Question about Durabrand DWT1304 13" TV
How to change the tv mode. Its on AV mode and i want to change it back to TV mode
    Top Expert:
  • Durabrand Master
  • 76,001 Answers
Hello
You can set the Game mode and External input mode at the same time by pressing the GAME button on the remote control. "GAME" appears on the TV screen. To exit the the Game mode and the external input mode, press the GAME button on the remote control again. To cancel GAME mode only, adjust the PICTURE control. The game mode will be set ot 'OFF" automatically. In this case "VIDEO" instead of "GAME" appeares on the TV screen. When you press the GAME button if the TV is off, the TV turns ON and will be in the GAME mode and external input mode automatically.
Posted on Nov 06, 2010
5 Suggested Answers
  • 3 Answers
SOURCE: tv is in AV mode
you would need to purchace a universal control you can find these in shop like currys ask the teqs there or look on ebay for a remote like your old one
Posted on Dec 28, 2007
  • 7 Answers
SOURCE: lost remote
Fairly easy and resourceful fix for this. Spent the past hour on the net looking, and no one had any info. So, we post here!
Our remote was lost, and were in the same unable to use the input port situation on our Durabrand BH1304D. Tried 3 universal remotes with no luck. However--- we are back in business now, Houston!
My fix-- grab a DirectTV remote (we had a white one-- RC 32 is the model). It's compatible with this 13" Durabrand TV, and most people a neighbor probably have one!
To program it to the TV (at least in our case), you have to slide the top switch to TV, then hold and press MUTE and SELECT until the green light flashes twice under the TV switch. Then press numbers 11034 and the light should flash twice again. Ta-da! Should be in business. We were!
The input button also worked as is, no need for the other step listed in the remote manual. But if your TV is changing channels and volume, but no input button, quick easy fix there too apparently. Didn't have to use it, but the input button can be activated or deactivated as needed. Simply hld SELECT and MUTE down again, the hit 960 on the keypad. That should be the activate/deactivate code per the manual.
Hope this helps someone, as the durabrand remote situation stinks, but thanks to the power of internet and users like us, there's now a solution in your reach! :)
Steve
karaokestl.com
Posted on Feb 02, 2008
SOURCE: An old zenith tv
TV HAS SOUND BUT NO PICTURE
Posted on Aug 06, 2008
  • 5 Answers
SOURCE: TV/av mode
no there isnt u have to get a new remote. The GE remote is cheap and the code is 0157. its the only code for that remote that works properly
Posted on Mar 09, 2009
How to switch back to TV mode from DVD
Use the remote controls' TV/AV button, or input select button; to select the inputs. http://electronicshelponline.blogspot.com/
Sep 17, 2014 | Proscan Televison & Video
Can not change my toshiba remote back to dish mode how do i do it?
The TV have been changed to program 12. Press the TV/AV button to come back to AV.
Jul 13, 2014 | Toshiba 26HF84 26" TV
How to change pc mode of sharp into tv mode
Use the input selector to change back to TV. Usually the first input on the list.
Jun 26, 2014 | Sharp LC-32SB24U 32 in. LCD TV
I have a calypso flat panel TV every time i switch it off and turnedit back on it comeson in AV mode with out me switching it from TV to AV,then i have to always go to the menue and put it bact into TV...
If you have something plugged in the AV, try unplugging that, and then switching on off etc tests. If that works and solves the problem, then the TV is sensing whatever is in the AV input, and thinks you want to use that first.
I'm not at all sure you can change this, except by making sure the thing in the AV input is either totally turned off, or unplugging it. I hope I'm wrong about this part, and if so it'll be clearly stated in the user guide some place about how to disable this auto-selection.
I hope this helps find the cause of your problem.
Dec 17, 2013 | Televison & Video
How do I change tv/video mode
take remote look for tv/av or a button with an in bound arrow with a square and press u will see av 1 av 2 according to the source say dvd u accessed on the back of tv u are good to go
Jul 14, 2013 | Samsung Televison & Video
No remote need tv in av mode
While ur TV is connected to d AV device which must also be on, run a frequency scan and all available channels including ur AV channel will be detected and saved. After d scan, u can manually change channels to ur AV choice.
Jun 06, 2013 | Televison & Video
TV to AV mode
you can press the tv/av button at the tv front panel button or through the remote controller.
Dec 24, 2012 | GE 27GT619 27" TV
How can I go to av mode without remote control in samsung hitron tv
Yes, you change your channel to '00' or go up to '101' and then press up button on tv then it will automatically comes to '00'
Nov 08, 2012 | Samsung Televison & Video
I used to be able to change picture mode (dynamic fixed) (standard) etc.. but now stuck on standard. I have lost the picture mode option and can't get it back to the brighter richer (dynamic fixed mode). ...
Go in the tv menu,right at bat u in the Picture mode go down the menu to reset push it.The Tuner board will reset it self.It will be set on the Dynantic fixed mode.And the AV mode button on the remote should able to changes back and fourth again Dynamic fix mode,Dynamic mode,Standard mode,User mode,Game mode.Not able to changes by pushing the remote button AV mode to changes,than ur Tuner board have problems,not working properly.
Jun 09, 2010 | Sharp AQUOS LC-52XS1U-S LCD TV
How do I change the TV from video mode to TV mode without the remote control?
Look for a button named AV or Input or something of the like. Press the button to toggle between different video modes such as AV, TV, S-Video etc.,
Dec 03, 2009 | Sanyo DS31520 31" TV
Durabrand DWT1304 13" TV Logo
840 people viewed this question
Top Durabrand Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
