Hi there, I pulled my air con filters out to clean them and have forgotton which way they go back. On 1 side under the mesh is a foam filter and on the other side there is a funny sort of pleated thing. I cant remember looking at the system which 1 goes on which side. Thanks Carlee
  • 4 Answers
Hi Carlee,
The first thing you need to do is figure out which way the air flows, if the filter goes in a return grille turn the pleated side away from you if the filter is in the indoor unit however the pleated side of the filter should be facing toward the top of the unit.
Posted on Nov 06, 2010
How do I correct a 4E error?
try unpluging for 15mins re try
Apr 27, 2015 | Samsung Washing Machines
Air filter how to clean it
My air con unit has a fine plastic mesh in a frame.
I simply remove it and place it in a sink and soak it through, then I use flowing water to dislodge any dust left, shake and leave to dry before returning it to the air con.
I guess if I were pedantic I should use some type of sterilising cleaning agent, but I've never bothered, and I haven't succumbed to legionnaires disease yet so it's all good.
Mar 13, 2015 | Filter Heating & Cooling
How to clean the air filter
If the filter is clogged would it quit working
Hi there! If the filter is clogged this will cause the vacuum to lose suction and possibly shut-off. Below are instructions to checking and cleaning your filters.
1. Remove the dirt cup. Twist off the dirt cup lid.
2. Remove the filter cartridge from dirt cup.
3. Separate the foam and cartridge filters. Wash foam filter under running. Allow 24 hours to air dry outside the vacuum.
4. Tap the excess dirt out of Hepa filter. Hepa filter may also be washed. Allow 24 hours to air dry.
5. Check the secondary filter by removing the filter cover from base. Rinse the foam filter under running water until it runs clear. Allow 24 hours to air dry.
6. The red baffle tube inside of the dirt cup is apart of the filtration of the vacuum and needs to be cleaned as well. Twist out the baffle tube by turning 1/4 turn clockwise. Remove any hair or debris wrapped around baffle tube. Baffle tube can be rinsed if needed. Allow to dry thoroughly.
If the filters are too dirty they may need to be replaced. With regular maintenance the filters should be replaced about once a year. Follow the links below to order replacement filters for your UH20020.
Primary Filter
Exhaust Foam Filter
Hope this helps!
Jun 12, 2014 | Hoover Nano Cyclonic Compact Bagless...
How to remove air filter on 2001 fxst
Remove the screw and air cleaner cover, remove the three TORX screws and the bracket from the filter element, gently pull both rubber breather tubes from the back of the element, remove the filter element and gasket, replace the filter element if damaged or if filter media cannot be adequately cleaned, gently pull the breather tubes from the breather bolts on the backplate, clean the filter element by washing the paper/wire mesh air filter element and the breather tubes in lukewarm water with a mild detergent, do not strike the filter element on a hard surface to dislodge dirt, allow the filter to either air dry or blow it dry from the inside with low pressure air. Do not use air cleaner filter oil on the Harley-Davidson paper/wire mesh air filter element. c. Hold the filter element up to a strong light source and if light is uniformly visible through the element, it is sufficiently clean.
May 09, 2014 | Harley Davidson FXST Softail Standard...
Tv is displaying to clean air filter, where is the air filter? How do you clean it? Does it have a reset?
Found on the net:
The Panasonic air filter is located BEHIND the removable Front Panel.....it pops off and you should see it located in a "screwed in" panel.
But, it MAY be located on the BACK or side.....LOOK for a Grille with a grey or black foam piece. IF you don't find it behind or beside the TV, then pull off the Front panel.
Now, those foam filters can be removed from the grille-plate to be washed......the best way to wash it is to PUSH the dust out of the filter by turning the Clean-side of the filter TOWARDs your water source (the faucet or the Much-preferred Kitchen Sprayer)....Now get that DUST OUT!
Once finished cleaning just shake all the water out of the foam panel. Snap it just like you're snapping somebody with a towel. Still Moist? Don't worry, the plenum on the TV is pretty long and "moisturized air" won't hurt the bulb......
Reassemble it......
And DO NOT let that filter go that long between Cleanings!! It EXTENDS the life of the bulb when maintained regularly.
Oct 12, 2010 | Panasonic PT-52LCX65 44" HDTV
How to change air filter for 2007 volkswagen jetta ,2.5
Hi, on the VW Jetta 2006 to 2009, the cabin filter is underneath the glove box so lay down on the floor and look under to see the 2 plastic screws. Access is gained by removing two plastic screws and gently pulling down a piece of foam insulation. Once the insulation is removed you can see the filter 8 inch long by 2 inch wide black plastic face plate. You must slide the face plate toward the passenger side door.
The face plate will now come off and the filter will still be inside and you will have to pull it down. Debris will come out onto the floor mat below. Insert the new cabin filter, put the face plate back up an slide toward he drivers side to lock in place. Replace the insulation, re-screw the 2 screws, and you're back in business with fresh air and clean hands besides!
Take care
Aug 10, 2010 | 2007 Volkswagen Jetta 2.5 Sedan
My DC25 Animal is making a howling, whistling noise. Primarily when turning off (winding down to shut off)
if it started after you cleaned the filters, it is because when you smack the filter that is in the ball like they tell you to, it pushes the gasket in so air can sneak past it. take it back out and pull the rubber gasket away from the filter so there is about 1/16-1/8" away all the way around, then put it back in. it will seal it and stop.
May 13, 2010 | Dyson DC25 All Floors Bagless Upright...
CLEAN THE AIR FILTER
Go to the following site to download a free PDF service manual. There are two manuals for your bike near the bottom of the Honda listings.
http://www.carlsalter.com/motorcycle-manuals.asp Most of the manuals are in English but some are not. There is no way to be sure without doing the download. You can always delete it if in a foreign language. The manual will help you maintain your bike.
May 21, 2009 | 2003 Honda XR 650 R
Pressure relief valve opens
Hi.
If the hose works ok then you have A blockage in the section of the machine that goes from the brush roller to the wastebin.
Just remove the soleplate under the machine & check all the airways working back to the wastebin. definately check removeable inspection ports you will probably find omething in them blocking the airway.
http://dysonmanuals.llc.nu/
Jun 25, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
Heating & Cooling Logo
60 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
