Question about Dyna-Glo (PPH16-LP) Utility Heater
I have a 4 year old 120,000 BTU kerosene Dyno Glow heater for the Garage and i just went to use it and it was intermitantly blowing fumes....then it went out and smoke went everywhere,,,,it was only on for about 20 seconds.....Now when i turn it on the blower fan and motor comes on but nothing will come out the end.....
    Master:
  • 646 Answers
Consult the manufacturer for help with this problem. It sounds like the burner has failed and may need replacement.
Posted on Dec 03, 2017
SOURCE:
koolbreezes
  • 540 Answers
SOURCE: Reddy Heater Kerosene 50,000 BTU produces TOO
There are2- adjustment screws on the back 1--air---#2-fuel. adjust it while running for the perfect combination for the fuel/ air ratio.!
Posted on Dec 22, 2009
SOURCE: Mr. Heater Natural Gas Garage Heater - 45,000 BTU.
my garage heater was working early this winter. I turned the thermostat to 0, but when I went to restart heater nothing happens, can you help me with this problem?
Posted on Dec 27, 2009
heatman101
  • 43501 Answers
SOURCE: Reddy Heater 50'000 BTU - Puffs Smoke and Leaks Out The End
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters Torpedo Heater Pump Pressure Adjustment
heatman101
Posted on Oct 31, 2010
SOURCE: Dyno-Glo RMC-95-C7 kerosene heater. replaced wick
once the tank gets low(on E) put the heater outside and let the remaining fuel burn completely out. This will burn off the residue build up on the wick and make it easier to turn off manually. do this often. i also use an old toothbrush to "fluff up" the wick. if the residue is too hard for the toothbrush bristles, flip the toothbrush over and break up the residue with the back side of the toothbrush. once all (or nearly all) of the residue has burned off you may see some smoke when you ignite the wick again. also, it may smell for a bit. I always light and shut off the heater outdoors. I mounted a dolly (table withe 4 wheels) under the heater to make transporting it easier. hope this helps!
Posted on Jan 14, 2011
  • 4736 Answers
SOURCE: Problem with the All-Pro Kerosene
Here as link to your DESA International, ALL-Pro heater, Model # PK 60. Be sure to checkout the Trouble Shooting Guide.
http://www.desatech.com/manuals/Construction%20Heaters/113282-01.pdf
I'm sure this will help solve your problem. Please let me know.
Posted on Mar 07, 2011
Kerosene reddy heater flame is intermitent
Heater had a cracked fuel line that was not visiable on original inspection.
Jan 25, 2009 | Reddy Heater-70,000 BTU Kerosene w/T'stat
Fan turns on starts blowing and a lot of smoke.
when you start it the smoke starts wright away it is not getting the right air flow takethe top part off and started see what it does if it stays running try to ajst. the fens ok .
Dec 26, 2008 | All-Pro Kerosene Garage Shop Heaters - All...
Fumes
One of two things, a high heat limit control or the flame sensor, also check your air line that runs to the heater nozzle could be cracked, not enoughair to fuel mix will make it burn dirty.
Dec 14, 2008 | Reddy Heater-170,000 BTU Kerosene Deluxe
Dyna-Glo (PPH16-LP) Utility Heater Logo
304 people viewed this question
Top Dyna-Glo Heating & Cooling Experts
Paul Carew
Marvin
Marvin
fordexpert
Are you a Dyna-Glo Heating and Cooling Expert? Answer questions, earn points and help others
