Question about byD sign d:5032 50 in. HD-Ready Plasma Television
How to attach antenna for over the air use - byD sign d:5032 50 in. HD-Ready Plasma Television
Directly to the ant input on the tv if it is so equipped and go through the menu to set up dig channells
Posted on Jun 14, 2008
I'm trying to "cut the cord" and use digital air TV. The problem is it buffers and stutters so badly I can't watch it. What can I do?
Get the correct antenna on your chimney. You need the right band antenna for your region. If your shonky antenna picks up something then you know a decent antenna high up will work fine. The attic is a better location but it has to get through the roof tiles and that maybe too much.
Oct 21, 2017 | Televison & Video
How do I hook up an air antenna to my tv
There looks to be a special type of connector. You might need to go to a television retailer and get an adapter.
http://www.wikihow.com/Hook-Up-a-TV-Antenna
How to Hook Up TV Antenna
Feb 11, 2016 | Televison & Video
How to install indoor digital tv antenna to a lcd tv & pickup digi channels
First, the LCD TV has to have a digital tuner in it. Older ones may not. If it does, then you attach the antenna connector to the TV connection that is marked TV IN or CABLE. Then, in the TV's menu, you would need to ensure that the digital tuner is selected. Once that is done, then, still in the menu, perform an "ON AIR" channel scan to find and lock in whatever digital channels that the antenna can detect.
Aug 05, 2015 | Electronics - Others
How can I buy a new antenna for model sony cfm-165tw
Many boombox antennas are attached by a small screw through the pivot point. This is usually a #1 Phillips screw. Some do not have a swiveling antenna; for these you have to remove the back of the case to get at the attachment screw. Keep the screw; it's guaranteed to fit when you attach the new antenna.
The hard part is finding a replacement. If you have the pivoting/swiveling antenna, the Radio Shack 28" Replacement Telescoping Antenna 270-1405 ($5.99 online) will probably work. You might even be able to use it for a non-pivoting antenna that telescopes into the inside of the case.
Jul 22, 2014 | Sony Boombox Am Fm Tv Weather Band...
How do I attach an antennna?
On the back of the TV look for the connector marked Ant/cable. This is a silver connection with threads on it. If you have a digital indoor antenna, connect it there. Same goes if you have an outdoor antenna. Now go to the setup screen and select AIR for antenna type. After that do a channel search and select digital and analog channels. Let the TV find all the stations it can. When it's done searching, it will show a picture. You may need to aim the antenna to get a better picture .
Sep 05, 2013 | Sharp Aquos LC-13E1U 13 in. EDTV LCD...
Key up with no antenna connected
I am unsure what the question is but i believe you are asking if it will hurt your radio to keyup without antenna attached the short answer is yes.
When testing with a watt meter you should transmit into a resistive load aka dummyload or antenna.
Dec 01, 2011 | Radio Communications
I have aflx-3202 t.v. what type of h.d. tv antanna can I use thank you
Any set top HD antenna will do if you are not surrounded by hills and mountains, it maust have COAXIAL connector to attach to your TV. HD (ATSC) antenna is the same as UHF antenna (HD (ATSC) uses the the old UHF band for transmitting) but HD sound better than UHF for marketing purpose so they can charge you more with the word HD on the box.
TARGET or RADI SHACK, BB.
http://www.bestbuy.com/site/RCA+-+Indoor+Off-Air+HDTV+Antenna/8280834.p?skuId=8280834&ci_src=14110944&ci_sku=8280834&ref=06&cmp=RMX&loc=01&id=1171058630499
Learning
http://tv.about.com/od/hdtv/a/hdantenna.htm
http://www.crutchfield.com/S-RIn3fwb4G6X/learn/learningcenter/home/antenna.html
http://www.hdtvantennalabs.com/articles/category/over-the-air-hdtv/
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Dec 26, 2010 | Element Electronics FLX-3211B 32 in. LCD...
Antenna problems
where to attach the antenna? becoz my tv is attached too close to the wall. i can't see the backpanel
Nov 17, 2007 | Televison & Video
byD sign d:5032 50 in. HD-Ready Plasma Television Logo
43 people viewed this question
Top byD sign Televison & Video Experts
Jaime Hernandez
Elise Lacoursiere
Elise Lacoursiere
Are you a byD sign Televison and Video Expert? Answer questions, earn points and help others
