Question about Mackie MR5 MR5 Reference Monitor
A Mackie SR 40 solo light stays on along with the Rude light
  • Mackie Master
  • 5,603 Answers
Check for a defect on the solo switch. The rude lights when ANY solo is on. Sometimes the switches stick mechanically and don't fully come up.
Posted on Nov 06, 2010
I have a Mackie 406M Powered Mixer. can't get sound out of it anymore. all the input level set lights stays on. any suggestions
That sounds like the amp board died. Mackie parts can be hard to source, and Mackie is really slow to ship, so I suggest taking it to a Mackie authorized service center. Here's a link-
Contact Support Mackie
May 18, 2016 | Mackie Music
I have a Mackie ProFX22 and when I solo the "rude solo" LED turns on. I have checked every signal and none are soloed. Also only the left meter shows anything. What is causing the "rude solo"?
The "rude solo" wil only flash if something is soloed. You need to check again as there is STILL something soloed. The left meter is because that is showing the channel that is being soloed. Once you unsolo everything, the meters wil display full left and right as usual.
Apr 02, 2014 | Mackie Music
Solo and mute lights don't come on
They should come on/flash when the associated button is set.
Mar 05, 2014 | Behringer XENYX 2442FX Mixer
Mackie srm 350v2 speaker packed up
I believe there is an internal fuse in these which, according to a friend who has these, seems to blow occasionally for no apparent reason. He has also had to send two back for replacement and would not buy again, they seem to be inherently unreliable although they sound great.
Jan 02, 2013 | Mackie SRM350V2 POWERED SPEAKER
If I solo something, that level bleeds onto the Main. If everything is down, there is still some bleed over. Sub outs work fine, but then I lose the effects.
The channel solo does NOT kill the subs for the channel, so if you have the subs going to effects and back to the mains that path will still get to the mains appearing as bleed Here is the service manual for the CFX20 which is just more channels of yours.
http://elektrotanya.com/mackie_cfx20_sm.pdf/download.html
Scroll down to "get manual" and click to download. Ignore other download links which are for viewers, etc..
Jul 02, 2011 | Mackie CFX 16 mkII 16 Ch. Compact SR Mixer...
I have a Mackie d8b, not getting any signal no matter what we try.
This is vague,,, there are so many outputs, knobs, LED's that I suspect you have not tried the right combination. I have no idea what your signal sources are... mics... tape... etc.
To start, turn the trim control of one channel that you have a signal source connected. Set all the EQ controls and the pan CONTROLS TO 12 O'CLOCK.
Check that you can trigger the clip light with high level of input. Press the solo button for that channel and using a set of headphones listen for any signal... turn the headphone level up and the slider for that channel...
First do your basic checks,,, try EACH mute button and see the LED light... try each solo button and see that each will light AND also that ANY solo light will cause the RUDE solo light to come on...
Dec 09, 2010 | Mackie 1604 Vlz3 16 Channel Mixer
Took apart and cleaned all my ribbon cable connectors (all off at once). Also took off and cleaned and reseated all molex connectors. Now back together but....solo light on all channels is lit with nothing...
A few questions first:
1) Does this effect the functioning of the "solo" at all? (ie is the light on always but without effect and can you select solo using the pushbutton?) We need to determine whether or not the problem is a funcitonal one or just the indicators being lit when they shouldn't be.
2) Are there any other symptoms at all? Any other lights effected at all or any functions not working as expected?
I will look up the prints for this, but I need to narrow down the search a bit. Gaining access to the board is not quick as all of the knobs need to be removed and all of the control nuts removed as well. If we can narrow this down a bit, you may be able to avoid that.
Please post up the info requested and I'll pull up the prints.
Thanks,
Dan
Nov 07, 2010 | Mackie 1604 Vlz3 16 Channel Mixer
Behringer XENYX 2442FX Mixer. The power light does not come on, The +48V does come on. The solo light blinks Constancy. No sound. I checked the fuses, they seem to be OK. any ideas on what wrong
You have likely lost one, probably the +15 volt power supply... This is possibly a shorted component or a short on the circuit board causing this. It takes some skills at troubleshooting to find this. Sometimes using a thermal imaging camera will show hot spot... other times you have to search with a millivoltmeter. The rude solo light is driven by an op amp that uses both polarities of 15 volts and to turn it on it pulls negative... Hence I suspect the +15 is missing.
Nov 05, 2010 | Behringer XENYX 2442FX Mixer
The "rude muting" light is blinking
That means that one or more of the "SOLO" buttons are down. This is the funtion that sends ONLY the SOLO selected mix to the headphone jack.
Jun 23, 2010 | Mackie 1604 Vlz3 16 Channel Mixer
Can't get sound out of the main outs just the solo out I using a mackie 1604 mixer bought back in late 1990's about 1995
Here is the manual if you don't have one:http://www.mackie.com/pdf/archive/cr1604_om.pdf. There are solo buttons for each channel. There is also an auxiliary return solo button. There is also a solo to main button. These buttons are all inter related. Is your main output mute button in or out? Read the manual carefully as there are a myriad of combinations you can use. Have a look at the trouble shooting guide on page 21. If you can't find a solution try contacting Mackie. Let me know if this helps.
Jan 25, 2010 | Mackie 1604 Vlz3 16 Channel Mixer
Mackie MR5 MR5 Reference Monitor Logo
169 people viewed this question
Top Mackie Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Lawrence Nentwig
Lawrence Nentwig
Level 1 Expert
Are you a Mackie Music Expert? Answer questions, earn points and help others
