Question about LG 24 in. LDS 5811 Built-in Dishwasher
Have a LDS 5811WW dishwasher that will not power up. Do not have any panel lights or "ding" noises. Have ac volatage to the unit. Red LED light on controller board not lit. Tried new board. Still no LED light or panel lights.
  • LG Master
  • 3,247 Answers
Which control board have you replaced. There are two boards in the panel. See diagram items 251 and 252.
The dishwasher should also have a thermal sensor which trips on over heat. I am unable to find its location on your model. See this article. Was there any error code on display prior to the problem occuring.
Posted on Nov 06, 2010
My son repeatedly turnt off and on the tv button and now the t.v light just blink sometime a noise happens as if t.v is going toturn on but nothing any ideas?
From your description the horizontal output transistor is shorted, it is located next to the high voltage transformer black in color and mounted on a heat sink.
Sep 24, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
LDS 5811ww- permanent draining
Remove the front panel - In the crack where the top and front meet about 2 inches over from each edge there are clips you push in with a putty knife or flat blade screwdriver and the front releases at the top and un hooks from the bottom. Now put washer in the spin cycle. right in front at bottom is the motor and on top of the motor is a silver colored part ( the inverter) look in between the motor and the inverter on the right about 2 inches back - you should see a green light that is flashing ( it may help to darken the room) Tell me how many times it is flashing.
Jun 16, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
LG Dishwasher LDS 5811BB does not turn on when pressing the Power button.
1. confirm there is power up to the dishwasher.
2. open electrical connection box on right side, behind toe kick panel, and hold one wire nut connector at a time while giving each individual wire a firm tug. All wires should remain connected. If not, correct poor connection.
3. dissassemble door and check door switches.
4. if all previous steps check out, you should have a red LED lit on the control board inside the door. If power to board, but no LED on, replace board.
Jan 15, 2011 | LG 24 in. LDS 5811ST Stainless Steel...
My dishwasher is an LG LDS 5811WW it reports an IE reading after one minute. Any help?
check clogging of water inlet hose ( or hose twist or freezing)....check water supply
Oct 20, 2010 | LG 24 in. LDS 5811 Built-in Dishwasher
LG dishwasher(LDF 7810WW) making noise like a four wheeler.
check to see if the load noise is coming from the motor that is attached to the sump if it is replace the motor and sump together as one unit if you buy them seperatly youll end up paying almost twice as much for the single pieces take off the bottom panel to inspect where the loud noise is coming from
Apr 29, 2010 | LG 24 in. LDS 5811 Built-in Dishwasher
Motor removal
I am having a same problem. You can open dishwasher sump assembly from inside the dishwasher and check if something is blocking white impeller. I tried to open impeller and sheared screw head as I did't realized it is left handed screw. Even after cleaning impeller you still get problem, you need to check from bottom and see if something is stuck there. If all right and you are still getting error then it is time to replace motor. In my case I ordered entire sump assembly as my seals were also wornout. Sump assy cost $113 on Sears part direct.
Dec 30, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
LD Dishwasher power problem
On the LDS5811 model, I doubt very much that the door switch would cause a full failure.
If you are confident the power is live into the dishwasher, the most common failure with this symptom is a failed controller card (PCB) and will require a service call to LG.
Aug 09, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
Lds 5811ww dishwasher e1
ther is a problem with the noise insulation in the door. It damages the coating on the wires and causes them to crack that can lead to any type of problem. lg recomends replacing the inner door and the wire harness hope you have warranty!!
Feb 10, 2008 | Kenmore 24 in. 17032 Built-in Dishwasher
LG have a history of E1 error problems.
The controller board can be one cause, however, most of these are caused by a faulty circulation pump.
The impeller breaks on the shaft and does not turn, so it doesn't produce pressure. A pressure sensor activates, bringing up the 'E1" message.
The impeller and pump are a complete assembly.
Replacing it usually fixes the problem.
Oct 30, 2007 | LG 24 in. LDS 5811 Built-in Dishwasher
LG 24 in. LDS 5811 Built-in Dishwasher Logo
116 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
