Question about Canon imageCLASS MF4150 All-In-One Laser Printer
Canon MF4150 Fax Problem
I just purchased Canon MF4150 two weeks ago. Last night, when I tried to received 3 pages documents. Canon MF4150 kept switch to copy mode. I couldn't figure out what happened. I have no problem fax it out. I set up "received only" on fax mode. it still not working. Very frustrated. Can anyone tell me what happened? Thanks.
  • 2 more comments
  • NYAnnie Jun 17, 2008
    It's not working. I tried to switch to fax/tel mode but this international fax just transfer to fax machine and blinking with data processing light on. It will disappear after few seconds. It just won't print out my fax. Does Canon imageClass MF4150 has problem with fax function? Will DSL filter affect my fax function? I can't seem to figure out what happen. It's brand new machine. Btw, I don't see any "auto receive" function in Canon imageClass MF4150.
  • Anonymous Jan 12, 2009
    I have switch the machine to fax mode for receiving fax. However, after few second it switched to copy mode automatically. After several tries, monitor showed Remove MP Paper and the error right light was on.
    I followed up by removing MP papers, the try started working for nothing.
  • Anonymous Apr 16, 2009
    same thing...says to remove the MP Paper...the received fax wont come through....
  • Anonymous Mar 30, 2014
    cant receive faxes
  • 197 Answers
On the settings, it needs to be set for a certain number of rings, and also on auto receive
Posted on Jun 16, 2008
We have a Canon Image Class MF3240 Copier/Fax/printer/scanner. We are receiving error A4-load proper paper. We are loading with 8 1/2 by 11 paper. What is this error telling me?
The problem is on the computer, not on the printer.
"A4" is a paper size, just like "Letter" and "Legal".
You probably have your software application, such as Excel, Word, etc., set to paper size = A4.
Do this in your program on the computer:
[File]
[Page Setup]
[Size] "8 1/2 x 11"
... and print your document again.
Mar 19, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
Canon mf4150 -- fax has a mind of its own?
Hi ...
The problem is with receive mode settings ... Following the below instructions and you can change the receive mode settings which will resolve the problem.
Setting the Receive Mode
  1. Press <Additional Functions>.
  2. Use <la.gif> or <ra.gif> to select [5 FAX SETTINGS], then press <OK>.
  3. Use <la.gif> or <ra.gif> to select [3 RX SETTINGS], then press <OK>.
  4. Use <la.gif> or <ra.gif> to select [3 RX MODE], then press <OK>.
  5. Use <la.gif> or <ra.gif> to select the desired receive mode, then press <OK>.
    round_note.gif - For [AnsMode], make sure an answering machine is connected to the machine. If [AnsMode], [FAX/TEL], or [DRPD] is selected, you can select some settings as below:
    [AnsMode]
    --- [AnsMode CHK TIME] (select time from 10 to 30 seconds for the answering machine to start playing outgoing message after receiving a call)
    --- [FAX DETECT TIME] (select the duration from 10 to 70 seconds for the fax to detect)
    [FAX/TEL]
    --- [RING START TIME] (select the time from 0 to 30 seconds for the phone to start ringing after receiving a call)
    --- [F/T RING TIME] (select the duration of ringing from 10 to 45 seconds)
    --- [F/T SWITCH ACTION] (select the action the machine will take after the ringing ends, Receive or Disconnect)
    [DRPD]
    --- [NORMAL RING]
    --- [DOUBLE RING]
    --- [SHORT-SHORT-LONG]
    --- [SHORT-LONG-SHORT]
    --- [OTHER RING TYPE]
  6. Press <Stop/Reset> to return to the standby display.
Jul 17, 2009 | Canon imageCLASS® MF4150 All-In-One Laser...
Fax won't fax
We have the same problem and the fax will send and receive only if the printer cord is pulled out of the back of the printer. I just keep the printer cord pulled out and put it back in only when I need to print a document from the comptuer.
Jan 13, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Fax recipt problems for Canon MF4150
My faxing not gothrough,what shold I do now?
Mf4150
Aug 29, 2008 | Canon imageCLASS MF4150 All-In-One Laser...
Canon image class MF4150 distinctive ring
How to Set the Receive Mode (MF4140/MF4150)
1. Press [Additional Functions]. 2. Use [Left cursor] or [Right cursor] to select [FAX SETTINGS], then press [OK]. 3. Use [Left cursor] or [Right cursor] to select [RX SETTINGS], then press [OK]. 4. Use [Left cursor] or [Right cursor] to select [RX MODE], then press [OK]. 5. Use [Left cursor] or [Right cursor] to select the receive mode, then press [OK]. [FaxOnly]: Answers all calls as faxes and disconnects voice calls. [AnsMode]: Receives faxes automatically and records voice messages. [NET SWITCH]: Distinguishes between fax and voice calls. [FaxTel]: Switches between fax and voice calls automatically. [MANUAL]: Does not answer any calls. You have to manually receive faxes. NOTE: a. For [FaxTel] or [MANUAL], make sure the optional handset or an external telephone is connected to the machine. b. For [AnsMode], make sure an answering machine is connected to the machine. c. The [NET SWITCH] mode is available for certain countries only and requires subscription to a network switch service. 6. Press [Stop/Reset] to return to the standby mode.
Aug 12, 2008 | Canon imageCLASS MF4150 All-In-One Laser...
Lexmark 8300 print/scan/fax
There are sensors in the document feeder that detect the width and length of the paper being copied or faxed. Try getting a can of compressed air and go nuts blowing all the dust out of the feeder, if you spray everything you can get to, you will probably blow clean the sensors. Just an educated guess.
Good luck,
Printdoctor
Jun 19, 2008 | Lexmark X8350 All-In-One InkJet Printer
I can only receive one page each time
Make sure that the paper size set on the machine matches the paper that you have in the cassette. Also make sure that the sender is not sending legal-size documents if you are using standard size paper.
Is the machine giving any type of error message or code when the error light comes on?
May 15, 2008 | Canon imageCLASS MF4150 All-In-One Laser...
Repeated Fax TX report printing
Solution #3 solved it for me. The report kept printing over and over, so I used the menus (roughly) mentioned in Soluton #3 by guest.
My problem was the printer was trying to print the TX Error Report with the image attached. That made the report too big for standard sized paper, so the machine kept telling me to check the paper size, and I'd hit 'OK', and that made the machine try to print the report again, for it continued to think it had not printed a complete report.
Here's what I did...
Go to: Fax Menu
Arrow right ( >) to Maintenance/Settings, hit, 'OK'
Arrow right to (>) to Device Settings, hit 'OK',
Fax Settings, hit 'OK',
Arrow down ( v ) to TX Settings, hit 'OK',
Arrow down ( v ) to TX Report, OK
Select 'Print error only', hit 'OK',
Attach TX image, Select 'NO', hit 'OK"
With the instruction to not attach the TX image, it will print out the error report without the TX image, the report will fit on the paper, and it will clear this problem.
Jan 22, 2008 | Canon PIXMA MP830 All-In-One InkJet...
MF4150 Printing all Black - pages covrerd in black
Yes. Exchange it while you can. It will more difficult after the first 30 days. Could be a toner cartridge not seated properly. Or could be a high voltage power supply.
Aug 10, 2007 | Canon imageCLASS® MF4150 All-In-One Laser...
Canon imageCLASS  MF4150 All-In-One Laser Printer Logo
1,087 people viewed this question
old marine
old marine
