Question about Hampton Bay 52 In. White Redington III¿ Ceiling Fan w/ Remote Control & Light Kit
I have a Hampton Bay Redington III ceiling fan light. I would like to change out the light kit with a 4-60 watt bulb light kit. I don't know what is adaptable. Do I have to buy a Hampton Bay light kit? How do I know what is adaptable from Hampton Bay or other manufacturer?
  • 44 Answers
Go to home home depot or lowes . Thats were I go to match up fan parts for customers . Alot of those are universal . Hope this helps
Posted on Nov 06, 2010
I just replaced my bulbs on my ceiling fan light fixture with the compact flourescent bulbs 13 watt to replace the regular 60 watt bulbs but they are flickering now. Could there be a problem with wiring...
Your remote control I would assume includes a dimmer for the light. CFL bulbs are not compatible with dimmers. If it has a dimmer, you must use incandescent bulbs.
Feb 14, 2011 | Hampton Bay 52 In. White Redington...
Where is the remote receiver located in the Redington III fan housing. I need to reset the dip switch. Thanks
It is in the canopy where the fan mounts to the ceiling box . Very easy to do there sould be 4 small screws . Hope this helps
Nov 05, 2010 | Hampton Bay 52 In. White Redington...
Electrical wiring guide for Hampton bay ceiling fan with remote control?
mcdevito75 here, I did a fast search and have a tech. support number -- 800-330-3267 Hope this helps.
Jul 23, 2010 | Hampton Bay 52 In. White Redington...
My Hampton Bay ceiling fan runs only on high speed and the remote has stopped working even after changing the batteries. Does Hampton Bay have a life time warranty?
Yes, look up www.hamptonbay.com and get their contact number from them. It sounds like your transmitter (Remote) has failed. If it were the receiver the fan would most likely not work at all.
Jun 09, 2010 | Hampton Bay 52 In. White Redington...
Remote works for fan but not lights
I know you replaced the bulbs, right? There may be a loose connection on the receiver unit wiring to the lights. Check it out.
May 15, 2010 | Hampton Bay 52 In. White Redington...
Hampton bay ceiling fan stopped lights work
you can test the light switch by temporarily hooking up the light bulb to where the fan normally goes ....the bulb will only work on the highest speed setting but can prove if the switch is bad or not . turn power off before woking in there ... if you know someone with a volt meter then they could quickly test the switch for you .. they can also test the motor for continuity .. .. most of the time the trouble is simply bad connections inside the wire nuts ... like insulation not skinned properly or wire not in the wire nut properly ..you can remove and inspect each connection (power off of course) ... sometimes there is a seperate power line for the fan and light ... so they can be independently controlled externally ... thats not needed when the pull chains are the only off on method ...
Apr 15, 2010 | Hampton Bay 52 In. White Redington...
Changing the light in a 54shrl
Redington III. The remote receiver is integral to the light kit. There is no replacing the light kit, you can, however change out the glass, but you're stuck with what you got.
Apr 01, 2010 | Hampton Bay 52 In. White Redington...
Light kit has light bulb size that I cannot find bulbs for
Melanie, you must have gotten a bad batch of bulbs. I have installed over 100 Hampton Bay ceiling fans and I have dropped them from up the ladder and have them bounce across the floor with no damage. I think they must have allowed a substandard batch to go out.
Home Depot is where I buy my replacement bulbs. Hampton Bay make fans exclusively for HD.
You can easily change lighting bases, as the wiring is the same for all Hampton Bay. You may even appeal to Hampton Bay on the internet and they might send you the kits. But I don't think you'd have success in a store.
If you try replacing them with bulbs from another Home Depot you may find them much hardier. I wish you the best of luck, and if you need additional help please write back.
Sirwriter
May 25, 2009 | Hampton Bay 24750 Huntington III Ceiling...
Hampton bay ceiling fan (7030T) remote does not work.
This symptom is usually caused by either a bad receiver or bad transmitter. Install a new remote system (receiver & transmitter).
Apr 20, 2009 | Hampton Bay 52 In. White Redington...
Hampton Bay Remote
You must use the switch on the fan itself.
Aug 01, 2008 | Hampton Bay 52 In. White Redington...
Hampton Bay 52 In. White Redington III¿ Ceiling Fan w/ Remote Control & Light Kit Logo
369 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
