Question about Gateway GT4022 PC Desktop
I had a blackout and heard a pop-When electricity returned the computer starts to start up for a second then goes off-I think the fuse blew
    Scholar:
  • 85 Answers
Should be a SMPS problem better contact your hardware engineer.
Posted on Nov 06, 2010
How to troubleshoot this electrical problem?
Hi HDWG1, if you have a 2000 FXDWG the fuses and main circuit breaker are located behind the left side panel and the bracket that is secured by four nuts. The very first thing I would ckeck is battery voltage sould be 12.5 volts or better. The second thing I would check is the battery cables to be sure they are clean and tight especially the ground cable at BOTH ends. In case this turns into a lengthy search and repair issue you can reach me for more free advice at xlch@mail.com. Do you have a service manual? Good luck and have nice day. Gregg
Jun 09, 2015 | 2000 Harley Davidson FXDWG Dyna Wide Glide
My mitsubishi tv started out with white dots on the screen.eventullay i heard a sizzle and pop and the tv went out. so i did research found that i needed to replace the dlp chip which i did and the la
Most likely a fuse blew when the lamp blew, there is internal fuses on the power supply board on these mitsubishi's, if the fuse is ok though then most likely another component somewhere failed.
Jan 02, 2018 | Mitsubishi WD Televison & Video
No Power to Ignition Switch on 1990 Pace Arrow/Ford 460-v8
defintely sounds like fuse or relay. also could be relay for your headlights thats runs to the ignition switch as well. trace your wires from ignition switch out through the firewall and see where they go. may need to have second person help. Wherever the wires go is prob your problem. Most likely a relay. also check for any hot wires loose touching thats shortening the circuits.
Mar 13, 2014 | Cars & Trucks
Everything works great except after you touch a button or something there is like a 5 second delay and the screen turns black. but lights up everytime you do something to it....
Blackout Mode On and Off
When the Blackout mode is turned on, the display will
turn off to reduce power consumption.
This additional power enhances the sound quality.
1 Press and hold the B.OUT button for at least 3
seconds to start the blackout mode. By doing so the
display will turn off.
NOTE
If any button on the unit is pressed during the blackout mode, the
function will be displayed for 5 seconds to show the operation
before returning to Blackout mode.
To cancel the blackout mode, press and hold the
B.OUT button for at least 3 seconds.
Mar 31, 2011 | Alpine CDA-9827 CD Player
I went to start my triumph and let it idle for about ten minutes. I began to leave and as soon as I pulls the throttle it died. I then opened the choke and restarted it but as soon as I gave it gas it...
Sounds like its been sitting a while and you have to clean the jets in the carb.
As for the electrical problem.
Sounds like it could be the ignition main fuse. There is a main hot wire off the battery that goes to your ignition switch that is always hot, when you turn your key it sends that power to everything else.
That hot wire has an inline fuse that is not in the fuse box. It probaly blew from trying to start the bike repeatedly and the wires got hot and the fuse blew. Clean your carbs, and check that fuse.
Dec 02, 2010 | Triumph Legend TT Motorcycles
Started washer, heard 'pop', water started coming out of bottom
Thats not good. Sounds like the seal blew out. Inside the unit there are seals that seal up the parts where they are bolted together. Also there is the pressure connection that could have blown out as well. To determine which is the problem you will need to dissassemble it.
Jun 22, 2010 | Karcher K 593 M Electric Pressure Washer
Had blackout and now furnace won't start
The biggest items to check after blackout are the circuit boards and the transformer. Also if the furnace was running when it happened, the unit could trip on limit...BUT if this happened the blower would run nonstop with no activity of heat. If no blower, you will need to start with 120v to furnace and then 24v from transformer.
May 11, 2010 | Coleman Propane Forced Air Heater...
My son put a bottle cap in where the lighter goes,i heard a popping noise,now i have no interior lights or stereo.fuses dont look spent.I have a 91 chevy 1500k.any ideas on how to fix this?
replace the fuse. he shorted out the lighter and it blew a fuse, it is either one maked int or lighter i think. oh, remove the bottle cap first.
Feb 07, 2010 | 1991 Chevrolet K1500
Got an alpine cda 9855 the screen keeps goin black but if you touch the button it comes back on it has like a 5 sec delay then it goes black but still plays any help
Blackout Display Mode: When the Blackout mode is activated, the display turns off to reduce power consumption. The additional power made available by turning off the display helps enhance sound quality. If a button is pressed during the Blackout mode, the display will illuminate for 5 seconds before blacking out again. Blackout Mode On and Off (CDA-9855 only) When Blackout mode is turned on, the display will turn off to reduce power consumption. This additional power enhances the sound quality. Press and hold FUNC. for at least 2 seconds to activate the blackout mode. The display will turn off. If any button on the unit is pressed during the blackout mode, the function will be displayed for 5 seconds to show the operation before returning to Blackout mode. To cancel Blackout mode, press and hold FUNC. for at least 2 seconds.
Copied from the alpine user manual..
Hope this helps
Aug 01, 2009 | Alpine Car Audio & Video
Plugged xbox into wall and heard a pop, now it doesn't work
The current was proberly to high and blew the fuse or worst blew a electrical component in the xbox360 itself. You will need to either replace the fuse or call microsoft and see if they can replace your console or give you advise on how to fix it.
Jul 28, 2009 | Video Game Consoles & Games
Open Questions:
Toshiba Support USA - Toshiba Online Customer Care Support USA Toshiba as a brand has continued living up to the expectations of its customer for nearly three decades now, by maintaining the high quality of its products with the help of delivering a combination of useful software and attractive hardware in a package, which is required for providing the needed technological expertise. With laptops becoming an indispensable and integral parts of our lives, it is important that companies today equip their laptops with all the advanced technologies along with a sleek and stylish design for that attractive feature that would add to its plus point. Our Toshiba technical support team members are available all the time on our Toshiba Support number +1 888 784-9316 and are highly adequate in resolving issues related to Toshiba printers. The fact that everyone today knows about Toshiba Support brand and most people who have tried Toshiba products like them, makes them one of the most reliable in case of printers especially. Toshiba makes business portable laptops, with highly durable features of being sturdy and long- lasting for use in all walks of life. Most laptop owners would agree to the fact that Toshiba products are designed to provide quality portable solutions and highly acclaimed for their bullet-proof build value. But with time, users might face issues with Toshiba Virus like any other laptop band and these issues can be prevented from causing any severe damage to the laptop by accessing resolution from our technically specialized team members, who are available on our +1 888 784-9316. Issues faced by Toshiba customers: Toshiba Backup BIOS update issues Slow Performance Office and outlook setup Wifi and Internet Issues Audio & Video Issues Startup and Boot problems Windows updates Windows 10 upgrade issues Computer Tune-up Issues Virus Removal Issues Data Backup, Transfer and retention issues All these issues and many more, concerning Toshiba users are directly and efficiently resolved by our technically knowledgeable team who can be Reached 24/7 on our Toshiba Contact- +1 888 784-9316.
Apr 23, 2018 | Toshiba Computers & Internet
See all Gateway GT4022 PC Desktop Questions
Gateway GT4022 PC Desktop Logo
18 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
