Question about Yamaha RX-V800 Receiver
No sound coming out of Center, left and right front speakers
We run our TV, DVD and cable sound through the receiver which has been working great until the other night it the sound stopped coming out the center, front right and left speakers. The sound will still come out of the back speakers. What could be the reason for this?
  • 243 Answers
Make sure you didnt turn off speaker set A on the reciever. cause from what i can tell from the manual you may have hit a button to turn them off. now on your reciever look below the power button on the unit itself. below that is a speaker A/B push the A button to make sure its on or the B depending how your speakers are rigged. if this isnt the problem let me know and i can help you with another solution -Nate
Posted on Jun 14, 2008
Yamaha RX-V365 Receiver when I hook up my center channel it is not audible at all. The R and L speakers work fine when they were located in the FRONT A and FRONT B terminals, but when I moved everything to...
With what signal did you try? Maybe your signal source (DVD/TV or radio) didn't contain any sounds for the center channel.
Go to the Setup menu, Speaker setup / Manual setup and find there item called "Test tone". It will output a test tone to each speaker individually (you will see on LCD which speaker is being tested at each moment). If you will hear a sound from the center now, there is no issue and center is working fine, just your source didn't contain any sound for the center.
If it doesn't work, then either you have faulty cable, faulty speaker or faulty center output of the receiver.
- Try connecting the center speaker to different output of receiver (this will test if speaker is OK).
- Try connecting working LEFT speaker to left output with CENTER cable (this will test if cable is OK).
- Try connecting working LEFT speaker with working cable to the CENTER output (this will test the output of receiver if OK - but use the Test Tone from Setup).
May 18, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
No sound from left fronts (A+B) in TV mode.
Just check the rca cables. Try wiggling the cables as well. If they are the plastic rca cables, they do to wear out quick.
If it is not the cables, than it is a shorted resistor in the channel sound output
Jun 17, 2009 | Yamaha HTR-5440 Receiver
7.1 speaker setup: no sound coming from right front/surr speakers
Solution to having no sound coming from certain speakers in a 7.1 speaker setup for TX-SR606 receiver when playing a DVD.
Review the cable setup for the DVD player since it was identified as the source of the problem. Best to unplug and plug in the cables to ensure they contact the back of the receiver's RCA jacks. Redo the microphone setup for Audyssey 2EQ calibration. A good chance that it is the cable that may have caused the malfunction and loss of sound from the speakers. The cables can come loose during setup and not plugged all the way to the back of the RCA jacks or a defective cable causing signal loss.
Apr 15, 2009 | Onkyo TX-SR606 Receiver
5.1 Surround Sound Cutting Out
Yes you are right man, this problem occurs only with the cable problem, i can explain you, if there is a receiver problem means you won't get the sound its dam sure,
only if there is a cable problem you will get some noise or sound cut off with the speakers, so you please check the cables properly it will be alright.
Mar 26, 2009 | GE GTD120 System
No sound out of right main when watching DVR/TV or VHS
When watching TV or VHS the sound should be stereo and therefor come out of the the 2 front speakers. I suspect you now have sound out of the left front and the center speaker which indicates you connected the center speaker to the right front speakerterminal and the right front to the center terminal.
Just check if all speakers are connected to the correspondent speakerterminal.
If this is correct and the problem persists, try to connect another speaker to the right front terminal to see of the terminal or speaker is not working properly. If another speaker does work on the same connection, your right speaker might be damaged which might not be heard when listening to 5.1 because of the surround sound.
Mar 15, 2009 | Yamaha RX-V663 Receiver
Audio output
I have the same issue if I connect my digial audio cable from the Yamaha receiver directly to the HDTV. But, I get all 6 speakers working when I connect the Yamaha receiver directly to the Comcast HD box (instead of TV).
Dec 11, 2008 | Yamaha HTR-5650 Receiver
1 front speaker and 1 surround speaker won't work on cable selection
theres probably a problem with the right channel cable or plug that connects the tv to the reciever, or the tv is set to mono audio.
May 17, 2008 | Yamaha HTR-6030 Receiver
No sound coming out of back speakers when watching DVDs
Make sure you have set blu ray player out put to bitstream,if you have set to pcm for hd master audio and dolby true you need to have a amp to decode this and hook up with a hdmi cable.If your amp has hdmi in and out but no high def audio you may still get multi channel audio.
Hope this helps.
Mar 06, 2008 | Yamaha HTR-5790 Receiver
Yamaha RX-V800 Receiver Logo
100 people viewed this question
Top Yamaha Audio Players & Recorders Experts
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
