Question about Bissell Healthy Home HEPA Bagless Upright Vacuum - Metallic Blue
I have a model 6100 healthy home vacum. When it's turn on the motor make a very loud noise. I took it apart and blew some dust out of it. And it still make the noise.
  • cmullins2010 Nov 07, 2010
    I done everything you said. took the whoe thing apart and all the hoses where clear. it sounds like it's coming from the main motor. Sounds like it's running way to many rpms. Very loud
  • cmullins2010 Nov 09, 2010
    I took the whole thing apart again. Took all hoses off, crystal clear. Could not find nothing. i took the motor out of housing and blew it out again. I put the motor back in housing and hook nothing to it just to see what would happen. It made the same noise. Sounded like a wood router. it was really loud. I had a good friend come over and and even look at all hoses and every where that air travels through. we both could,nt find anything. I turn the motor back on to let him here it and when i did it started to make a funny sound. After about 10 sec. the motor rpms started to slow way down and making a real bad smell.
  • Bissell Master
  • 43,501 Answers
Usually when a vacuum is making the loud noise it is because of a stoppage somewhere in the vacuum.
To find the blockage some detective work will be needed.
First off take off the hose at the closest point to where in enters the cannister or bag. This will tell you if the hose or the floor unit is plugged up. If the noise changes and goes away then you have a blockage in the hoses or floor unit and need to pull everything apart and clean it out.
To clean out the hose you will need a stick like a broom handle to push completely through the hose.
The floor unit may need to be taken apart to find the blockage. Often there are few screws in the top or bottom that hold it together.
If removing the hose from the unit does not work then you will need to use your manual to find and clean all filters and check all of the passageways in the vacuum it's self...
By checking all of these things you should be back vacuuming again...
Here is a tip that I wrote about my Bissel but I bet you have the same problem and the hose is clogged...
Bissell Bagless Upright Vacuum not working
heatman101
Posted on Nov 06, 2010
  • D. Floyd Kolb
    D. Floyd Kolb Nov 07, 2010
    That is exactly the sound that you get when something is clogged....believe it or not the rpm's do actually go up because the motor cannot get air so it actually is not working at all so the rpm's go up.....
    I have a Bissell similar to yours but not the exact model... I have had similar problems and have really had to hunt to find all of the filters....and once even had something in the hose that would flip out of the way when I ran something through it, but then would flip closed when air was pulled through in...
    I still think you will find there is something blocking the air flow...
  • D. Floyd Kolb
    D. Floyd Kolb Nov 09, 2010
    Wow, seems like something went wacky internally in that motor.... can you return it under warranty??? How long have you had it...
    If too long then getting a new motor will cost more then a new machine...junk it and get a new one...
Very loud screeching ,continuous when turned on
Hi dfabin,
Does the screeching come from the motor area or the brush/belt area?
If it's from the motor. Turn it off. It needs repair.
If it's from the brush/belt area, most likely your belt is either slipping or rubbing on something.
Do you have an owner's manual?
If you do, and the noise come from the belts, take the belt(s) off and check them for wear, stretching, anything imbedded in them. Be sure to clean all debris out of the area. and reassemble. If still noisy, the belt may be slipping and needs to be replaced.
Here's a site where you can view the parts breakdown and order parts: http://www.vacpartswarehouse.com/Bissell-Healthy-Home-Models-5770-5990-6100-6405-s/600.htm
Hope this helps. If it does, I'd appreciate a vote. Thanks,
Handie Andie
Apr 03, 2011 | Bissell Healthy Home HEPA Bagless Upright...
What kind of belt do I need to fix my vacuum?
Healthy Home Bagless upright vacuum cleaner replacement belt. Genuine Bissell part number 203-1329 or 2031329. Fits All Bissell Healthy Home, and Heavy Duty models including; 5770, 5770-5, 5770-8, 5770-P, 5990, 6100, 6405, 50C9. Belt contains the following code MS 3M-243-12 written on the outside.
Feb 16, 2011 | Bissell Upright Vacuum - The Pet Hair...
It is shooting out dust and particles from the back.
The bag is damaged or incorrectly fitted or not closed properly.
Jan 20, 2011 | Bissell Healthy Home HEPA Bagless Upright...
POWERMATE HEAD DOESNT SEEM TO HAVE GOOD SUCTION AND IS LOUD
suction wise have you checked the internal pipes on your vacum as for the load noise if it is quite a load noise a humming noise it is ure motor so not worth fixing motors r pricey for a vacum
Feb 03, 2010 | Kenmore Vacuums
Motor noise and burning smell
your belt is of the guide arm try replacing the belt usually located @ the head of the vacum there should be 4-6 screws holding the head on remove it in well ventilated area try putting on mask cause you will release all the dust from the head when you take it apart you will see the belt around the brush remove the brush and bearings togther then replace belt if you know your model # of your vacum u can usually find replacement parts online or @ most sears and walmart outlets.
Jan 26, 2010 | Dyson DC14 Bagless Upright Cyclonic Vacuum
The motor for brush won't turn on for the bissell healthy home vacum
Is the grey "brush" button on the handle depressed? Brush won't turn unless the button is down
Jan 01, 2010 | Bissell 5770 Healthy Home Bagless Upright...
Motor noise CV 353
its not that bad to take apart and blow out the motor with a compressor, but if that dust got into the bearings of the motor it could be ruined.
Apr 19, 2009 | Broan-NuTone CV353 Central Vacuum
Bissell Healthy Home HEPA Bagless Upright Vacuum - Metallic Blue Logo
70 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
