Question about Maytag Neptune MDE5500AY Electric Dryer
Dryer will not heat up! shows no codes on the display. have a hard time believing its just a lint problem !
  • Maytag Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Jan 15, 2011
Dryer shuts after one minute
If it heats then you're getting 240 to the dryer. Take off the vent hose and look for a lint build up in the hose and where it connects to the house. Restriction will cause the dryer to shut off the heat to avoid a fire.
Oct 20, 2014 | Whirlpool Dryers
Clothes not getting dry
sounds like perhaps you are losing your heating element...could be electronic, but it's most likely the actual element needs to be replaced...
Apr 25, 2008 | Whirlpool GGQ8831L Gas Dryer
Bosch Nexxt 500-series electric dryer problems - Dryer never finishes complete cycle of drying clothes. When attempting to restart, the display will show 20 (mins) even though I've pushed something di
did you clean the LINT filter? try vacuuming the lint trap area. wet or damp lint can get built up in the lint trap area. it is good to regularly clean the area as it is a Major fire hazard.
Mar 12, 2014 | Bosch Nexxt 500 Dryer
Dryer won't heat
Odds are the Heating element is out. Only repair is to replace it.
Oct 29, 2012 | Maytag Dryers
Why is my Whirlpool Cabrio dryer saying AF instead of the Mins.?
Thank you for contacting Fixya.com.
According to the manual....
"AF (low airflow condition):
The dryer will continue to run when this diagnostic code is present. Press any key to clear the code from the display and return to the estimated time remaining.
Try the following:
1. Clean lint screen.
2. Check to see if the vent run from the dryer to the wall is crushed or kinked.
3. Confirm the vent run from the dryer to the wall is free of lint and debris.
4. Confirm the exterior vent exhaust hood is free of lint and debris.
5. Confirm your vent system falls within the recommended run length and number of elbows for the type of vent you are using.
6. Select a Timed Dry heated cycle, and restart the dryer.
7. If the message persists, have your entire home venting run cleaned."
Please get back to us if you have any further query.
Have a nice day.
Dec 02, 2010 | Dryers
My Frigidaire dryer will not start. It shows a PF trouble code. What does this mean?
PF is showing you that there is a power problem. Check your dryer circuit breaker at the power panel. This can be a sing that one of the 2 breakers has tripped. Push the CB hard to OFF and then back to ON. Then try and start your dryer. If that does not work just respond here and I will help you.
Try selecting "No Heat" after resetting the CB and see if the dryer starts. If it does you could have a bad heating element that caused the breaker to trip to begin with. Sometimes when the heating element fails the broken link will contact the chassis and cause the CB to trip. Heating element failures are usually caused by poor airflow. You may want to look for any signs of lint in your dryer to include the lint filter area and all the way to the outside wall exhaust point.
Kelly
Oct 01, 2010 | Frigidaire Electric Dryer
The lent signal comes on when start the dryer
Hello, Welcome to Fixya. Based on what you've described I don't think anything is wrong with your Bosch dryer ( provided the model number is correct ). If the dryer has an l.e.d. Indicator labelled "check lint" this is simply a reminder to check it before proceeding. Believe it or not I have clients who have used their dryer for years and never noticed this indicator or "reminder" ever before...so I get it ;o) So If the unit starts and isn't displaying any error codes and otherwise working, the dryer is functioning properly, i.e. heating, not running too long, not tripping hi-limit safety etc. Let me know if this is indeed the case...that the dryer is working fine otherwise, or if you are referring to another model number. Thanks for choosing "fixya". Please take a moment and rate the answer provided here today accordingly. macmarkus :)
Jul 10, 2010 | Bosch Axxis WTL 6307 Electric Dryer
Dryer will not heat. lint filter is clean. dryer runs fine bosch dryer nexxt 500.
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Nov 08, 2009 | Bosch Nexxt 500 Dryer
Frigidaire Affinity dryer error code?
HELLO,
I HAVE A FRIGIDAIRE AFFINITY DRYER (AEQ6000CE32). WHENEVER I PUT THE CLOTHES IN IT JUST SPINS FOR 10 TO 15 MINUTES AND SHUTS OFF BEFORE THE ALLOTTED TIME. THERE IS NO HEAT IN THE DRYER. ANY SLOUTIONS?
Sep 16, 2007 | Frigidaire Affinity ATF7000ES Front Load...
Maytag Neptune MDE5500AY Electric Dryer Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
