Question about Dewalt DC011 AM/FM Radio
The radio lights up charges a battery but there is no sound
    Scholar:
  • 71 Answers
The speaker wires might be loose or touching take the radio apart and follow the wires to see if its just the wires if they are fine check the souder points on the mother boards
Posted on Nov 06, 2010
Radio shut off while driving. All lights on radio display not showing up. Also, when using the turn signals, I don't hear them anymore, and when key in ignition, the chime doesn't sound.
Make sure battery and charging system are working properly. If charging system is not effectively charging the battery and the battery runs low on charge, the vehicle will start shutting down different electrical units/modules in order to keep the vehicle running
Mar 08, 2016 | 2007 Chevrolet Equinox
Toyota Camry 2005, battery light came on, bought new battery, car started and ran although the battery light did not go off ran the car that Friday, Saturday morning left for work, lights started...
it does sound like the alternator but i would get the battery charged and then have someone to check the charging system and the fuses......get the battery charged first so they want try to sell you a battery and an alt. cause there are a few people out there that want to take you.....
Sep 12, 2011 | Toyota Camry Cars & Trucks
My 1995 chevrolet silverado wont turn over. it acts as if it wants to crank but doesnt. the dash lights light up but my headlights and radio wont come on. My battery is fully charged and my alternator is...
Sounds like the starter may have some issues. However, the headlights and radio not coming on is a sign that either the battery is not charged up sufficiently, or there are some blown fuses.
Also, the connections should be checked at the battery for corrosion which can block the electricity from flowing freely from a 'charged' battery to the starter or the lights.
Good luck on this repair.
Jan 12, 2011 | 1995 Chevrolet Silverado 2500
The radio will not turn on and when I charge it and turn it on when its charging it makes popping sounds. Also charger light will not come on when it is plugged in.
The two items that most commonly cause this problem are a bad charger or a bad battery. First try putting the radio in a different charger. If the problem persists, swap the battery with one from another working radio.
Oct 28, 2010 | Motorola MU21CV (1 Channel) 2-Way Radio
Audiovox 2 way family radio charger (for 4 radios). Plug in RV and no lights displayed indication it's charging. Remove inline fuse and it's ok. Put fuse back in and orange lights come on indicating it's...
It sounds like you have some corrosion on the terminals. Remove the batteries and with a good light source look at the springs and plates to make sure there is no corrosion. If there is remove it with crocus cloth. Check the batteries also for corrosion. If you find any remove it the same way. If after cleaning everything the batteries still will not charge get new ones as you probably have one or more which are shorted.
Thanks for using FixYa and for the generous rating.
hardrocko
Aug 01, 2010 | Audiovox 2-Way 14 channel FRS Family Radio...
Battery not charging light comes on at idle rmp
SOUND LIKE ALTERNATOR NOT CHARGING BATTERY.BEFORE BUYING A NEW ALTERNATOR CHECK ALTERNATOR WIRES AND FUSE.IF YOU HAVE TO REMOVE ALTERNATOR.TURN OFF RADIO BEFORE REMOVING NEGATIVE BATTERY CABLE.SO YOU WONT LOSE PLAYING CODE.
Apr 18, 2010 | 1998 Cadillac DeVille
Charge cradle says charge complete even when no radio/battery
The full charge light MAY be strictly a voltage monitor and with no battery installed the unloaded charging voltage may trigger the light.
Some of the circuits are not very sophisticated.
The key thing is if your batteries are being charged normally when you do charge them?
Jan 11, 2010 | Vertex Radio Communications
Problem charging
If you are referring to a flashing yellow light on the charging base, this is an error code. Either the 1) battery is bad, 2) not making good contact in the charger, or 3) very very low on charge. The solution for this set of problems is as follows: 1) have the company you purchased them from replace them, 2) clean your contacts with a pencil eraser, 3) leave the battery on the charger with the yellow light flashing for an hour or two. If the battery is just very low on a charge, it will come back to life and the light will change to be constant. If the battery is bad or shorted out, the light will continue to flash and you will need to get with the vendor you purchased the batteries from.
Other things which come to mind are compatibility issues such as you are using a different battery chemistry than you had before. NiCd batteries can charge on either of the two chargers available for the P110 (slow rate or fast rate). However, NiMH and Li-Ion batteries require a fast rate charger.
If you are referring to a yellow blinking light on the radio while it is in the charger. You need to shut your radio off. Radios should always be turned off when charging. If the radio is left on you will never have a full charge. Also, if you inadvertently press the PTT while the radio is turned on, while on a charger, you can cause damage to the radio.
FYI: There is no light to show "out of range" on the radio, unless you are possibly using a trunking or repeater system. A blinking light on your radio indicates the radio is turned on and/or there is traffic on your frequency. Your charger base light can be red, yellow or green. This indicates the charge cycle status. Flashing most always means some type of error.
Best regards
May 20, 2009 | Motorola For RADIUS P110 7.5v 1200mAh NiCd...
My radio cuts out when I put my brakes on or my signals on what could be the problem???
Sounds like the radio is getting power from the light system. Run a hotwire direct to the battery and see if that fixes the radio. I all
likelihood the problem will not come back.
Mar 22, 2009 | 2000 Harley Davidson FLHTCUI Electra Glide...
Dewalt DC011 AM/FM Radio Logo
88 people viewed this question
Top Dewalt Audio Players & Recorders Experts
Gyula Lacz
Rob Beech
Are you a Dewalt Audio Player and Recorder Expert? Answer questions, earn points and help others
