Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
I have a D52W20 RCA tv. The picture will go out intermittently, but the sound is still on. When the picture goes out, sometimes you can see it faintly for a few seconds before it fades completely
  • j_rod_tech Nov 07, 2010
    Thank you, found a loose solder at #3 of a component I believe is called the oscillator.
  • RCA Master
  • 17,130 Answers
Possible errors in the main board , it can be due to failure of a solder joint in the set.
Remove the back panel and switch on the TV to work. when the fault appears then the main board can be tapped lightly to see if there is any switch on of the picture. If so the fault is confirmed and you must resolder the dry joints of the suspected areas.
Look carefully with a good lighting to check the joints specially the high voltage and the power circuits.
Some tips on these board issues: click on Board problems
Also check for Soldering tips
Posted on Nov 06, 2010
Tv pops on and off suddenly after viewing for about 10 to 15 mins. this problem becomes progressively worst after prolonged viewing. as of today there is absolutely no picture and or sound.
Your symptoms exactly match this scenario: a component involved in picture & sound was failing intermittently, then progressed to a hard failure.
My suspect: a power capacitor in the power supply. They sometimes fail this way - when the dielectric breaks down completely, then the power supply fails, causing no pic/sound.
Fix: replace power supply (or the specific capacitor, if you can determine which one died).
Oct 23, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a 52 in RCA Plasma TV and when I turn it on nothing comes on but just sometimes a green blank screen with no sound and sometimes power goes on and off. Ive hired an technician to look at it last...
The RCA D52W20 has three picture tubes the problem you describe is symptomatic of a shorted or a bad green tube. other problems could be bad crt boards. high voltage block, In the case of tube replacement i often suggest the cost of replacement is more than the set is worth. so i would suggest getting a second technicains opinion
Oct 20, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
TV picture went out.
power supply problem check capacitors...caution
high voltages..large capacitors retain nasty charge for a long time.........
Feb 24, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv picture goes off but still have sound.
Resolder all poor connections on power supply board and this should fix your problem.
Feb 09, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
My rca 52 inch hdtv turns itself off after a few minutes
Sounds like the green tube shorting intermittantly. Have a qualified tech use a tube restorer to check for shorts, or the loss of the 300v line to the green tube.
Aug 30, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
36 inch RCA tv loses picture and sound, but power stays on
Cable Looses signal power after 20m ... Install signal amplifier
https://youtu.be/AkiKf4G4UE0
May 04, 2017 | RCA 36V430T 36" TV
42" RCA Projection TV - Sound good, but Picture goes out intermittently.
resolder the vertical output IC . bad solder there can make the CRTs blank for protection and you will lose the picture when the vertical drops out.
Mar 27, 2008 | Televison & Video
RCA D52W20 cold start issue?
i am looking for an owners manual for the d52w20, can anyone help me out here.
kimmipoo_2000@yahoo.com
Apr 04, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Sound Problems
this set has a int/ext switch on back..and audio ic inside
Sep 11, 2006 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
841 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
