Question about Philips 42PF9630A 42 in. Plasma Television
42PF7320A/37 Is the viper located on the SSB Tuner board 3104-313-60376?
  • yrush Jun 21, 2008
    Replacing it fixed the problem. I replaced the whole board though.
    Problem Solver:
  • 5 Answers
Regards
Has already received a question for the Philips plasma television from yrush member had asked about the location of damaged Crystal View I should send him service Manuel If he wants
With greetings ------------------------------------------------------------------------------------------
Symptom
TV turns "off" by itself, the LED blinks 5 times. Cure
Replace X-tal (Viper) on SSB (item 1H00, order code: 2422 543 01397). REMARKS:
- Error 5: Viper does not boot.
- Only a "reboot" is visible in the Debug menu.
- Error will appear after heating up of the xtal. HISTORY:
23-03-'06: Chassis added. Text updated. yassur
Posted on Jun 17, 2008
Phillips ssb
It is pretty much a plug and play. It is more time consuming than any degree of difficulty.
You must make a strong mental note of where each screw goes.
Simply disconnect the Molex connectors and the screws on the Signal Board; you're pretty much reverse the process. No cutting or soldering is required!
Dec 08, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Part # referring to
the ssb is located on bottom middle when looking at back of tv with back cover off. has inputs and tuner on it. part number is 313926727671 and is buyable through vancebaldwin.com. when replacing a small signal board and you don't have picture you need to enter 062598 menu (diversity code which is 3 digit numeric code located on option code sticker on panle itself). hope this helps dan
Aug 22, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Philips 42PF5321D/37 Error Codes
replacing ssb for 4 blink error was correct as error is communication failure specific to micro processor on ssb. getting an alternate error after replacing ssb would suggest either wrong ssb or defective ssb. verify vendor number on ssb tuner on original and new ssb and if same reorder that board and if not order per original board
Jun 30, 2008 | Philips 42PF9630A 42 in. Plasma Television
42PF7320A/37
i wont e mail to sent pdf doc
Jun 21, 2008 | Philips 42PF9630A 42 in. Plasma Television
42PF7320A/37
REMARKS:
HISTORY:
Jun 13, 2008 | Philips 42PF9630A 42 in. Plasma Television
Philips 42PF7320A blinks 3 times every time i hit the power button
The SSB is small self contained board that u connect your Antenna, and HDMI to. An error three is a communication error between the SSB and to Logic board ( located underneath the SSB on the back fo the plasma panel that is just below the power supply. U can check parts.com and see if u want to purchase a SSB for this TV. Is the 3blinking lights coming from the front of the TV. Also check the power supply and see how many times the green led blinks on the upper left of the power supply and let me know.
Apr 24, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
PHILIPS PALSMA TV SSB BOARD
I was unable to locate the part number 310432838731. The SSB board for model 42PF7320A is located below.
Philips 42PF7320A Replacement Small Signal Board
Apr 14, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Philips 37pf9631d/37
Alright,
6 flashes is viper not starting up the failure will be in one of two places. You could have a bad power supply all of the voltages would need to be tested on this board to rule it out. Especially checking the 5 volt lines coming off of it. If the power supply checks out you would be looking a a defective viper on you small signal board. Power supply will cost about 200 dollars SSB on the other hand is about 1000 dollars.
Hope this doesn't ruin your weekend.
Josh
Feb 08, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Philips 42PF7320A/37 won't power up Led blinks 7 times
This what to do measure from the logic board which is located under the small signal board and have the AV jacks connected to it. If the voltage is 3.1 or close the problem is with the power supply or a boar connected to the power supply. Unplug the set. Disconnect the Y main board first that will be on the left side of the set facing the back. Plug the set back in if the led is solid replace the Y main and the Y upper lower. If still blinking plug the Y main back in and unplug the X main which is on the right side facing the back. If the led is green replace the X main. If the led is still blinking replace the power supply.
But if the volts are 0 the problem is the SSB or the logic board. In that case take the (SSB) small signal board out the set and place 1 jumper on J8003 and another jumper J8004 of the left side of the power supply. Then place 1 jumper on CN2072 of the lower left part of the logic board. Plug the set back in if the set displays a white, blue ect screen replace the SSB. If not and on the logic board you don't have 1 solid blue led and 1 blinking led data is not flowing and change the logic board.
Dec 13, 2007 | Philips 42PF7320 42 in. EDTV-Ready Plasma...
Philips 42PF9630A 42 in. Plasma Television Logo
189 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
