Question about GE (PSS26MSRSS) Side by Side Refrigerator
Shouldn't the doors stay open wherever you put them instead of banging into you (or slamming back against the wall) when you're trying to get items out? I have tried leveling the unit according to the manual but can't get the doors to stop swinging.
  • rjfh Nov 11, 2010
    I haven't tried it yet but at least it is something to work on. However, I have a feeling that I won't be able to make the adjustments suggested. Thanks.
  • 4,070 Answers
They are supposed to close on their on because of the door closing cam on the bottom hinge. If it closes faster then you think it should you can check the operation of the door cam. The door should rise about 1/4 when you open it. There is a door stop at the bottom of each door you might can un bolt and reposition to keep it off the wall. The cam is usually black plastic and fits on the hinge pin.
Posted on Nov 06, 2010
Airflow problem with cold start
try lubricating the flap hinges & check to see if there bent or misaligned
Mar 05, 2014 | Nissan Micra Cars & Trucks
My KitchenAid Dishwasher door won't stay closed. It keeps popping open after a few seconds.
I experienced the same problem after my tension cables broke. The door fell open with such force that it bent the hinges a little. If you've replaced the tension strings (which you should do every 5-8 years) then you don't have to replace the latch. I did and it didn't solve the problem.
Here's the solution:
Put a towel at the bottom of each side of the door by the hinge.
Push the door closed a couple of times to bend back the hinges.
Remove the towels and you're back in action.
Good luck
Aug 11, 2012 | KitchenAid Dishwashers
I put some washing in my samsung J845 front loader the door will not lock before the washing can be done. my husband brought a new door latch due to the other one been burnt out and he put it back on the...
Just bang the door again until the error goes away. The door is not lined up and won't latch properly. At least that is what ours does. I usually slam the door on my machine.
Sep 29, 2009 | Samsung Washing Machines
1997 Isuzu Rodeo, 4.2L All windows stopped working!!!
all windows controlled from the drivers door...if you have someone in the family with BIG fists have them stand beside the drivers door panel and putting the **** against the door, SLAM their fist into the door panel right under the switches. Take a can of WD-40 and spray ALOT directly around the switches in the door using the little red hose WD40 gives you. GM's are known for carbon-tracking their door mechanisms...build up over the years...sometime banging the door knocks the buildup loose allowing the circuit to work.
Jun 14, 2009 | 1997 Isuzu Rodeo
Seems like doors bang against open stops
is this when it's opened and slidding back ?
if so there is form tape you can buy and cut off a pice and place at the back of the rollers were they stop.
May 30, 2009 | 2004 Honda Odyssey
Opener only makes clicking sound when activated by remote or wall
where is door trolley, up or down. did it go up too far and wedge against bolt in track. take out bolt to release and try. put bolt back in. did you overheat motor. wait 15 minutes. give more info. (Does light bulb blink 10 times, then safety beam problem affecting door going down).
Jan 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
2005 Chevy Tahoe back door won't stay open...slams shut
no you probably have to change the lift gate struts/supports that are on the liftgate itself. very easy to do and they sell them at the autoparts store i would say for around 30-60 bucks
Jan 13, 2009 | 1995-1997 Chevy Tahoe Ignition Starter...
Borrowed friend's truck - opened the tailgate - now it won't close. seems like the latches are doing nothing, nothing moves or catches when trying to slam/close it shut. Help?
On the truck body there is bolt potruding. On the tailgate, there is a hook that when pushed against the bolt, will shift to grab the bolt and hold the gate closed. This hook can shift just enough to bang against the  bolt instead of hooking it. Use your finger or a screwdriver to push the hook back (or down). You should be good to go. sslgrits
Jul 22, 2008 | 2005 Chevrolet Silverado
Door is slamming open...
Without seeing it.Check to see if the unit is level.If it is, You may want to remove everything on the door and see if it still happens.If the problem still exits, you may be able to adjust the door.
Dec 05, 2007 | Maytag MBF2256H Bottom Freezer...
No Power Whirlpool MH7140XF
does it not light up at all? A microwave has a fuse on it. Probably accessible from the back panel. if not you would need to disassemble it. Most likely cause of this is slamming the door broke one of the safety switches the door has so the microwave knows when the door is open. And it shorted against something when it broke. It might have simply blew the fuse but then again you might have fried it.
Oct 01, 2007 | Whirlpool MH7140XF Microwave Oven
GE (PSS26MSRSS) Side by Side Refrigerator Logo
100 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
