Question about Krups Cappuccino/Espresso Maker - Stainless-Steel/Black
I have a new Krups XP 5240 machine. The instructions tell you how to make espresso and froth milk for cafe lattes, but don't mention how to actually MAKE the latte. What is the correct procedure for making lattes, cappucinos, etc?
A latte can be made to suit your own taste, but as a starting point I would suggest:
Steam your milk first to 140 f, let it rest for at least 30 seconds( the temp will continue to rise up to around 160-180 f
while the milk is resting make your espresso shots; I like quite a strong coffee so I would make 2 shots using the double measure (once the coffee starts flowing this should take 15 seconds)
pour your shot(s) into a cup/mug first then top up to about 5mm from the rim of the cup with milk, holding the froth back with a spoon.
finally knock out any bubbles by banging the milk jug on the worktop ( this can be messy until you get good at it). using a spoon/ swirling the jug mix the foam and remaining milk until combined then top up your cup. this gives the smooth foam on the top of the latte.
Hope this helps,
Leni
Posted on Nov 08, 2011
Cafe barista not frothing
the frother gradually gets milk buildup and loses suction- an air blast through the milk tube and up the spout (can get an aerosol at hardware store) will help as well as the cleaning cycle. Also I used a q tip to the top of the spout several times but just had the q tip top come off and may have blocked it completely
May 05, 2014 | Sunbeam Mr. Coffee Cafe Barista Espresso...
I bought a Krups 867-42 espresso cappucino maker from a second hand store. I need instructions on how to make espresso and how to froth milk. I have the necessary coffee pot to brew regular coffee, but...
Hi austyn90211,
Welcome to fixya!
Here is the user's guide to your espresso machine: http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000035208.pdf
Enjoy!
Handie Andie
Jul 15, 2011 | Vacuums
Help received the Delonghi Cafe Nabucco machine from a friend .no instructions ,how do I make expresso ,capp steam milk etc?
http://www.manualnguide.com/dl/10372/
Go to the above link and download the manual for the BCO 120T
It should provide the basics to get you going
Making a good espresso with steamed milk takes practice
If you don't have the frothing pitchers.. buy a couple in different sizes
Used cold low fat or non fat milk..
It takes practice to get good at it.. a hand on the side of the pitcher to make sure you don't scald the milk.. etc.. you don't want the milk to bubble/boil..
If you have a control valve for the steam pipe.. immerse the pipe about an 1/2 inch or so into the cold milk and slowly open the valve.. until you have it open full. Jostle the pitcher to move the milk around pretty much during most of the process once it begins to warm and foam.. raise the pitcher to heat the milk in the bottom .. then lower it as the foam begins to form...never letting the steam pipe out into the froth. Once done..wipe the pipe clean with a wet cloth.
Grind of the coffee is imporant as well as the roast and when you fill the portafilter don't over tamp.. If you pack it to tightly.. won't brew... too loosely.. brews too fast.. You want to see the coffee shots come out and form what's known as crema... which is a thin layer of tan or light brown foam on top of the shot. If aren't getting this..the coffee is either ground wrong or packed too tight.
It's an art..and nothing beats practice.. there are scores of books and internet threads on how to froth milk and make different coffee drinks..
I love a good Cafe Borgia now and again.. we live in the Portland, Oregon area.. everyone here is addicted to the bean..
Best of Luck
Apr 29, 2011 | DeLonghi Caffe Nabucco BCO70...
Not frothing milk
that means that the steamer is not generating enough pressure steam.
This happens either because there is not enough heat, or if you release the steam when pressure is not enough.
Very common problem with the american maid makers.
bear also in mind that Krups are not the best at frothing milk, and this is also a basic model.
If you want the best capuccino Coffee machine, buy the italian ones, Gaggia, Delonghi, Ariete etc. that are all great at this, or get a bigger Krups as a replacement like the Krups XP405040 that is also good at capuccino
May 09, 2009 | Krups XP7225 Espresso Machine
No froth
ing it back to store and tell them ur problem....u can ask for repair or a new machine
Apr 19, 2009 | Krups XP4030 Espresso Machine
My Krups XP4050 frother heats and makes bubbles but no froth
It doesn't froth because the air hole in the frother has become plugged with dried milk (cream). There are two types of frother - old one was a black rubber nipple with a stainless 2-3inch air tube rising above the milk. The plastic insert has a pin hole (really about the size of a straight pin!) that clogs. Use a sewing needle or straight pin to clear it.
Apr 01, 2009 | Krups XP 4050 Espresso Machine
I cant make cappuccino with the instructions in Krups machin F888
Go to krupsusa.com and click on "instructions" you can download the instruction manual.
Feb 26, 2009 | Krups F888-43 CaffeCentro Coffee and...
Milk froths at 1st then doesn't after 1 week
Ensure first that you are using the steam pipe in the correct way to froth the milk.
If it still does not work, that means that the steamer is not generating enough pressure steam.
If you think you are doing everything in the right way, then contact the company and insist for having the machine fixed or replaced.
Nov 07, 2008 | Krups XP 1500 Espresso Machine & Coffee...
Froth control problems
Your vinegar did the job: it as removed the deposits, now these deposits are clogging the four holes porcelain valve.....if the froth lever is not broken.
Remove all the screw you can see on the top and under the top of it, remove the cover, unscrew the frothing device down to the porcelain valve consisting of two 4 holes discs, clean them, and voila!
Dec 22, 2007 | Krups XP 1500 Espresso Machine & Coffee...
Krups Cappuccino/Espresso Maker - Stainless-Steel/Black Logo
332 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
cyfred
Level 1 Expert
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
