Question about Iomega 1TB Desktop USB 2.0 Hard Drive
My PC cannot see the hard drive - Iomega 1TB Desktop USB 2.0 Hard Drive
    Brigadier General:
  • 10,406 Answers
The external storage device has several major components:
* USB cable
* external power-supply
* disk-drive inside the enclosure
* USB-to-disk-drive adapter inside the enclosure.
Try a different USB cable.
Try a different USB port on your computer.
Try a USB port on a different computer.
Take a multi-meter, and measure the output voltage/amperage of the power-supply,
and compare with the specifications on the label of the power-supply.
Open the enclosure, and remove the disk-drive, and attach it as a "slave" drive in a desktop computer, to see if bypassing the USB-to-disk-drive adapter bypasses the problem.
Look at the label on the disk-drive, for manufacturer, product-number, serial-number, and manufacture date. Access the manufacturer's web-site, and use "check warranty status" to see if the warranty still is valid. If so, the drive can be replaced, at minimal cost to you.
Buy a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Search online for a professional "data recovery service". For a significant fee, they can repair your disk-drive, just long-enough to copy your files to a new disk-drive.
Posted on Nov 06, 2010
Eee pc 1025c hard drive not detected
If you have another hard drive check to see if it is the hard drive if the other hard drive detects in the bios then it is your hard drive if not it is your sata or IDE interface which is what the hard drive and optical drive run from I hope that helps you
Feb 19, 2014 | ASUSTeK COMPUTER ASUS Eee PC 1025C - Atom...
Does not read on the mac
If the USB hard drive was formatted in NTFS on a PC then the MAC cannot read this hard drive.
If you format this hard drive on a PC in FAT32 file format then the MAC can exchange data between the MAC and the PC.
The MAC can read and write PC data to this hard drive.
Oct 15, 2012 | Buffalo Tools (HD-PE500U2/RD) 500 GB USB...
External hard drive used on mac,how do i use it on pc?
You need to format this hard drive using your PC.
If the hard drive was formatted using the MAC then the PC won't see anything on the hard drive because the MAC uses a different file system that is not compatible with the PC.
BUT if you want to exchange files between the MAC and the PC then format the hard drive using the PC in FAT32 file system. The MAC can read and write to a FAT32 formatted hard drive.
Apr 10, 2012 | Hitachi Computers & Internet
My WD My Passport external Hard Drive ! TB formatted for Mac is not reading my files
A Windows PC computer will not read files on the WD hard drive that has been formatted on a MAC.
The fix.
Copy your photos onto the MAC computer then remove the WD hard drive and connect it to your Windows PC and format the WD hard drive in FAT32 file system.
After formatting has been completed remove the WD hard disk and connect it to the MAC computer. The MAC can read and write to a Windows FAT32 formated hard disk. You can now copy the photos from the MAC to the WD hard disk. When copying is complete, remove the WD hard drive and connect the WD hard drive to your Windows PC and you can now copy the photo from the WD hard disk to your Windows PC.
Mar 05, 2012 | Western Digital Passport WDXML800UE...
Aspire one can not detecthard drive
Repair laptop hard drive is not detected
Solution 1
1. Open the hard drive cover (remove two screws)
2. Remove the hard drive screws, then slide the hard drive (see the arrows)
3. Wait 15 minutes, then plug the hard drive
4. Turn on the laptop.
Solution 2
1. Remove the hard drive
2. Clean the gold layer with a pencil eraser
3. Plug the hard drive, then turn on your laptop
Solution 3
2. Plug jumper on the hard drive
Solution 4
1. Remove the hard drive, plug the external cable.
2. Connect the hard drive to another computer, with USB connection
3. If the hard drive can be detected, eject the hard drive
4. Plug the hard drive to the laptop, then turn on
Intended to make the hard drive can work with the help of another computer
Solution 5
1. Remove the laptop hard drive
2. Plug the laptop hard drive to my PC.
SATA1 - PC hard drive
SATA2 - Laptop hard drive
3. Boot the computer from a PC hard drive
The purpose of using a PC computer main-board as drivers of the laptop hard drive.
I hope this information helps. Thank you for using FixYa!
Oct 15, 2011 | Acer Aspire One PC Notebook
COMPUTER DOES NOT RECOGNIZE HARD DRIVE...HELP
Hello Sir, hi, If a PC does not recognize your external hard drive, you need first to check if the USB port is working, to check simply plug another USB device such as flash drive, if the port is fine, check to see if the USB port is a version 1.1 or a version 2.0, and look if your external hard drive is compatible or does it needs a DEVICE DRIVER, A USB 2.0 device may work on a USB 1.1, just reduced speed, and last try to see if your PC is the problem and not the Hard drive, have your Hard drive plug on another PC, visit a friend and check if you could use his or her PC to see if your hard drive is bad. Now if you find your hard drive is bad, its either the Interface circuit OR the physical hard disk itself. You can check your hard disk, simply disassemble the unit and gain access to the hard disk. either SATA or IDE, plain Hard disk plug it on your PC. see if you can access the disk. If yes back up your files. your Interface circuit at this point is bad. If your hard drive is bad, buy a new hard drive, as your replacement. keep me posted
Jun 08, 2010 | Acomdata (HD160UE5-72) (HD160UE572) 160 GB...
I think that the wires to the disk driver are in the wrong place, whats the right way they go in
Primary IDE Connector with Hard-Disk Drive To connect the PC-DVD drive to the primary IDE connector with the hard disk, perform the following steps:
  1. Back up the files on your hard-disk drive before you proceed.
  2. Set the jumpers on the PC-DVD drive as slave and the jumpers on the hard-disk drive as master (see Figure 11).
  3. Connect the power cable and IDE data cable to your hard-disk drive as shown in Figure 13.
Figure 13. Connecting the PC-DVD Drive to a Primary IDE Connector with Hard-Disk Drive
May 23, 2010 | E-Machines T2042 PC Desktop
I want to read the files of my old Hard drive?
ok you have a pc. now, plug the IDE connector to your old hard disk and plug the power connector also. Now, you have 2 hard disks. Your old hard disk must be plugged into the secondary IDE slot. Dont touch anything with your original hard disk. Just add your old hard disk to your PC through the secondary IDE slot and using IDE cable. When your Windows OS opens, you will see a new Hard Drive when you open My Computer. It could be Drive E, F or G
Oct 09, 2009 | Maxtor Hard Drive
Physical installation of 2nd hdd
The document below gives instruction for installing, but the place and shape of the cabinet and hdd case may be different from you PC. You can use this as a refrence. Installing a hard disk drive Use the steps in this section to install a new hard drive into an empty drive bay. Step 1
If you are installing a new hard disk drive, make sure it is set to cable select. c01179815.jpg Step 2
Slide the hard disk drive into the hard drive cage. c01196498.jpg Step 3
Align the screw holes on the hard drive with the screw holes on the hard drive cage. c01179817.jpg NOTE: Make sure the connectors are at the top of the hard drive cage. c01179818.jpg Step 4
Replace the four screws (two on each side) to secure the hard drive to the hard drive cage. c01179813.jpg Step 5
Connect the power and data cables to the drive. The connectors are keyed and can be attached in only one way. c01179809.jpg Step 6
Insert the hard drive cage into the PC.
Align the four tabs on the side of the hard drive cage with... c01179819.jpg ... the four slots inside the PC. c01179820.jpg Align the three tabs on the side of the hard drive cage with ... c01179821.jpg ... the three slots on the front of the PC. c01179822.jpg Step 7
Slide the hard drive cage down until it snaps into place. c01196499.gif NOTE: Make sure the front tabs on the hard drive cage are correctly inserted into the slots on the front of the PC. c01196500.gif Step 8
Replace the two screws that secure the hard drive cage to the PC. c01179804.jpg Step 9
If you are adding another hard drive instead of replacing a hard drive, connect the SATA data cable for the new hard drive to the next available SATA connector on the mother board.
NOTE: The SATA data connectors on *********** board may look slightly different than the example. c01833532.gif Step 10
Replace the front panel and the side panel, and then reconnect the cables.
For more information about replacing the side panel and the front cover, refer to the HP support documents Removing the Front Cover and Opening the PC Case . c01179827.jpg Step 11
If using Windows, wait until Windows finds and configures the new drive. c00615034.gif
Regards,
Shrey
Oct 07, 2009 | Computers & Internet
Pc hard drive
Yes, that correct you can just need to take the hard drive from your desktop and get a external hard drive ecnlosure where you need to put the hard drive and connect it to your laptop via USB cable, check this link for the sampole of the hard drive enclosure that you need to buy http://www.tigerdirect.com/applications/Category/category_tlc.asp?CatId=2777&name=Hard-Drive-Enclosure
Hope that helps.........
Sep 08, 2008 | IO Magic Corporation GigaBank (I250HD35)...
Iomega 1TB Desktop USB 2.0 Hard Drive Logo
65 people viewed this question
Top Iomega Computers & Internet Experts
Marvin
Marvin
 Grubhead
Grubhead
Alun Cox
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
