Question about LG LRBC22522 Bottom Freezer Refrigerator
The refrigerator is not cold inside.
Fan stopped after two days of making strange noise and now the refrigerator is not cold. I can't find anyone who will work on it.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 210 Answers
Do you have an error code? More than likely you have a ER FF or 6,7. The problem is you have a build up of ice that is blocking your fan. The noise was the fan hitting the ice and the ice has no blocked it completely. Defrost your unit and remove the back panel on the freezer wall. Cut off a bit of the insulation as in the picture and you should be ok. The problem will not happen again if you do this.
Sgt 48
Posted on Jun 19, 2008
Why would a brand new fridge make strange noises already?
Good Afternoon Friend,
I understand that your Frigidaire refrigerator, model# FFSS2614QS, is making a strange humming noise. Your new, high-efficiency refrigerator may introduce unfamiliar sounds. These sounds normally indicate your refrigerator is operating correctly. Some surfaces on floors, walls, and kitchen cabinets may make these sounds more noticeable. This could possibly be the compressor that you are hearing. Modern, high-efficiency compressors run much faster than in the past. The compressor may have a high-pitched hum or pulsating sound. Hope this is helpful.
-Best Regards-
WP
Jul 02, 2014 | Frigidaire FFSS2614QS FFSS2614QS 26 Cu....
Freezer on bottom is cold,refrigerator on top is warm. 2 days before failure there was a vibration noise intermittently between fridge and freezer that stoppped if freezer door was shut hard
This is a little strange to hear but something caused the vibration. Closing the doors hard or soft may make big changes in sound because of pressure change. I just want to know if the compressor is purring away without overheating. Anytime there is a restriction in ventilation the evaporator fan will struggle to push the air to the freezer and enough to refrigerator side to maintain safe temperatures. On the bottom even if the fan stopped the bottom would work because it is below and cold is heavier than warm. I will look over your parts breakdown to see what vent, dampers or fans that may cause this, work with me on this and I will help you solve this. Thanks Sea Breeze
Jan 21, 2010 | GE Profile PDS20SFS Bottom Freezer...
My Jenn Air French Door Professional Refrigerator makes a strange annoying knocking sound. It seems to come and go and happens for a few seconds to close to 1 minute. It will stop soon after I open the...
You have two fans and a compressor which could be making the noise. Inside the freezer behind the back cover is the evaporator fan. It probably stops running when you open the door. Hold the door switch down to keep the fan running to see if it's making the noise.
the compressor and other fan is under the unit accessed from the back behind the cardboard cover.
Nov 30, 2009 | Jenn-Air JFC2089HE French Door...
Our LG bottom freezer refridgerator is 2 years old. It is making a whirring noise that stops when the door is opened. It can get pretty loud at times.
The whirring sound is the fan that blows cold air into the refrigerator. It is supposed to stop when the door is opened. If it is making a loud noise there may be ice built up in the fan housing. Turning the power to the refrigerator off for a 2-4 hours may allow any ice in the fan to melt. If you do not open the freezer during that time the frozen food will not defrost.If the noise continues, you may have to take the fan apart to make sure it is not frozen. It is probably located behind the back inside panel of the freezer.
Nov 02, 2009 | Refrigerators
Loud whirring noise that stops when freezer door is open.
It is most likely your circulation fan in the freezer. Normally the fan stops when you open the door. It is a normal operation. Check to make sure that the fan is not blocked by frozen items or that the fan doesn't have an ice build up. On some models the fans stops when you open the door and starts a few minutes later after you close the door.
Mar 15, 2009 | GE Profile PSW26P Stainless Steel Side by...
Loud buzzing noise from inside Jenn Air 2389G fridge
i don't know jennair specifically being from england.
however, there is often a fan inside the back panel and the noise you heard was the fan hitting ice. the reason now not heard and fridge not working may be that the ice has built up so much the fan is jammed
Jun 25, 2008 | Jenn-Air JCB2388G Side by Side...
LG LRBC22522 Bottom Freezer Refrigerator Logo
199 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
