Question about Pioneer Televison & Video
I replaced the convergence IC's and I cannot get the convergence to adjust now?
    President:
  • Pioneer Master
  • 1,779 Answers
You must check all the low ohm resistors around the Ic's they must be exact. they should be 2.2 ohm , 1.5 ohm...in that area depending on the make and model of which you did not include.Make sure your solder connections are all ok, them let me know.
Posted on Jun 14, 2008
My tv is a magnavox and we bought it about 3 years ago and it is now showing like a double picture the color is hazy and pinkish looking the model is 51MP392H/17
The problem of your unit is the convergence. Try to adjust it using the original remote control in the setting menu, then goto the convergence section adjust the red and blue convergence, you should move red and blue UP, DOWN and LEFT or RIGHT, if you cannot move them far enough the convergence IC is defective, replacing this IC will restore the original setting of your tv. This convergence IC is attach to a large aluminum plate it is the heat sink this IC has a marking of STK-#### followed by numbers, remember be careful when replacing this IC you may accidentally tampered or damage the PCB and cause much damage to your unit. Or you can contact a technician to do it for you and save you from stress good day and best regards. Try to check this link for the convergence http://www.google.com.ph/search?q=convergence+ic&hl=tl&sa=X&tbm=isch&prmd=ivns&bav=on.2,or.r_gc.r_pw.&biw=798&bih=472&ech=1&psi=JZdtTvDCPIe4iAe72sTABA.1315804977740.3&emsg=NCSR&noj=1&ei=MpdtTpa4OKKSiQfBpcjGBA
Sep 12, 2011 | Philips Magnavox 51MP392H Rear Projection...
Colored lines at top and bottom when tv comes on and seeing double vision in different colors at all times
If your tv is not a DLP the problem is in the convergence, try to adjust it using your original remote control go to the setting menu then to the convergence section. Adjust the red and blue convergence. you should move the red and the blue in up, down and left, right if this color does not move far enough your convergence IC is already defective. Replacing this convergence IC will solve the problem. In locating this convergence IC you should remove the back cover of your unit but be sure to unplug it before doing this. This convergence IC is attached to a large aluminum plate, it is the heat sink, and it has a marking of stk- ### followed by numbers. You can try to pull it out using a soldering iron and soldering pump but be careful you may damage the board and cause much problem to your unit. Or you can contact a technician to do it for you and save you from stress good day and best regards.
Aug 28, 2011 | RCA Televison & Video
The colors are unalligned and the picture is blurry
hello,,the deffective part of your tv probably the convergience ic,it is a 2 pcs big ic with heatsink mounted on the mainboard you can replace it with a new one..or try to adjust first the allignment of your cathodes the RGB cathodes..on your front pannel there is a convergeance manual allignment button use this button to allign the convergeance..on your remote control there is also an allignment command consult your manual for the command .after the adjustment you must save the adjustments before exit the convergeance adjust..if thris adjustment do not work replace the convergeance ic ..mostly the ic is labeled STK XXXX..
GOODLUCK i hope i this helps you..
please rate my help tnx.
May 29, 2010 | Philips 51PW9303 51" Rear Projection...
Green color projection is lifting from the bottom left corner of the screen. Convergence adjustment for the green projection is unresponsive
Howdy,
The TV has a convergence problem; the IC’s for that circuit will need to be replaced. The cost for this repair runs around $450.00 or more.
Replace the defective Convergence Output IC Part Number (STK392-110. When Convergence Output failure is
detected, it’s recommended that both IC’s be changed.
Thanks for choosing FixYA, Big Irish.
Dec 22, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Convergence
If you can not adjust the convergence, then you need to change the convergence IC's The number of the IC is on the chip. There maybe one or two IC chips. I think there are about 12 to 15 pins or so, and will be mounted to a heat sink. There maybe surrounding resistors that need to be replaced too. I hope this is helpful.
Nov 13, 2009 | Televison & Video
Mitsubishi ws48511 convergence problem
Your model uses one convergence IC its a STK392-110 you need to replace that IC. You can get a replacement at the following link with free instalation instructions with pictures so you can do the repaair yourself. Here's the link.
http://servicemanuals.vstore.ca/
Jun 26, 2008 | Mitsubishi WS48511 48" Rear Projection...
Problem with Samsung TV
SAMSUNG Convergence Problem
It looks like blue convergence. Look at menu, select convergence and see if blue top is bent down on convergence adjust screen. Probably won’t adjust.
Some Samsungs have convergence IC’s on a separate convergence board in the back of the TV. Others have the IC’s mounted on the main deflection board. Either way the board has to be removed to get at the dud IC’s and associated burnt resistors.
You remove the appropriate board, determine if any resistors are burnt or damaged, replace any burnt or out of tolerance resistors, replace 1 or 2 IC's and re-install the board.
Now you have to adjust it to look like new.
If the unit has not been misadjusted and everything is OK now, running the auto focus may put the picture back to it’s previous stunning quality, as it was before IC failed.
If after self or autofocus it is still misadjusted noticeably, try the customer convergence adjustments. Operators’ manuals are available on web through searching.
If convergence can not be adjusted properly, you messed up chip install or resistors may be wrong value or open; or it needs major adjustment.
If you live around Calgary, Alberta try me instead:
http://calgaryconvergencerepair.weebly.com/convergence-explanation.html
Or try to the find the repairperson part of this website (on the Homepage) and search postal code. Maybe you will be lucky and someone from your area is listed for Projection TV repair.
Most rookies doing this job will cause damage and not be successful. They will pay double for someone to fix their mess or end up scrapping the TV. It is not a simple task. It is more difficult than batteries on a remote.
Good Luck
easyab
Jun 06, 2008 | Samsung HCN4226W 42" Rear Projection...
Red Convergence on JVC AV- 65WP74
convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 28, 2008 | JVC AV-65WP74 Rear Projection Television
Sony HDTV Convergence Issue
No, You will not solve the problem with only changing the convergence IC, associated resisters may also be required.
Beside of that, after spending time to get parts and replace the ICs, you need to make and adjustment the color lines (about 14 lines)
This adjustment without experience will take you about 3 to 4 times and 4 hours each to get thing right (if you areskillfull, most of people failed this adjustment).. The total time spend for this problem would take you full 24 working hours.
I successfully adjusted one set of my big TV (95%, need more more round)), on another set one I failed.
Nov 30, 2007 | Televison & Video
PCB's when available,are expensive.Replace convergence IC(s),
re-adjust and you are good to go!
Oct 12, 2007 | JVC AV-65WP74 Rear Projection Television
Televison & Video Logo
32 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
