Question about GE JE1660 Microwave Oven
GE JE1660GB002 microwave oven.\r\nReplaced magnatron & diode 4 months ago. Now the wire harness was starting to burn up creating smoke inside the mw. What is the cause of the wire harness problem?
  • 19 Answers
SOURCE: Ge Spacemaker microwave jvm240 wv Micro hood combo.
sounds to me like the magnatron has shorted out. i don't know of a way to test them unless you have some high dollar equipment. a continuity test prob wont tell you anything. what reading did you get on the cap when you tested it?
Posted on Jan 06, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: GE Spacemaker XL1400 Microwave works
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part (such as a shorted diode)
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
NOTE: There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jun 23, 2008
SOURCE: Ge jvm1650wb005
weve had our fixed before and it's the heating element $75-$100 to fix.
Posted on Sep 01, 2008
  • 13 Answers
SOURCE: ge microwave oven wall smelling wire burn!!!!
time to put it to rest
Posted on Jan 02, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: GE Microwave shuts off after running 3 seconds
It is a loose or bad magnetron emitting electrical interference that disrupts the control unit.
When you move the circuit board away from the magnetron or take the cover off, the interference is weakened, and the control unit works fine.
If it's within the mag warranty, G.E. should send you the magnetron to do it yourself. Call them at 888-239-6832 with your model, serial, and manufacturing date.
If nothing else, you can save about $50-75 if you remove it from the wall and take it to a GE-authorized servicer.
Posted on Mar 02, 2009
Our microwave quit HEATING this morning. What can
Could be the magnatron/thermal cut out seek pro advice
Apr 01, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Panasonic dimenion 4/ nna772sbbpq
you will have a failed magnatron, rectifier diodes to same, or a power supply fault.
Feb 14, 2008 | GE JES1851 Microwave Oven
My GE spacemaker microwave makes an awful sound and has smoke with a terrible smell coming out of the vents. The clock and everything seems to be okay. Can this be fixed:
might just be magnetron and diode and thats not to terrible cost wise but if the smoke is real heavy the transformer may be burned as well and its not worth it then. mag & diode price with labor should only be $150-180 and add on an extra $120 for transformer
Feb 04, 2010 | GE JVM1650 1000 Watts Microwave Oven
It wont heat anymore and the tray stopped turning a few months ago
Im sorry to hear you are having this trouble.
I believe you have a faulty door safety interlock switch. Please remove the cover and check the small micro switches with your ohm meter.
What frequently happens is this: because of opening the door during oven operation, the small points inside the switches arc and burn. Once they cannot make contact, they are not able to tell the oven the door is closed and when the door is not closed (forget what YOU think the door is doing) the oven will not turn on the magnatron. No magnatron, no heat.
Please let me know what happens
Thank you for posting your question on FixYa.com
a
Nov 08, 2009 | GE JVM1630 Microwave Oven
MICROWAVE WILL NOT HEAT
check the door safety switches ... remove the cabinet and check the micro switchs you find involving the door with a volt/ohm meter
Nov 03, 2009 | Hotpoint RVM1425 Microwave Oven
Wont heat food
It could be that the "grinding" noise was actually "arcing" taking place inside the cavity or uder the cover. The magnatron is possibly damaged or the h.v. diode. Should be repaired by qualified repairman
Sep 12, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave is arcing on the antenna blade.
Arcing is often the result of the cover over the magnatron (The thing that produces the microwaves) being aged, burned or damaged. If you look inside the oven, you will see a cover (usually square or round and around 3-5 inches across depending on the machine)made from a flakey silver plastic/fibre material. If this is burned or has a hole, it needs replacing and this will probably cure your problem.
Mar 13, 2009 | GE Microwave Ovens
GE spacemaker xl1800 and Pop tarts bad mix
it sound to me as if the high voltage diode is shorted. It could be inside the capacitor or out board the cap. The capactor could also be short but this is a rarity. Diodes are a cheep item . repace it and if it don't work its probably the magnatro. good luck.
May 13, 2008 | Microwave Ovens
Make noise like when some aluminium is inside.
The noise is coming from the high-voltage transformer being overloaded by something shorting it out. Either the magnatron or the high-voltage capacitor and diode. Replace the capacitor and diode then if still not working, replace the magnatron. Its only affordable if you do it yourself - buy the part on EBAY - lookup "universal magnatron"
Hope ya fix it!
Feb 08, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Micowave power
Hope ya fix it!
Feb 05, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE JE1660 Microwave Oven Logo
111 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
