I have a whirlpool washer wfw9200sq00 not working. got an f70 and f71 errors. replaces eloctronic control and control panel. what else could it be ?
  • 347 Answers
The Problem: The washer may be beeping three times, showing a F70 or F71 error code, and not starting.
Cause: The communications between the electronic components is incorrect
Correction: Use the diagnostic charts below to diagnose F70, F71 and "not starting" complaints.
i have a whirlpool washer - 4207842940_8c8522a241_o.png You have a bad (motor control board ) or motor control board wiring harness issue, the motor control is located in the cabinet bottom on the left side if looking at the front of unit. It is actually maybe more accessible if you remove the rear panel. Run the above test first, M 13 is a small connector with blue wires and is located above the large connector with black wires. it has been my experience that this is a motor control issue Hope this Helps Good Luck
Posted on Nov 06, 2010
How do I know which user interface I need for an error code F71? I'm getting an F71 error code. The washer will not start at all. Model WFW9200SQ00 Whirlpool
Hi
F71 is a communication error and is displayed when there is no communication from the User Interface to the Central Control Unit. First check the user interface harness for continuity and then check the wire harness to the user interface and CCU. If the drum rotates then replace the user interface, if the drum is not moving then replace the central control unit (CCU). Hope this helps...please post back for further assistance.
Daniel
Aug 11, 2011 | Whirlpool Washing Machines
What does an F70 and F71 error code mean?
Hi.
Please read the tip below, explaining how to fix F70 and F71 problems. The comment applies to Whirlpool washers like the one in question.
F70 and F71 are two logic board error codes that point at a communication error between the main log...
Regards.
Ginko.
Nov 29, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Getting code F70 and F71.
Hi.
Please read the tip below, explaining how to fix F70 and F71 problems. The comment applies to Whirlpool Duet washers like the one in question.
Regards.
Ginko.
Oct 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Getting code f70 & f71 washer will not run water does not fill or spin
Hi.
Please read the tip below, explaining how to fix F70 and F71 problems. The comment applies to Whirlpool built kenmore washers like the one in question.
Regards.
Ginko.
Jun 06, 2010 | Kenmore 47081 Front Load Washer
I have a front loader whirlpool washer model # WFW9200SQ00, my problem is the washer starts and runs through cycle start process and then flashes F71, I unplug and plug up and same thing happens. I have...
The F70 and F71 error codes on this model of washer indicates a communication problem between the user interface control board and the central control unit (main control board). These error codes can sometimes be caused by a power surge or glitch through the electrical lines. Try unplugging the washer to completely disconnect electrical power. Wait 1 minute and then plug the washer back in to the see if the fault code clears. If it does, then the washer may work normally.
If the code reappears, then you could have a wire harness connection problem, a failed user interface control board or a failed central control unit. I recommend calling a service technician to properly diagnose and repair this type of problem so that the correct component can be replaced.
Be sure your unit is plugged into a 3 prong grounded outlet as well.
F71 is a "heatbeat failure" which means that your front interface control board is shorted and will need to be replaced. it's actually fairly easy to replace and can definitely be done by yourself. To access the part, just pull the unit forward and remove the 3 screws coming in from the back of the top panel. Remove the top panel by pulling it back, up, and off. Then remove all the screws going into the top of the control panel. Remove the dispenser drawer and remove the screws coming in through the dispenser. Remove the screws coming from the inside of the dryer going forward into the control panel, then remove the control panel (it's just clipped in on the bottom. After that you can disconnect the wire harnesses to the front interface control board and replace that part.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 22, 2010 | Whirlpool WFW9200S Front Load Washer
There is an error code f70 and there was an error code f71.
Hi.
Regards.
Ginko.
Mar 04, 2010 | Kenmore HE2 Plus Front Load Washer
Flashing code F71 then F70
We've owned a Whirlpool Duet Washer (WFW9200SQ00) for about 3 years. We started getting the F70 error code intermittently about 6 months ago and it seems to progressively be getting worse. Unplugging the unit for a few minutes resets the error, but it comes back about every 2nd or 3rd load causing my wife a lot of frustration and with 4 kids, our laundry was backing up. After reading several Forum's, I found the F70 error code indicates a "heartbeat" communication error between the various electronic boards inside the washer and the consensus seems to be the most likely culprit is the Motor Control Unit (MCU) board. Before spending nearly $250 for a replacement board (http://www.helpfulparts.com/servlet/the-5733/8183196/Detail) with no guarantee that it would fix the problem, I decided to take the board out of the machine and inspect it. What I found is the connector for the communication (the connector with three blue wires) on this board is a very unreliable connector that uses the edge of the printed circuit board on one side of the connection instead of a real connector soldered to the board. In addition, the fit of this connector seems to loose to make a good connection. I noticed a little bit of corrosion on the board contacts which I cleaned with rubbing alcohol and a pencil eraser. After re-installing the cleaned board we've done several loads with (keeping my fingers crossed) no errors. I am still concerned about the reliability of this connection. Because of it's location, this board is subject to a fair amount of vibration and because of the loose fit I'm concerned that this issue will only come back over time. I've already decided that if the error comes back I will solder wires to the contacts on the board to provide a more robust connection. It's a shame that you can spend well over $1,000 on a top of the line washer, and in order to save $.10 Whirlpool decided to use a very poor connector in a critical area. It makes you wonder where else did they skimp to save a few pennies?!! Our next washer will not be a Whirlpool, and next time will not get a high end washer with all the bells and whistles.
Oct 02, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Washing Machines Logo
158 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
paul
paul
