Question about Belkin N Wireless Modem-Router F5D8633au4A
I set up my Belkin N Wireless Modem and it has been working fine. Except I did not install it with a "password" at the time of setup. How do I put in a password now. I cannot find a program in my program list?
Hi psheayn,
Kindy copy this steps in notepad and also copy the screen shot before u start doing it.
You can put up a wireless password manually b logging in to the router interface but you should be very careful because if you change any thing else it might be a messup your whole router so kindly do the following steps alone.
Step 1: Open the internet explorer
Step 2: Clear the address bar and just type the number alone which is 192.168.2.1
Step 3: You will get router screen as below
Step 4: In the left corner of the page under "Wireless" Security and select security mode as "64 bit WEP "
Step 5: Type any 2 numbers per box as u like and apply changes. Also make sure that you are gonna copy the password. If you want to connect any other computer in future you will need to have that password to connect.
Step 6: Under security in left side select "WPS or Wifi Protected Setup" and select WPS as disabled and apply changes. Dont worry it not related to security its just an option that has to be disabled if you enable the 64 bit WEP password.
Step 7: Then Connect wireless computer to the wireless network name and will ask for the password this time since password has been enabled. And ur router is gonna be a protected one and no one can hack it.
Step 8: In case if ur not able to connect to the network remove the preferred network and connect to it.
To remove preferred network
XP OS
Start -->control pannel --> Network and Internet connection-->Network connection --> Right click on Wireless network connection icon --> Select 2nd tab Wireless network --> Remove preferred network one by one.
Windows Vista/ Windows 7
Start -->control pannel --> Network and Internet connection -->Network and sharing center --> In the left side select Manage Wireless network and remove preferred network one by one.
Check out the screen shot to enable security on the Router and to disabled WPS
Posted on Nov 06, 2010
Need passwword for belkin wireless router
By default, Belkin routers do not have a password,just click on Submit to log in..But you should check check your Belkin router setup documents.
If you forgotten or lost router password cannot be recovered. It can only be reset by hard resetting the router.
Sep 11, 2012 | Belkin (F5D7230-4) Router (587009)
Can i connect belkin to belkin through dsl modem and how
Yes, you can connect:
DSL modem WAN/Internet port on Belkin #1
LAN/network port on Belkin #1 WAN/Internet port on Belkin #2
LAN/network port on Belkin #2 your computer
If the two Belkins are in different rooms, and there are more than one computer in the room with Belkin #2, it makes sense to run ONE (not MANY) Ethernet cables from Belkin #1 to Belkin #2.
Nov 19, 2010 | Belkin Basic Wireless Router
How to connect Belkin N N 300 Router to Cox Cable Modem step by step instructions. Cox just installed a new modem since the old one "went bad" and was giving a wrong "number". Was working fine before and...
Step 1 : Connect modem - Router - Computer ( Wired )
Step 2 : Open router setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left side under internet WAN click Connection Type
Step 4 : leave the Password Blank and click submit
Step 5 : Choose the connection type as dynamic and click next
Step 6 : Leave the Host name blank and click apply
Step 7 : On the left Under Internet WAN Click MAC Address
Step 8 : Click Clone and Click Apply changes
Step 9 : If the Internet status on the top right is connected
Step 10 : Then check if you have internet
Step 11 : if not Then unplug the Power Cable from the Modem And the Router
Step 12 : Plug the power Cord to the Modem
Step 13 : Wait till all the lights are on
Step 14 : Plug the power to the belkin
Step 15 : Check the color of the light in the belkin
Step 16 :If green then Check if you have internet
If not working then call belkin
================================================WIRELESS SETTING UP A WIRELESS CONNECTION
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Aug 30, 2010 | Belkin Wireless Play Router (F7D4302)
Security
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} How to quickly install and use your Belkin wireless G router 1. Step 1
Position your Belkin wireless G router.
Place your wireless G router in a wide open and central location. Don't connect the power plug into the router, yet. Make sure your computer is turned off.
2. Step 2
Connect all the devices.
Find the Ethernet cable that connects your PC to the modem. Unplug the Ethernet cable from your PC and insert it into the wireless G router's WAN port. You should have an additional Ethernet cable that came with your router. Take this cable and plug one end into one of the LAN ports on the router. Then connect the other end to your PC's Ethernet port.
3. Step 3
Turn on your modem, router, and PC.
Plug the power plug adapter into the modem. Turn on the modem. It'll take approximately 30 seconds for the modem to boot up. Connect the power plug adapter to the router and the other end into a power strip or outlet. Like the modem, it'll take about 30 seconds for the router to boot. Turn on your PC.
4. Step 4
Verify lights are on for your devices.
Make sure the following lights are on for your router: power, WAN, and LAN light. If you don't see any of them lit, confirm these devices are turned on. Make sure the Ethernet cable connections are installed correctly.
5. Step 5
Install and configure software.
Use the setup wizard application to configure your Belkin wireless G router. Set up features, such as creating your password and setting up your time zone. Continue to follow the setup wizard so you can configure  other settings.
Jul 23, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
I need to change the name of my Belkin Wireless (automatic) name and password. Can you walk me through this?
2. Step 2
3. Step 3
4. Step 4
5. Step 5
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Jul 01, 2010 | Computers & Internet
Belkin N Wireless Modem-Router F5D8633 drivers
Just hook it all up, and push and hold the reset button in the back of the router for 10 sec..
Then unplug your internet box, [cable/DSL box] and plug back in,
The internet box will send a IP to your router automaticly.
[If it dont work unplug power from both boxes, then back in but plug the internet box in first..]
done..
if your useing wireless this will not be setup with a password to join, and will be open to neighbors,,
If you want to go to the next step and setup a password to join, you can do this with out the cd also, but get it working first and hit me back
Sep 12, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Belkin N Wireless Router doesn't connect to Modem
If router is brand new you should have a set up disk. the set up disk will walk you through it or you might log onto Belkin site to see a walk through set up. If you can access internet from modem to router to internet. That means router is functioning properly. To go completely wireless you will need to secure your network and setup your access codes. Definitely use the setup disk to do this. A unsecured wireless network is a nightmare waiting to happen. Good luck
Sep 01, 2008 | Belkin Modem connector (R6G064-R-50)
Belkin N Wireless Modem-Router F5D8633au4A Logo
149 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
