Question about Intermatic Inc. ST01C Digital In-Wall Timer
I need instructions on how to set the timers on my tork electric timer for my outdoor lights ,it is put into my switch inside
  • Anonymous Nov 06, 2010
    If you tell me the Tork timer model, I will look up the manual.
Here is link to Tork in-home timers showing digital 7-day programmable timer:
http://waterheatertimer.org/Tork-consumer-timers-and-manuals.html#SS700
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Feb 08, 2011
Where to purchase trippers for GE mechanical time switch model #15163?
This actually a Jasco 15163 and according to www.harwareandtools.com it takes a Jasco 15602 tripper set. This tripper set can be found for online order at http://www.jascoproducts.com/products/pc/Replacement-Timer-Tripper-2-pack-p1089.htm#.U9Ov2bHG-f415602webg2.jpg
Jul 03, 2014 | General Electric GE 56941 24-Hour Outdoor...
INSTRUCTION MANUEL FOR Tork 654A Digital Outdoor Photocell Timer
Copy following link to identify 2-outlet, dawn-dusk, Tork 654A digital timer and download possible manual, and read instructions.
http://waterheatertimer.org/Tork-consumer-timers-and-manuals.html#outdoor
Also sold as GE 15255:
http://waterheatertimer.org/GE-timers-and-manuals.html#outdoor
Nov 11, 2012 | Hardware & Accessories
I have a tork 651a . that only works at knight and its a photo cell,go figure....can you help???????????????
Tork 651 timer is dawn-dusk that automatically turns on at dusk.
Open following link to identify timer and download instructions:
http://waterheatertimer.org/Tork-consumer-timers-and-manuals.html#651
If you want ordinary 24-hour on-off timer for outdoors, instead of dawn-dusk timer, then select Tork 611A or Tork 601, or Tork 611 timer shown on same link above.
http://waterheatertimer.org/How-to-set-timers.html
Jul 25, 2011 | TORK 651A Photocell Controlled Mechanical...
GE Indoor Outdoor Timer # 15306 the clock is working and the when the time for it to go on it goes on but when the time comes for it to shut off it does not trip the off switch. I then have to shut it down...
1) If analog dial keeps time, I can only guess that OFF tripper is not in position correctly, or tripper is worn or defective, or that manual override lever is defective. Trippers are made of softer metal so they wear down before other parts of timer.
http://waterheatertimer.org/images/GE%2015306%20Mechanical%20Outdoor%20Box%20Timer-24%20Hour.jpg
2) Buy Tork P47 trippers to replace GE 15306 trippers
http://waterheatertimer.org/Tork-timers-and-manuals.html#Trippers
3) Open following link for GE timer resources:
http://waterheatertimer.org/GE-timers-and-manuals.html#15306
4) 15306 is heavy-duty indoor-outdoor version of Tork 1800 series or 7200 series 120Volt analog timer that is sold online and at Home Depot under GE brand name.
http://waterheatertimer.org/images/Tork-1800-600.jpg
5) You can buy new timer at Home Depot and return defective one in new package.
6) The on and off trippers are attached to the analog dial.
Dial rotates as time passes.
Trippers make physical contact with the manual override lever. The ON tripper pushes lever one direction and the OFF tripper moves lever other direction.
The override lever rotates a cam located on back of timer that opens and closes electrical contacts.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Jun 02, 2011 | General Electric GE 56941 24-Hour Outdoor...
Will the 7120z work on a gfi breaker
7120Z timer is electro-mechanical astronomic dawn-dusk timer so it should perform fine on gfci breaker.
http://waterheatertimer.org/Tork-timer-and-manuals.html#7200
The purpose of gfci is to identify electrical short at the moment it happens and trip off so nobody gets shocked.
Typically you find gfci with outdoor wiring, and astronomic timer controls outdoor lights.
If you locate box outdoors, it must have NENA3R raintight indoor/outdoor case.
If timer is indoors, then NENA1 enclosure/case is fine.
Apr 13, 2011 | TORK Hardware & Accessories
How do you program a Tork 602A timer? I can't get mine to cycle on and off at a desired time.
The Tork 602A mechanical outdoor timer with 2 grounded outlets.
Tork 601A and 602A manual
http://waterheatertimer.org/pdf/Tork-601A-Manual.pdf
Manual has images of timer that will help.
Plug timer into outdoor outlet.
To set current time, rotate dial clockwise until current time lines up with arrowhead located on inner dial.
Dial is divided into light and dark sections that represent day or nighttime hours.
Reset time after power outage.
96 pins located around timer dial are used to set on-off times.
Each pin represents 15 minutes in 24 hour day
Move pins in-or-out with fingernail or ink pen to set timer on-off functions.
With Tork timers, usually when pins are out, timer is ON.
When pins are in, timer is OFF.
To double-check pin setting, manually rotate timer to watch when lights turn on-off.
Set multiple ON/OFFs each day.
Change on-off times by resetting a pin or two.
Timer repeats every 24-hours.
Manual ON/TIMER switch is located on inner dial.
Set Manual switch to TIMER for programs to operate.
To override time and turn on Load, move override to ON position.
Dec 09, 2010 | TORK 601A 24 Hr Mechanical Outdoor Timer ...
How to set a GE outdoor timer product ID 51587 ?
GE 51587 has same instructions as Tork 601A single-outlet outdoor 24-hour mechanical timer.
Move pins in-or-out with fingernail or pen to set timer on-off functions.
With GE timers, usually when pins are out, timer is ON.
Manual ON/TIMER switch located on inner dial.
Set override to timer for program to operate.
Dec 06, 2010 | GE 51587 MultiEvent Timer
Is there an instruction booklet available?
Instructions for tork timers:
Tork makes several timers that look similar.
Link above has photos of each type with manuals.
Dec 02, 2010 | TORK 601A 24 Hr Mechanical Outdoor Timer ...
I didn't get any instructions with my timer. It is a tork 601A I don't know how to set it. I think it looks great and just what I'm looking for. The case was sealed but no instructions. Thanks J Seel
Tork 601A outdoor timer manual:
Timer has 1 125Volt receptacle located on bottom of timer
96 captive tabs located around timer dial allow times to be set each 15 minutes.
Minimum time setting is 15 minutes.
Maximum time setting 23 ¾ hours.
Dial is divided into daylight and nighttime hours.
Nighttime PM hours are on dark background.
Daylight hours are on light background.
To set timer, rotate dial clockwise until current time lines up with arrowhead located on inner dial. Reset time after power outage.
To override time and turn on Load, move override to ON position. To use timer functions, move override to TIMER position
I have a Tork timer model number 1101 24 hr time switch. Can you tell me how to set it???
Tork 1101 is a 120V mechanical dial-type timer
c79f9b8.jpgTork 1100 series
To set timer, you lift and rotate dial. Line up current time with the word Time located to lower right of dial.
Next, place trippers on dial. Dark trippers are OFF and light-colored trippers are ON
Tork 1101 is 120V timer.
120V Black Hot wire from circuit breaker connects to Pole L
There is a brass bridge that connects Pole L and Pole 1 >> if this is missing, put a jumper wire that connects both Poles
120V White Neural wire from circuit breaker connects to Pole X
White wire going to Load (lights, fan, motor) connects to Pole X
Black wire going to Load connects to Pole 2
Up-vote if this information was helpful. Thanks for the feedback.
Oct 14, 2010 | TORK 651A Photocell Controlled Mechanical...
Intermatic Inc. ST01C Digital In-Wall Timer Logo
188 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Hippy_dd
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
