Question about Motorola MU24CVS UHF (4 Channels) 2-Way Radio
WILL THE MU24CVS AND THE MU21CV CAN THE TALK TO EACH OTHER
  • Motorola Master
  • 1,654 Answers
Yes. They would simply need programmed to match. MU24 is a 4 channel radio, so you would need to leave it on channel one to match the 1 channel MU21 model.
Here is a link to the user guide where you can read about programming the radios: http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/Spirit_M_Series_E.pdf
Best regards.
Posted on Nov 06, 2010
What is the frequency for this radio what ever came with it
These are programmable radios that require Motorola software and programing equipment that is only available through a Motorola dealer. A reputable dealer should be able to help you reprogram the radios with the appropriate frequencies and codes for your use.
Dec 08, 2013 | Motorola MU24CVS UHF (4 Channels) 2-Way...
Where can i buy battery terminals for my spirit mu21cv walkies
Your local Motorola radio dealer should be able to help you with this.
Mar 23, 2012 | Motorola MU21CV (1 Channel) 2-Way Radio
I have a Motorola MU21CV with a overly sensitive 'push-to-talk-switch'. Sometimes even though you press it and get the "red" transmit indication - it's not transmitting. Is there anyway to...
  • You can open the radio up and clean the switch up a bit but it sounds like the switch may be worn. It's a simple on off push switch. You may just go to your local hardware store or electronics store and get a switch and solder it in.
Regards, Tony
May 03, 2011 | Motorola MU21CV (1 Channel) 2-Way Radio
Will the MU21CV radio's work with the talk about radios?
Short answer, maybe. It depends on whether you have a 14 channel or a 30 channel Talk-About. The Motorola Talk-Abouts operate on the FRS frequencies (14 channel) or FRS & GMRS frequencies (30 channel). The MU21CV does cover a few of the GMRS frequencies. (see bold numbers)
GMRS Frequencies
462.500, 462.575, 462.600, 462.625, 462.650, 462.675, 462.700, 462.725, 467.550, 467.575, 467.600, 467.625, 467.650, 467.675, 467.700 & 467.725
FRS Frequencies
462.5625, 462.5875, 462.6125, 462.6375, 462.6625, 462.6875, 462.7125, 467.5625, 467.5875, 467.6125, 467.6375, 467.6625, 467.6875, 467.7125
MU21CV Frequencies
464.500, 464.550, 467.7625, 467.8125, 467.850, 467.875, 467.900, 467.925, 462.575, 462.625, 462.675, 464.325, 464.825, 469.2625, 469.500, 469.550, 462.7625, 462.7875, 462.8125, 462.8375, 462.8625, 462.8875, 462.9125, 464.4875
Nov 01, 2010 | Motorola MU21CV (1 Channel) 2-Way Radio
When i try to talk on another motorola spirit mu21cv it makes a cracking/static sound and it transmits what im saying but i have to have it very loud for it to work and even then it makes a very loud...
Two things come to mind. First, you may have a bad battery. It is typical for a bad battery to cause the radio to have static, or poor transmit. Second, you may not have the radios set to the same frequency as one another, or one is on a narrowband frequency, and the other is wideband. (Depending on the age of the two units.)
Try switching the batteries between a working radio and the staticy radio. See if the problem moves to the other radio. If so, replace your batteries.
Check your programming, if you don't know how, contact your local Motorola dealer or give us a call (google our name). We can walk you through programming over the phone.
Lastly, if all these suggestions fail, your radio may be in need of repair. Flat rate repair is currently around $69 ea.
Best regards.
Oct 18, 2010 | Motorola MU21CV (1 Channel) 2-Way Radio
Is the motorola MU21CV a UHF or VHF??????
MU21CV is a UHF radio.
MU= UHF
MV = VHF
Here is a link to the user guide: http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/Spirit_M_Series_E.pdf
You can find a frequency chart on page 10.
Best regards.
Jan 11, 2010 | Motorola MU21CV (1 Channel) 2-Way Radio
Compatability
Any programmable UHF 450-470MHz mobile radio could be programmed to the frequencies of the Spirit MU series radios.
Your radios are 2 watts, so you would probably want to stay with a 1-10 watt, or 10-25 watt mobile radio, to have the best success. The current compatible model for Motorola is the CM200 UHF radio. If you are looking at a used radio, just simply watch for it to be UHF 450-470 MHz.
Then when you are ready to have the mobile radio programmed, the dealer (or programmer) will need to know the settings of your MU radios. These are easily read out over the phone, or in person by an experienced programmer.
Dec 13, 2008 | Motorola MU21CV (1 Channel) 2-Way Radio
Compatability
would a MU21CV be a VHF or UHF????
Aug 12, 2008 | Motorola MU21CV (1 Channel) 2-Way Radio
MU21CV
It is likely your radio needs a new rechargeable battery.
Jun 24, 2008 | Motorola MU21CV (1 Channel) 2-Way Radio
Motorola MU24CVS UHF (4 Channels) 2-Way Radio Logo
104 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
