Question about Holmes Products HQH309 Compact Heater
I have a Holmes HQH309 Tower Quartz Heater. Stopped working suddenly. Took case apart and it appears that the fan does not activate or stay activated. Fan starts to turn and periodically stays on, but shuts down at random. Any thoughts?
5 Suggested Answers
  • 79 Answers
SOURCE: holmes tower quartz
The diode-looking parts sound like thermal fuses. Typical thermal fuses resemble a 22-caliber bullet with the pointed end colored differently from the body. If they have failed, an ohm meter or continuity meter will tell you. Yes, they are a safety feature which should be kept.
Try your local appliance parts/repair store. Take the old ones in to compare. You will also need some crimp-on connectors to attach them to the wire ends.
Posted on Mar 22, 2008
  • 74 Answers
SOURCE: Heater comes on but quickly over heats.
There is no Filter On this Model. Check to make sure there is Dirt in the Flow way of the two towers. if that is not it the back up fuse in the heater is going bad.
Posted on Dec 13, 2009
  • 149 Answers
SOURCE: How do i manually reset the Holmes HCT460 Tower
reset means a malfunction has occured a bad wire etc. most are non resettable if it is resetable find out problem that has occurred before resetting.
Posted on Jan 16, 2010
  • 4736 Answers
SOURCE: The Holmes Comfort Temp ceramic heater works fine
These heaters were not designed to be serviced in the field. If it's not over a year old, it may still be in warranty. Contact Holmes through there website www.holmesproducts.com for more info.
Posted on Jan 19, 2011
Holmes u tower fan. How do I clean it?
Best way to clean most tower fans - YouTube
? 0:23
www.youtube.com/watch?v=PDnPs7AQu_M
May 9, 2014 - Uploaded by slim alee
Keywords; Lasko,Honeywell, ozari, Holmes, newair, crane, Seville, vernado, etc etc. how to open a tower fan ...
Sep 30, 2015 | Tower Dryers
Holmes HT38R stopped working can we repair it?
were you able to find a solution? i now have the same problem
Nov 06, 2013 | Holmes Products /FANS HT38R-U Tower...
Fan will not run when plugged in. Took it apart, but did not find any discolored wires, etc.
you may have a problem in the on off switch. if it is not making proper contact then the fan wont come on
Aug 19, 2011 | Holmes Products HT40RCL-U Tower Fan
My holmes heater will not turn on, but the light comes on when the thermostat kob is turned to lo.. but the fan inside isnt working.. this happened out of nowhere
Same problem, I took it apart and found that the thermostat had failed, there are "points" burnt out (like in older cars distributors) that make contact at the thermostat and there were some solder joints which had come loose as well, adding up to no contact through the "hot" side of the wiring. Basically it's not something you can repair, just go buy a new heater, they're about $30. If you decide to try to fix it, beware, it might be dangerous if you don't do everything exactly right, also beware that parts might cost more than the heater.
Oct 13, 2010 | Holmes Products HFH106 Heater
How do i manually reset the Holmes HCT460 Tower Heater? I do not have a manual.How do i get a manual for this heater?
Jan 16, 2010 | Holmes Products Holmes HCT460 Home Base...
Heating & Cooling Logo
266 people viewed this question
Top Holmes Products Heating & Cooling Experts
Paul Carew
Gil Shultz
Paul Bade
Are you a Holmes Products Heating and Cooling Expert? Answer questions, earn points and help others
