Question about Bissell 8910 ProHeat Clear View Upright Vacuum
I need to know how to run it - Bissell 8910 ProHeat Clear View Upright Vacuum
  • 34 Answers
Http://dl.owneriq.net/8/8a856ed5-0977-47c7-9706-d31d579f4a11.pdf here you go ! Good luck...have fun...yeah right...lol
Posted on Nov 06, 2010
Toro Rack Vac won't run
there is a shortage in the wirering somewhere take it to guarantee vacuum and sewing center and they will fix it for little to know cost to you and you will not need a new vacuum cleaner
Mar 26, 2014 | Vacuums
Our dryer has been running longer than normal on cycles. It seems to dry just fine but at times it seems like the timer is not working. The dryer will just keep running for hours. Ideas on what I should...
Have you checked to see that the knob for the signal to ring is still set to "on"? I know I have accidentally pushed my own off & wondered the same thing as you are.
You may also have an excessive problem somewhere. Check your removable lint filter as it may have too much accumulation on it & is making your dryer run longer.
You should remove it after every few cycles and clean it anyway.
If you use dryer sheets in your dryer, you should also, actually wash that filter to remove any remaining residue from the dryer sheet. You won't see it, but you'll know it's there by running clear water over it, and if it doesn't go thru the screen easily, there's your film.
After taking such good care of your filter & lint traps, check your dryer exhaust, all the way out to the outside of your house. Sometimes a lot of lint gets stuck in there also.. It's important to remove this because any lint that's caught in there could easily start a fire.
If you try all of these things and your dryer is still running too long and your not hearing the signal, I would check to see if the signal is operating first.
Set your dryer to stop in 5 minutes, then watch it. If it keeps running & you don't hear the end of cycle bell, check to see if it's set to "on". If it is set to "on" yet not working, you may have to replace the part or call a service person.....Check to see if your timer is broken or not, too. The wheel could be loose & may only need tightening. Or you may need to call a service person.
This will depend on what part needs replacement, or how handy you are.
I hope this helps.
Mar 15, 2011 | Vacuums
Followed directions on filling water and solution tanks. When I use the cleaner the cleaning solution is not being dispensed.
The tubing is clogged, you need to take the tubing off and clean it out or some how force some hot water thru the tubing and clean it out. this happens when you don't run clean water thru thesystem after using the cleaning solution. The solution dries and hardens in the tube.
here is some other tips that should help you get it back up and running
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000001755.pdf
Let me know if this is what you need or if you need more assistance
Nov 19, 2010 | Bissell 8910 ProHeat Clear View Upright...
IRobot 560 does not return back to the charging station as it runs out of battery after 1/2 hr. of cleaning.
You need to put the charging station in an easily accessible area, since the roomba doesn't know where it is if it's in another room. The roomba needs to be quite close to it to be able to detect it. When its battery runs low the roomba will zigzag around at random until it detects the charging station.
Aug 23, 2010 | iRobot Roomba 560 Robotic Vacuum
My Dyson DC-17 Absolute Animal does not stay running after I push start button. It will only run if I hold the start button down all the time.
switches always fail on the dysons. its a pretty simple fix though. let me know if you need parts and/or instructions on repairing it.
Apr 12, 2010 | Dyson DC28 Animal Bagless Upright Vacuum
Hoover steamvac F5826-900 leaks from bottom wheni put tank on ple
You may need to replace the gasket.if that dont work replace the whole tank
Aug 01, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover hygiene full bag light is on but the bag is empty
hi,
theres other filters that may be dirty and need to be washed or replaced below or around the bag, study the owners manual for alternate filter locations, basically the machine isnt getting the airflow it needs and is letting you know. The hepa filter is the most expensive, try and run the vac without it and see if the light goes out. Its okay to run it without but I suggest vacumming then dusting, not the other way around..
replace it as soon as possible
J
Jul 11, 2008 | Hoover Vacuums
Bissell 8910 ProHeat Clear View Upright Vacuum Logo
22 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
