Question about Blitzz Technology BWA711 (B3WL000900) Wireless Router
Reconfigure router I've had a motorola router and modem for few years. I was trying to secure my network and doing so I changed some settings on my computer and things went down the hill from there and ended up doing a complete recovery on my computer. Now the computer does not pick up the network and when I called Toshiba they told me I needed to reconfigure my router. Same problem with other 2 computers in the house, neither one will pick up the signal.How do i reconfigure? need to reconfigure router. computer died...cardiac arrest. had to pull the plug. how do i reconfigure with wireless laptops x 3?
  • 106 Answers
I seriously can't stand those motorola routers specially since they have to reboot themselves after every change.
Unplug the power from the router, hold the reset button in and plug the power back. Keep holding the reset button for 30 seconds. That should restore it back to factory settings. Plug one machine to the router and try to access the admin console. if memory serves me correctly, the user name is admin and password is motorola.
Posted on Jun 15, 2008
I need to use my telstra thomson TG782T modem on a different network how do i reconfigure it??
You need to contact your 3rd party service provider for the configuration settings for their network.
If you cannot change the settings on the Thomson modem then maybe the firmware is set to Telstra's network and cannot be changed. In this case you need to use the recommended modem suggested by your 3rd party service provider.
Apr 20, 2013 | Computers & Internet
How did my linksys router's ssid change when i got a new modem
I haven't a clue? Reset the device to default settings and reconfigure. Use this procedure, if you need it, to reconfigure, update the firmware if applicable: http://support.linksys.com/en-us/support/routers/WRT54G AND this: http://www.columbia.edu/acis/networks/aptnet/linksys/
Apr 01, 2013 | Linksys Wireless-G WRT54G Router
Wireless security
I think you should upgrade the firmware on your router.
After upgrading the firmware reset the router and reconfigure it manually.
I will also suggest you to create a new wireless network and use security modem WPA.
Try to connect to the new wireless network and see if that works.
See linksys router setup
Watch : How to reset Linksys router.
Jan 25, 2012 | Linksys Wireless-G Broadband Router
How do you reconfigure when you change network provider? Can this be done remotely?
Since the network provider is change you need to reconfigure it back by running the setup disc for it to detect and setup with the new configuration settings for it.But if you're not aware about those settings you can contact your provider to get the needed settings for it.
Apr 05, 2011 | NetGear RangeMax Next Wireless ADSL2+...
I want to make sure my wireless signal is secure. How do I do this?
I assume that you have a wireless router that is connected to your Motorola cable-modem.
Connect to the web-server "inside" the router, and configure the wireless network:
* set an SSID -- the "name" for your network
* set an encryption-level -- use 'WPA' or 'WPA2'
* set a password for your network
Now, your wireless communications between your computer and your router will be encrypted, i.e., "secure".
Also, having a password keeps other computers out, if their owners do not know the password.
Mar 16, 2011 | Arris SURFboard SB5120 Modem
Mdeschamps@comcast.netI have a Motorola router WR850G All connections are ok router front lights ok power on modem flicking green wireless flickling green network flicking green the security was changed a...
TRY RESETING THE ROUTER. BUTTON AT BACK IT IS A LITTLE HOLE
WHAT KIND OF WINDOWS (OPERATION SYSTEM YOU HAVE)?
DID YOU CAN RESTORE YOUR COMPUTER TO A DATE IT WAS WORKING TO GOT THE WORKING SETTINGS OR POST YOU OPERATION SYSTEM TO CHANGE THE SETTINGS
Feb 17, 2011 | Arris WR850GP Router
I dont know the key
You will need to check the wireless settings of the router .
Is there any computer connected to the router with the Ethernet cable?
If not then connect 1 computer to the router and open the router set up page. Once you open the router set up page, you will be able to find the wireless network key.
Use that password to connect to the wireless network
Click Here for step by step Instructions on how to find the network key
Dec 26, 2009 | Arris SURFboard SBG900 Wireless Router...
Motorola SBG900 Assign network address to computer
I guess your modem router was already configured well since it worked already previously. It seems that your motorola router is set to broadcast dynamic IPs (DHCP enabled) and your last connected Pc and laptop were configured with static IP. Please check your "network connection" setting and make sure it is set to "Obtain IP automatically"
Reagrds!
Jun 30, 2009 | Arris SURFboard SBG900 Wireless Router...
Modem router
I can tell that your network topology is not the most complicated ever.So u ve got 3 terminals,1 desktop pc and 2 laptop.Simple,reset your zyxel(from the button on the back) and reconfigure the Local area interface connection(ip & subnet mask for the zyxel),reconfigure your internet connection,(WAN zyxel interface) in case the zyxel is your Internet gateway too.Third,make sure NAT & Firewall are up and running(usually are by default) Finally,reconfigure the WiFi interface with the correct SSID name & WEP key or whatever security you prefer.Write down the security pass for your wireless and you are done.Good Luck.
Apr 19, 2008 | Zyxel Prestige 660H Router
Reconfigure router
Changing settings on your computer does not affect your router, but since the other computers cannot pick up the signal, then there is something wrong here.. See if there is a reset button on the Motorola and press it for 30 seconds to see if the router resets to its original configuration. If not, then you need to hardwire your computer to the router and get into the config page. usually, to do this, you just open up a browser and in the address line, type in the Default Gateway Address (usually this is 192.168.1.1).
To find the DG for your LAN:
Start > Run > cmd (ok)
From the Command Shell type:
ipconfig /all > ip.txt
notepad ip.txt
This should open a window with all your IP information in it. you will find a line called Default Gateway.. this is the address (probably 192.168.x.x) that you put in your Browser Window Address Line to access the configuration page of the router..
Dec 04, 2007 | Arris SURFboard SBG900 Wireless Router...
Blitzz Technology BWA711 (B3WL000900) Wireless Router Logo
97 people viewed this question
Top Blitzz Technology Computers & Internet Experts
Michael Galve
Michael Galve
fred capra
fred capra
Are you a Blitzz Technology Computer and Internet Expert? Answer questions, earn points and help others
