Question about Fellowes W11C Confetti-Cut Shredder
Runs only in reverse - Fellowes W11C Confetti-Cut Shredder
I just had this problem with my shredder. I think the problem started with a bin that was full. Running the shredder in reverse resulted in shredded paper being pulled up into the slot used to feed paper into the shredder. Some of this shredded paper was blocking the little plastic tab that activates the switch when paper is inserted, so the shredder would no longer start when paper was inserted. I emptied the bin and removed the shredded paper from the feed slot, being careful not to break the plastic "sensor" while removing the paper from under it. The shredder works fine now.
Posted on Dec 30, 2010
Only runs in reverse, why?
Polar Express only runs in reverse ' O Gauge Railroading ...
ogrforum.ogaugerr.com/topic/polar-express-only-runs-in-reverse
Dec 7, 2011 - Polar Express only runs in reverse ... At this time of the year all Polar Express trains are programmed to run North only. ... This would not be so bad on the Strasburg set because half the time, the prototype runs in reverse.
both trains only go backward - Classic Toy Trains Magazine
cs.trains.com > ... > Forums > Toy train operating and collecting
... trains that i set up around Christmas. The first train, according to the box, is a k-line 0/027 gauge dual motor mp-15. For a long time it has only run backwards.
no forward only reverse - Model Train Forum - the complete model ...
www.modeltrainforum.com > Scale Specific Model Train Forum > O Scale
Oct 18, 2009 - 10 posts - ‎3 authors
There are two switches under the cab; they have no effect on forward motion. This setis 2 or 3 years old and has been run maybe 1 hour total. New Athearn HO Locomotive won't go in reverse ...
Mar 5, 2015
Lionel Rio Grande 8213 only runs in reverse - Model ...
Nov 18, 2013
More results from www.modeltrainforum.com
Jan 01, 2016 | Crafts & Hobbies
3 cyl metro runs rough in reverse
Hi Have you checked if there are spark problems?
Check the sparks and see to that they are sitting correctly.
luck to you. kolbrun
Apr 10, 2012 | 1993 Geo Metro
On a 2002 polaris 325 magnum when going in reverse motor cuts out but runs fine if push reverse override. runs fine in foward gears
That is called a REV LIMITER. Its there to make sure you dont go too fast in reverse due to it being slightly more complicated to steer. They put the override button on there in case you DO want to go faster. Its pretty much standard on all quads. Similar to how low a regualr car is geared when in reverse. I hope this helped!
Nov 13, 2010 | Polaris ATV
My 1995 dodge caravan needs warmed before going into reverse
Trans is internally worn and only sealing properly when parts are hot. I would change fluid and filter just to be sure pressure loss is not from filter but if it does not improve, start saving up for a rebuild.
Jun 16, 2009 | 1995 Dodge Caravan
Stalls when engage blades in forward, but cuts fine in reverse
Did you try to disengage the safety feature that should shut the tractor off when the blades are engaged and the tractor is placed in reverse? I believe that it is located under the shift leaver
May 14, 2009 | Mtd Garden
Can not get car into reverse
Try puttingi t in reverse with the engine off.
Usually the sign of a worn clutch
Nov 04, 2008 | 1998 Dodge Neon
please post brand and model
Jan 05, 2008 | Royal 1280MX Shredder
Fellowes W11C Confetti-Cut Shredder Logo
1,736 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
midnightmove
Level 1 Expert
quennie732
gggg
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
