Question about Brother Sewing Machines
My sewing machine does not feed material through automatically. What specific problem would cause this?
    Problem Solver:
  • 17 Answers
Your feeddogs are down or the pressure has been released on the foot. either problem sould be explained in the owners manual on how to reset either one.
Posted on Nov 06, 2010
Am having trouble with my husqvarna prisma 980 sewing machine withe mechanism that pushes the material further automatically as I am sewing.
The amount of pressure on the pressure foot can cause real problems. If you lower the pressure on the foot it is likely to work better. If this doesn't work try using another type of material. Some materials have problems because of being slippery or too thin. If this doesn't work check to see if the pressure foot is directly on top of the feed dogs. If it is it will need to be adjusted so that it isn't directly on top of the feed dogs.
Oct 19, 2016 | Husqvarna Sewing Machines
Does it feed.the.material by itself.automatically or do you have to do it
machines feed automatically
the bottom feed is by a set of jaws that rise up and move back then down and repeat the process back or forward according too the sewing direction required
mostly if it is not progressing the stitch it is because the feed direction is close to neutral position or in the middle of forward /back
Oct 10, 2016 | Sewing Machines
My feed dogs all of a sudden will not feed the material through. How can I fix it?
Please provide specific information regarding your Bernina model. The older "mechanicals" do require frequent oiling--not just at the hook, but throughout the machine. (When they made these old machines, they didn't really consider that the machines would still be going strong 20, 30, or even 50 years later.) Could be the oil surrounding the feed dogs has dried and is preventing the parts from moving.
2 527 Search results for Bernina oil sewing machine
If your Bernina is a newer computerized model, you should probably take it for service.
NOTE: The mechanical machines use a different oil than the computerized models. Be sure to get the correct oil for your machine.
Jul 14, 2016 | Bernina Sewing Machines
Why do my feed dogs grap my material at the beginning of a stitch
some sewing machines have what is called a buttonhole lever that
is to the left of the needle that has to be pulled down before the
machine will make a buttonhole,here is a link for a free manual
if you dont' have one
http://www.singerco.com/uploads/download/430_8280_es.pdf
Mar 18, 2013 | Singer 8280 Mechanical Sewing Machine
When i start sewing sometimes the material gets sucked down into the feeds dogs. this causes the thread and the material to make a mess i sometimes can not get the thread out i am making quilt pieces
Use a scrap of fabric under the pressure foot as a leader and feed the quilt square after it clears just like if you are chain sewing. After you have sewn the square clip the scrap off and use it again.
Feb 09, 2013 | Brother LS-1217 Mechanical Sewing Machine
Machine won't feed material. I have to pull while sewing.
First of all stop pulling that will only bend your needle and cause further problems.
Check to make sure your feed dogs are engaged. There should be a switch somewhere around the sewing area front or back or perhaps under a flat bed attachment.
Oct 28, 2012 | Singer 4423 Sewing Machine
Can the consew 339rb-1 be used only with 1 needle?
this is the specifications for the 339rb-3. they sould be close to yours, if you can put two seperate needles in and the machine hase one hook and bobbin case then I would say you can use one needle, if you have two hooks and bobbins, I would say no, you may want to thread with one and just hand turn for a few stiches to sew hoe it reacts, leave the bobbin door open so you can watch the hook.
Specifications
  • Two needle mechanism readily makes two parallel lines of stitches
  • Compound feed, walking foot mechanism insures even feeding of material
  • Large hooks and bobbins assures longer operation between bobbin changes
  • Centra-Lube® semi-automatic lubrication system
  • Automatic hook lubrication
  • Oil fed take-up
  • Simple adjustment permits raising and lowering of the center foot which allows for sewing different thickness of material
  • Safety clutch protects the hooks from being damaged
  • Various needle gauges available
  • For sewing light to heavy-weight materials such as leather, vinyl, upholstery, synthetics, canvas, vinyl and various coated and laminated products
  • Designed for stitching such products as auto, boat and furniture upholstery, tarpaulins, covers, sails, tents, camping trailer covers, awnings, umbrellas, tops, bags, luggage, handbags, travel ware accessories, sports and camping equipment, wearing apparel, outdoor clothing, canvas shoes, slippers, orthopedic appliances, etc.
  • Suitable for double needle seaming, binding, taping and piping operations
Aug 27, 2009 | Consew 339RB-3 Sewing Machine
Can't get the material to feed automatically
The teeth on your feed may be clogged with lint... follow instructions in the manual to remove the cover and clean out the lint...has the machine been oiled??
Aug 04, 2009 | Simplicity Serge Pro SW432 Mechanical...
Are feed dogs supposed to be up or down w/ embriodery unit?
The embroidery carriage automatically lowers the feed dogs when put in place
Dec 01, 2008 | Brother SE-270D Computerized Sewing...
Material not feeding automatically
you have to lift the presser foot and guide it through or pull it through slow - i knw no other way around this unless you have an industry type machine
Oct 22, 2008 | Singer 7442 Mechanical Sewing Machine
Sewing Machines Logo
47 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
