Question about Sony MDX-CA680X MiniDisc Player
I lost may mdx-ca680 conecctor. Does anyone have the drawing of the back pannel of the unit so I can take out the cables fron inside of the main board, but I need to know the cable´s possition on the connector to do it, or at least tellme whwer I can find it through the net. Thank.
  • 10,594 Answers
Click Sony Support link to download installation manual copy that has all necessary info about connection jack/ connection setup at rear of MDX-CA680
Hope this will help you.
Thanks.
Posted on Nov 06, 2010
Computer wont accept gps
Try other mini usb cable,restart pc try other usb port and check conecctor on your unit.
Sep 24, 2014 | Tomtom One XL GPS Receiver
How to change rear main engine seal on acura mdx 2001
http://www.mdxers.org/forums/73-2001-2006-acura-mdx/47786-mdx-transmission-rear-main-seal-diy-tutorial.html
Jul 31, 2014 | 2001 Acura MDX
Problems with the HFL in the acura MDX
Super easy to fix yourself. Sit in y our backseat and pull as hard as you can on the air cond controls. Pull it straight back and hard enough to make you think it could break - it won't. You'll see the top pops off easily and the bottom needs a little coaxing, just keep pulling it straight back and massage it when it needs it. Once you get that off, there is a little black box right there with a bluetooth symbol on it. The cable is really easy to remove, if you have to use force, you're doing it wrong. There is a little pressure button on the cable that will release it from the unit. That unit is what needs replacing; this is a common problem among MDX's, apparently. Anyway, you can get this part on ebay by searching for "07-11 Acura MDX HFL" without the quotes. They run about $140, it looks like.
Jun 06, 2012 | 2007 Acura MDX
Unit not running, no lights on pannel but lights work inside.
Could be a control board issue, a broken wire somewhere, maybe the plug came off of the board. Try to unplug the refrig and plug it back in....A lot of times that will reset the board
Sep 13, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
2002 Acura MDX door lock fuse blows
It sounds like the circuit has a short in it somewhere. You can check for grounding with the same tester your used to measure the amp draw. Connect the tester and put it on continuity, this should sound an alarm when a closed circuit is detected. Move the harness around to see if it goes off.
May 07, 2009 | 2005 Acura MDX
Acura MDX Navigation system is intermittent. Need to remove it to send to Alpine for repair. Can't find instructions.
its really easey to remove the dvd unit under the pasenger seat. just put the seat all the way forward and pull the plastic guard from the seat track (pull straight back) then unplug the harness connectors in the back of the unit.
Then put the seat all the way back and remove the 1o mm nuts on the side brackets of the unit and pull it forward.
Jan 20, 2009 | 2005 Acura MDX
Where to hookup front panel (PIII-3754LMR - )
Hello!
In this image USB connectors for a fron pannel header are marked as Q and R, and the audio connector for a fron pannel is marked U
Hope this helps!
Sep 30, 2008 | Computers & Internet
NO sound from my sony mdx-c8200
I had the same problem before with the same unit, and I found that the problem was only the recording format, you have to record your MDs in SP mode, this is because, the mdx-c8200 is a non MDLP MD compatible unit. So, if you want to listen your MDs on your mdx-c8200 just don t record em in LP mode, just SP mode.
Mar 14, 2008 | Sony MDX-CA580 MiniDisc Player
Aiwa CDC-MA01 can't change station
same thing, some of the buttons on the bottom flip panel work, the important ones do not. select is the most important one that does not function. I opened the unit up and checked all the connections, the ribbon cable seemed to be connecting, i can only conclude it is chip thing, as the switches under buttons rang the bell on my continuity tester. it is very easy to open up and put back to together.
Oct 15, 2006 | Aiwa CDC-MA01 CD Player
Sony MDX-CA680X MiniDisc Player Logo
104 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
