Question about Intermatic & Indoor/Outdoor Rain Tight Timer
I lost the little red stopper thing (still have the green one) that you put on the dial to kick the electricity off. Are those sold separately by chance?
  • 2,100 Answers
Yes they are, any hardware store should have them. They are a common item, even other timers should fit it. I have some in the garage now. Hope this helps.
Posted on Nov 06, 2010
Specifically I'm trying to identify the wire on the spark plug coil assembly to which I should connect the signal wire of a Tachometer to. The wire colours are, red, yellow, green/white, and blue.
It says the tachometer wire is Yellow/Green, you do not have that listed. You will find it in the list below, it is highlighted..
WIRING INFORMATION 2001 Subaru Legacy
WIREWIRE COLOR LOCATION
12V CONSTANT WIRE WHITE Ignition Harness
12V IGNITION WIRE GREEN Ignition Harness
12V ACCESSORY WIRE YELLOW Ignition Harness
STARTER WIRE WHITE/BLACK Ignition Harness
POWER DOOR LOCK (-) WHITE Harness In Driver's Kick Panel
POWER DOOR UNLOCK (-) GREEN/RED Harness In Driver's Kick Panel
PARKING LIGHTS (+) ORANGE At Light Switch
DOOR TRIGGER (-) PINK/BLACK In White Connector Behind Fuse Box
TRUNK TRIGGER (-) YELLOW/BLUE In White Connector Behind Fuse Box
TRUNK RELEASE (5-wire) LT.GREEN/YELLOW At Motor In Tail Gate
FACTORY ALARM ARM (-) Factory remote only
FACTORY ALARM DISARM (-) Factory remote only
TACHOMETER YELLOW/GREEN At Ignition Coil
BRAKE WIRE (+) WHITE/BLACK At Brake Pedal Switch
HORN TRIGGER (-) RED/GREEN Harness At Steering Column
LEFT FRONT WINDOW UP BLUE/RED At Driver Window Motor Inside Door
LEFT FRONT WINDOW DOWN BLUE At Driver Window Motor Inside Door
RIGHT FRONT WINDOW UP BLUE/RED Harness In Driver's Kick From Driver Door
RIGHT FRONT WINDOW DOWN BLUE Harness In Driver's Kick From Driver Door
LEFT REAR WINDOW UP BLUE/RED Harness In Driver's Kick From Driver Door
LEFT REAR WINDOW DOWN BLUE Harness In Driver's Kick From Driver Door
RIGHT REAR WINDOW UP BLUE/RED Harness In Driver's Kick From Driver Door
RIGHT REAR WINDOW DOWN BLUE Harness In Driver's Kick From Driver Door
Feb 07, 2016 | 2001 Subaru Legacy
We have an LG electric dryer Model number DLE2050W and when I turn it on it starts and runs but after awhile the illuminated board goes black,but the dryer continues to run. But it will not shut off.
I have an educated guess for you. A part of each control of a washer and a dryer is a little electric "clock". Those things can fail. I sounds like you may have a timer clock that is sticking and not advancing.
These " clocks" are a part of the times, and are not sold separately.
One way to possible tell would be to put your ear to the area of the control panel where the timer is and listen. Most of those "clocks" tick, and you can often hear them, or you can watch the dial, and it should advance with a click every so often.
Be blessed.
Feb 13, 2014 | LG Dryers
I would like to know ow yo fine tune my Yellow and Green colors on my Mitsubishi HD 1080 Series
If this is an auto convergence you may be in for a bit more of a project than you want to be into. If there are separate color guns then you can adjust them individually with a screwdriver from inside
Nov 09, 2013 | Mitsubishi Televison & Video
Good older rca tv favors blue green, red is weak. tint function doesent help this problem is there an adjustment inside?, where, turn down green blue or turn up red? jm
Hello; The red probably got low over a long period of time due to only one thing. The CRT/ Picture tube is getting weak and cost much more than the set sold for. The adjustments may only help a little and the set will get worse. These adjustments are done on your remote control with service menu accessed. You will need a Service Manual for instructions to do this, but I think it's time for another set. John
Apr 25, 2011 | RCA MM36100 36" TV
It is not switching on.when i set it for charging it show full charging but when i turn it on it shows red light and 3 time tone is heared thn it become off.....please help me
Even i also had a same problem after format a player its working good. Format your player and put songs again. thats it.
Notes:
  • Formatting is only available when the player does not playback.
  • If the OPR lamp lights red due to low remaining battery power, the player cannot be formatted.
  • All data stored on the player will be erased.
  • The Content Transfer software included with the player will also be deleted. If necessary,
    download Content Transfer from the customer support web site.
  1. Unite the left and right parts to turn off the player.
  2. Separate the left and right parts.
  3. Press and hold the jog dial for about 15 seconds until the status lamp blinks quickly.
    Release the jog dial. The OPR lamp lights red.
  4. Rotate the jog dial within 30 seconds after the OPR lamp lights red.
    The status lamp turns off. The OPR lamp lights alternately green and red each time you rotate the jog dial.
  5. Press the jog dial while the OPR lamp lights green.
    The OPR lamp blinks green quickly and formatting is executed. When the OPR lamp turns off, formatting is complete. If you press the jog dial while the OPR lamp lights red, or if 30 seconds have passed, formatting will be canceled.
have a nice song for ever...!!!!!!!!!!!!!!!!!!!!!!!!
Apr 11, 2010 | Sony Walkman NWZ-W202 MP3 Player
I'm trying to install a rotary phone, but it doesn't have a jack like modern phones do. It has three wires with little crescent shaped metal things on the ends. Please help!
if they are red-green-yellow then just isolate your yellow wire and spade and open up phone junction box and connect the red/green wires to the red/green wires on phone jack terminals you can hook either way this type of phone isn't polarity sensitive,then make sure all other phones on this line work properly after install
Sep 15, 2009 | Cortelco 1950's Classic American Standard...
Pixma MP830 is printing things green that should be red
when you change all new cartridges (make sure all cartridge ok, and the cartridge pins connection ok) still red color lost, it is the trouble at print head ink chanel some of that is too dry for longer time less using , most CANON printer head is separated from the ink cartridge, two way you may try:
1) take out the ink cartridge, drop down a little the special cleaner (best clean tools buy from dealer), to the head ink chanel hole, then set back the ink cartridge and waiting minutes
2) try put the print head bottom surface touch a little cleaner or water 1-2 hrs, if you can take out the print head unit. still not fixed for some case that should change the print head unit.
Feb 06, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Dirt/Collection Tank Bissell Little Green
I had the same problem, so I took out the black stopper, and soaked the whole thing in bleach water for about an hour, then I took a hand full of " aquarium " rocks and put them inside the tank, and shook them inside using a bit of the same water and then got rid of the rocks,( the rocks worked as an scrubber ) .... it worked pretty good
Sep 22, 2008 | Bissell 1400 Little Green Pro Canister...
Intermatic & Indoor/Outdoor Rain Tight Timer  Logo
Top Intermatic Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
