My computer shows a bluetooth icon in the control panel but there is no list to choose from. How can I fix this?
  • 35 Answers
HI
This is neo . Welcome to Fixya . Check the drivers and uninstall the drivers and reinstall the driver . Try to get the correct driver .
Posted on Nov 06, 2010
How to activate bluetooth in a leptop
Check to see that the laptop has a Bluetooth adapter installed. Click on the "Start" menu in the lower-left corner of the desktop. Click on "Control Panel." Click on "Performance and Maintenance" and then on "System." Click the "Hardware" tab in the System Properties window. Click on the "Device Manager" button. Look for a small blue icon that says "Bluetooth Devices." Click on the "+" next to it to expand the menu. There should be at least one Bluetooth device listed. This indicates that your laptop has a Bluetooth adapter. Turn on the Bluetooth device by locating the physical or software switch that activates the adapter. Check the outside edge of the laptop for a button or switch that is labeled "Bluetooth," shows a picture of the Bluetooth icon or is labeled "Wireless." Turn this to the "On" position. If no physical switch exists, check the function keys on top of the keyboard. Look for one that shows a wireless symbol. This may look like a small antenna with waves radiating out from the top. Hold down the "Fn" or "Function" button and press the corresponding function key until the computer indicates that Bluetooth is turned on. Locate the Bluetooth icon in the system tray in the lower-right corner of the desktop. It will match the appearance of the Bluetooth icon you located in the Device Manager. It may have a red symbol in the center that indicates that the Bluetooth is turned off. Right-click on this icon and choose "Start the Bluetooth Device" from the menu. Test the Bluetooth by connecting a Bluetooth device. Right-click on the Bluetooth icon in the system tray. Use the "Quick Connect" option or follow the Bluetooth setup wizard accessed through the "Add a Bluetooth Device" option. Hope this helps.
b>
Dec 13, 2012 | Lenovo 3000 N100 Notebook
Bluetooth problem.
If you have a Bluetooth icon in the tray notification area OR in the Control Panel right click on the icon, go to settings, choose setting to Allow device to find computer, (I'm not sure of the correct wording). I'm not sure what a HUD is on a computer.
Nov 23, 2012 | MSI Computers & Internet
Bluetooth option doesn't show in my laptop
You can find the Control Panel by clicking on the "Start" menu and selecting "Control Panel."
Click on the icon that reads "Hardware and Sound." Then, select the tab that reads "Bluetooth Devices."
Click on the "Add" button. This will put your computer in "Search Mode."
This means that it will search for any compatible Bluetooth devices in the area.
Put your Bluetooth device in "Discovery Mode."
This can be done by pressing and holding the button on the side of the device.
This will cause the device to send out a signal that will be received by the laptop computer.
Select your device from the list of found devices on your laptop.
Once this is done, your laptop and Bluetooth device will be permanently connected as long as they are both turned on.
hope this helps
Sep 21, 2012 | Computers & Internet
How to enable blue tooth
    • 1 Open the Dell Latitude E5400"Start" menu and navigate to "Control Panel." Click "System and Security" if your E5400 came with Windows 7 or "System and Maintenance" if it came with Windows Vista.
    • 2 Choose the "Device Manager" link. Windows Vista also requires you to click "Continue."
    • 3 Click the plus sign next to the "Bluetooth Devices" entry near the top of the list of devices. Right-click the entry for the Dell Latitude - E5400 internal Bluetooth adapter and select "Update Driver Software."
    • 4 Select the option to "Search Automatically." Click "Finish" after the latest driver is downloaded and installed.
    • 5 Close the "Device Manager" window. Locate the blue "Bluetooth" icon in the notification area at the bottom right of the screen. Right-click the icon and choose "Enable Bluetooth."
    • 6 Turn on your Bluetooth-enabled device, such as a cell phone or PDA. Navigate through the device's menu to the "Bluetooth" option and select "Enable Bluetooth," or the equivalent option for your device.
    • 7 Right-click the "Bluetooth" icon on your Dell Latitude D600 again and choose "Add Device." Click the name of your detected Bluetooth device and click "Next" to connect to the device.
Aug 18, 2011 | Dell Latitude E5400 Laptop
Bluetooth won't work and even won't turn on with win7
- Download the 'Windows Mobile Device Center which you can download it from
this works for both Vista and Windows 7. I've tried it on both.
Install the downloaded software but it may not look like it worked on Windows 7 PCs. Vista automatically configures the settings on the bluetooth devices but for those who have Windows 7, here are the things you should do:
- Go to 'Device Manager' from 'Control Panel' -Or- just right-click on Computer Icon and choose 'Properties' and then click on 'Device Manager'.
- You'll see an 'Unknown Device' named 'Bluetooth Peripheral Device'
- Right-Click it and click on "Update Driver Software" -Or- anyway you find it easy to bring up the Update driver window.
- Click "Browse My Computer for Driver Software" button.
- Click "Let Me Pick from a List of Device Drivers on my computer".
- Select 'Bluetooth Radio' from the list if it asked you to select and then in the next window, it will show a list of drivers with Company Names in one list and Drivers in another. In the Company List choose 'Microsoft Corporation', not only Microsoft.
- From the drivers list there may be one or more drivers with the name "Windows Mobile-Based Device Support" with different driver versions. Select one or the latest.
- Ignore any warnings and keep pressing next and then Finish at last. If all goes well, the last screen will show the message that device driver is successfully installed.
Now, after manually updating the driver for your bluetooth device, in 'Device Manager' when you click on 'Bluetooth Radios', it should display one more item which will say 'Windows Mobile-based device support'.
There are few more things that you want to pay attention to. If you have already added the device in your 'bluetooth device list' that didn't work, then remove the device and add it again. After you add it, you might need to restart the computer if it gave you a connection problem error message.
I hope this will help you guys fix your bluetooth problem with Windows 7.Rate me if the message was helpfull.
Thanks
May 20, 2011 | Computers & Internet
I try to install many drivers for bluetooth vostro 1015 but every time a pop up message say that the bluetooth is not turn on and i must trun on by fn+f11 but it doesn't work and the bluetooth still turned...
In most cases, you have to manually turn the bluetooth capabilities "ON' in the administrative tools located in the control panel. Click the START button. The go to CONTROL PANEL, PERFORMANCE AND MAINTENANCE, then click the ADMINISTRATIVE TOOLS icon. Locate the SERVICES icon. Double click the icon. To the left, you will see a list of options. DOUBLE click the SERVICES AND APPLICATIONS option. A list will populate showing the SERVICES your computer has. Locate the BLUETOOTH capabilities. Right click this option, go to PROPERTIES, click the DROP BOX menu. Make sure the service is set to automatic. Click apply and make sure you click the START button to begin the service. Your device should work after this.
Nov 23, 2010 | Computers & Internet
My laptop have got a build in bluetooth but i dont know how to connect it please help
hi
  • Open your computer's Control Panel center to access your Bluetooth Device settings. Click on the Windows icon or the "Start" icon on your computer desktop's taskbar at the bottom of the screen. When the pop-up menu opens, click on the "Control Panel" link.
  • Step 2 Access your Bluetooth Device settings. When the Control Panel opens, click on the settings link that reads, "Bluetooth Devices." This link will display all of the possible actions and settings you can take regarding your laptop'smag-glass_10x10.gif Bluetooth technology.
  • Step 3 Configure your laptop's Bluetooth technology. Select the "Start the Bluetooth Device" action. The blue and white Bluetooth icon will appear in the Windows System tray within the computer desktop's taskbar.
  • Step 4 Network with another device in order to import and export files. Double-click on the blue and white Bluetooth icon on your computer desktop's taskbar. A Bluetooth dialog window will appear on your screen displaying your Bluetooth technology portal. Click on the "Add Devices" action. You will then be asked if your laptop would like to search for other compatible devices. Click "Next" to proceed. You will be prompted to choose a passkey for the pairing. Create a simple passkey and click on the "Pair" option. When the notification is received by the other device, enter the same passkey to pair the device to your laptop.
  • Jun 20, 2010 | Acer Aspire 5500 5570-2609 Laptop
    Control panel does not show bluetooth icon. Why?
    Run services.msc (which is the service management tool)
    You should see a Bluetooth Support Service, set this to start and then have it automatically start with windows as well.
    Bluetooth control panel application: bthprops.cpl
    Bluetooth listed in my actual control panel.
    However you may need to reinstall BT again and check for the properties of it.
    Please check the steps and let me know if it works.
    May 16, 2010 | HP Compaq nc6120 Notebook
    Bluetooth not showing
    Follow these steps to setup Bluetooth:
    1. Double-click the My Bluetooth Places icon
    2. In the initial Bluetooth Configuration Wizard choose where you want Bluetooth icons to be
    3. Enter a name for the computer, select computer type and click Next 4) In the next Bluetooth Service Selection screen, select services that will be offered by this computer by Bluetooth 5) Click next Next button and then click the Skip button to close the Bluetooth configuraton wizard
    Next you will set Bluetooth Discovery options 1) Right-click Bluetooth Icon and choose Advanced Config from Menu 2)Click accessibility tab 3)Select let other Bluetooth Discover this computer option 4)Click the Discovery Tab 5) Select Look for Other Bluetooth Devices option and choose how often you want to perform this check 6)Click Apply and then click OK to close the dialog box. Now when someone else with Bluetooth comes into range it will automatically connect
    Dec 25, 2008 | Lenovo R61 T7300 Notebook
    Computers & Internet Logo
    49 people viewed this question
    David Payne
    David Payne
