This is going to be a bit long winded so please bear with me\ System mobo: nforce 5m-a gpu gforce 7200 psu generic 450w cpu amd 64x2 4200 Ram generic 1gb onboard sound Ok I hit the power button No lights or beeps the fans start and no post or anything. I let it run like that a few (5) minutes and reboot,,,sometimes I get a hd l.e.d flash or two (fans start up too). I let it run another 5 mins reboot and the power on l.e.d comes on and I get several flashes from the hd led ...no post If i push the reset button sometimes it will boot up ok after that sometimes it is a lost cause...once it boots machine runs fine. Here's what I have done to it so far tried a working power supply from another machine and same results,,,removed ,cleaned and reseated gpu and ram(machine started ok twice after this step) I tried the gpu and ram in another machine and it ran fine... So please any and all suggestions will be appreciated and thanks for reading this....Jerry
  • threetyme626 Nov 06, 2010
    knindza22
    Thanks for the reply... I went into it and reseated everything left the hd and dvd burner unplugged to see if I could get a post..no lights beeps or anything ... no power light , no video at all but the fans were running...I let it run 5 mins or so and rebooted it and got a power on light but that was it...plugged everything back in and nothing but fans turning...I am begining to believe its the mobo....Any more ideas would be great to try~Jer
  • 345 Answers
This sounds like an OS issue. Like some component is corrupted. I would try to boot in to safe mode and see what happens. If it works in safe mode than i would say it is some kinda software or driver issue. Might even be antivirus software. If you cant boot in to safe mode, have you tired to reload windows. If this is not possible because pc wont run long enough in safe mode or allow to start system reinstall i would remove all components like cd/dvd rom. just unplug the power and ide/sata cable. Re-seat Hard Drive cable(power and connection) remove all external devices like usb keyboard and mouse, printer and what ever else you have. I would also try to remove cmos battery for 1 minute just to reset it. Hope this helps.
Posted on Nov 06, 2010
Testimonial: "knindza22 The problem I am having is getting it to post the bios message or any video.The power and hd lights not comin on is weird too"
  • Mihajlo Jerkovic Nov 06, 2010
    Since you have said power supply from another machine if doing same on this machine i would agree that it looks like motherboard is not providing power properly somehow. I doubt it is a cable issue. I mean you can try different power(one of the other power cables that come from power supply) and ide/sata cables but that would be really unusual. Sorry i dont have any other ideas.
I rebuilt computer with new parts, now won't start up. No POST. Power LED lights up, no cpu fans spin, no beeps. Psu works with paper clip test. New mobo, ram, psu, cpu.
Check display without cabinet maybe motherboard getting short with cabinet and try new Power supply check all the power supply connectors connected or not .
Nov 14, 2016 | Computers & Internet
Computer shuts down on its own. First it starting
Could be HArd disk drive issue or Windows OS issue, try repair windows operating system before you change your hard disk drive , good luck
Aug 07, 2013 | Computers & Internet
CPU fan & PSU fan working but No display coming to the screen
There should be some sort of beeps then. No beeps is an indication the CPU or RAM is not seated properly. You need to refer to board manual if there are beeps.
There is also the matter of... Never mind I just noticed the CPU is an 8 core CPU, but the board supports quad core.
Board specs
http://www.gigabyte.com/products/product-page.aspx?pid=3833#sp
CPU Specs
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103960
Double check my findings and go from there. Good Luck
Dec 11, 2012 | Gigabyte Technology gigabyte Ga-78lmt-USB3...
I want to know the graphic card slot in the motherboard ASUS M2N68-AM-SE2. Whether it supports DRR1, DDR2 OR DDR3.
Hi, you can see the list here:
http://www.asus.com/Motherboards/AMD_AM2Plus/M2N68AM/#specifications
At this site you also find drivers.
Remember to select your operating system
AMD Socket AM2+ / AM2 Processors
for AMD Phenom™ FX / Phenom / Athlon™ / Sempron™
AMD Cool 'n' Quiet™ Technology
AMD64 architecture enables simultaneous 32-bit and 64-bit computing
Support 45nm Phenom™ II CPU Chipset NVIDIA Geforce 7025/nForce 630a
System Bus 2000/1600 MT/s Memory 2 x240-pin DIMM, Max. 4 GB, DDR2 1066/800/667/533 ECC,Non-ECC,Un-buffered Memory
Dual Channel memory architecture
*DDR2 1066 is supported by AM2+ CPU only Expansion Slots 1 x PCIe x16
1 x PCIe x1
2 x PCI
Storage Southbridge
4 xSATA 3 Gb/s ports Support RAID 0,1,5,10,JBOD
ATAPI support ,AHCI mode
LAN RTL8211CL Phy Gigabit LAN Audio ALC662 High Definition Audio 6 -Channel CODEC
USB 10 USB 2.0 ports (4 on back I/O, 6 on board)
1 x PCIe x1
2 x PCI
Storage Southbridge
1 x PCIe x1
2 x PCI
Storage Southbridge
1 x PCI-E x16 Graphic card slot.
Aug 25, 2011 | ASUS M2N68-AM SE2 Motherboard
Id like to buy a msi nf725gtm-p31 mobo but am unsure if it supports am2 processors and ddr2 can u pls advice thanks
Here are the specs of the motherboard, both answers to your questions are "Yes". Happy purchase and have fun with it !
CPU
• Support socket AM2 for AMD® Athlon 64/Athlon 64X2 CPU / AM2+ for AMD® Phenom CPU / AM3 for AMD® Phenom II / Athlon II CPU . (95W only)
Please refer to CPU Support for compatible CPU; the above description is for reference only.
bult_ar_org.gifHyper Transport Bus
• HyperTransport 1.0 supporting speed up to 1000MT/s
bult_ar_org.gifChipset
NVIDIA® nForce 630a & GeForce 7025 chipset
bult_ar_org.gifMain Memory
• Supports Dual Channel DDR2 667/800
- 2 DDR2 DIMMs (240pin / 1.8V)
- Supports a maximum memory size up to 8GB.
bult_ar_org.gifSlots
• One PCI Express 1.0 x16 slot.
• One PCI Express 1.0 x1 slot.
• Two PCI slots (support 3.3v/5v PCI bus interface).
bult_ar_org.gifOn-Board IDE
• One IDE port by NVIDIA® nForce 630a & GeForce 7025 chipset
- Supports Ultra DMA 66/100/133 mode
- Supports PIO, Bus Master operation mode
- Can connect up to two IDE devices
bult_ar_org.gifOn-Board SATA
• Two SATA II ports by NVIDIA® nForce 630a & GeForce 7025 chipset
- Supports storage and data transfers at up to 3Gb/s
bult_ar_org.gifRAID Function
- SATA II 1~2 supports RAID 0, 1 mode by NVIDIA® nForce 630a & GeForce 7025 chipset
May 12, 2011 | Computers & Internet
After psu burned out , can't boot computer with
see your cpu fan connector, weather it is connected properly. to check wether psu is working properly, short the black n green wires present in the psu's mother board connetor by using a single strand wire, and switch on. if the fan rotates there is no probs with the the psu. then u will have to replace the motherboard
Sep 04, 2009 | Gigabyte Computers & Internet
Screen going blank for a second or two while video freezes then jumps.
If you have on board graphics try removing video card and reboot when computer rebooted turn it of and refit card and restart when restarted computer should recognize new hard ware and should find the already installed drivers if not try installing drivers again
Sometimes windows does not recognize new hardware until its refitted
had this problem with modems alot and the above method solved it
Jul 31, 2008 | ATI RADEON X1650 Graphic Card
Processor load on biostar m/b
IT seems no problem with your specification, but only one thing less in this criteria. What inch does your monitor? This must be match with the specification of your VGA Card, The more resolution you can get the best performance of this VGA card you can achieve, try to higher the resolution of your monitor , don't only use 1024 x 768 , but try another higher resolution. The VGA itself cannot reduce the system perfomance, because your vga card has GPU (This VGA card has his own processor and memory) just like mini computer inside your main computer.Hope this things can solve your problem, don't forget to vote
Jul 01, 2008 | Computers & Internet
Brand new motherboard wont start up
try taking 1 stick of ram off the motherboard, and boot up with 1 stick in slot 1 or 2.
You should get some beeps, 1 is system Ok.
3 is usually RAM/Graphics problems.
Also try booting with the motherboard setup disk in the CD Drive, it may be looking for files to initialise the Board.
And the obvious, check that all cabling is correct from mainboard to front panel. Power on/off Reset et,c.
View the user manual to see if the board has any jumper/dip switch settings for different configurations.
Mike @ compurepair.
Mar 14, 2008 | Computers & Internet
Computers & Internet Logo
94 people viewed this question
David Payne
David Payne
