answering machine connected to your machine will respond to an incoming call, and then the machine will receive faxes automatically. Voice call :
The answering machine connected to your machine will respond to an incoming call. Note:
  • Set the answering machine to answer on the first or second ring.
  • The entire message should be no longer than 15
Nov 24, 2008 | Canon PIXMA MP530 All-In-One InkJet...
BROTHER FAX 1840-C.
Set your machine to MANUAL, this will allow you to answer every call yourself, then if it is a fax, the machine will take over. Sounds like you have it in fax/tel mode now, which allows for the fax machine to answer every call then if not a fax, double rings to you.
Sep 19, 2008 | Brother IntelliFAX 1840C Plain Paper...
# of rings before answering
Check to make sure you do not have distinctive ring option turned on.
Feb 05, 2008 | Panasonic KX-FPG376 Plain Paper Thermal...
Connecting additional telephones
The only other way around is to fit a double adapter into the phone line socket and plug fax in one and the phone in other, this way both will ring and allow you to make or receive calls on the seperate handset
Sep 07, 2007 | Office Equipment & Supplies
What does "TAD" mean when it appears on the screen?
TAD is Telephone Answering Device. TAD mode is the only mode that can be used with an external telephone answering device (unless you are using a distinctive ring number for receiving faxes). Your telephone answering device must be connected to the jack on the fax machine (labeled "EXT" for USA). When someone dials your telephone/fax number (to send a fax or to speak to you), all the telephones (including the FAX) will ring according to the number of rings you set on the TAD. The Ring Delay setting is not recognized in the TAD mode. If you do not answer the call, the TAD will answer. As your outgoing message is playing, the Fax is in the background, silently listening for fax tones. If the FAX hears fax tones, it will automatically go into the receive mode. If the FAX does not hear fax tones, it remains silent, allowing the caller to leave a message. The above information is correct for a Brother fax machine. Is your fax automatically picking up the call or do you have to push a panel button to start the receive fax process? Perhaps the fax is already "in" your fax machine's memory and only needs a manual printout. Check the fax call log.
Aug 16, 2007 | Brother IntelliFAX 2800 Laser Fax
Epson Aculaser CX11NF won't receive faxes
Change your incoming mode from "autoswitching" to "TAM" (TAM is short for telephone answering machine" Press the "Setup" button on the control panel Use down arrow twice to select "FAX SETTINGS" Press the right arrow once The FAX SETTINGS menu appears Press the down arrow twice to select RECEPTION SETTINGS Press the right arrow once Press the down arrow unit INCOMING MODE appears in display Press the right arrow once Press the down arrow until TAM appears in display Press the right arrow once. That should do it for you If I got lost somewhere, it is in your Operator's manual - look in the index for TAM Hope it helped Ed
May 22, 2007 | Epson ACULASER CX11NF All-In-One Printer
HP 1010 Plain Paper Inkjet Fax Logo
1,273 people viewed this question
Clive
Clive
