Question about Bissell Vacuums
I have had my Bissell 6591-X for 2 years. I hate it! No matter what I do all the fuzz, hair, whatever fills up around the upper filter before it even starts to deposit in the cup. It has done this ever since I bought it. No matter how much I take it apart, clean it, clean filters, empty the cup, nothing does any good. I spill more dirt onto the vacuum and floor than ever gets in the cup. I will never buy another Bissell.
  • 34 Answers
Sure your not over filling it ?
Posted on Nov 06, 2010
Machine no power seems very hot
Vacuum cleaners easily overheat and will shut off as a result. The cause may be a bad electric connection, electric cord or accumulation of hair on the roller bar (prevents the bar from spinning, which burns up the motor). It might be a temporary problem or the motor might have burned up. Let it cool down, check all cords and connections carefully and retry it. You can call Bissell 1-800-237-7691 for more help if this doesn't resolve it
Jan 26, 2016 | Bissell 6591 Power Trak Revolution Bagless...
Bissell 6591 operating twice as loud as before.
Hey Mike! Excessive noise can be contributed to dirty filters or clogs. Here's a quick link to troubleshooting steps to assist you.
http://www.bissell.com/FAQDetail.aspx?id=1421&cid=ccsocial
Feb 03, 2013 | Bissell 6591 Power Trak Revolution Bagless...
Bissell powertrak revolution dirt not going into cup
If the unit is not blocked between pickup and filter have a good look at the filter to see if air is passing through it---paper throwaway or foam filter the can be washed?
The ones that can be washed etc will have instructions right on them.
Nov 02, 2012 | Bissell 6591 Power Trak Revolution Bagless...
Unit will not **** up water
Your pump belt might be worn out or the motor track may be clogged with fuzz and hair from usage. You probably need a service and clean.for a vacuum cleaner or vacuum shampooer service center to repair your extractor call us if you are in Colorado.** watch this tutorial for DIY repairs.Make sure you are actually filling the soap canister because the machine will not perform properly otherwise.
Jun 05, 2012 | Bissell 8920 ProHeat 2XTM Upright Vacuum
I was given a model 6591, plugged it in and it worked but didnt "****" and didnt sound right. I turned it off and removed the hose from the back found a badly plugged hose. Removed the hair...
The User Guide for the bissell Clearview Power Trak
http://canada.bissell.com/images/UserGuides/3590C.pdf
May not be your exact model but should be similar.
The Bissel vacuums include an internal thermal protector to protect it from overheating. When the thermal protector activates, the cleaner will stop running. Should this happen proceed as follows:
1. Turn the cleaner OFF and unplug from electrical outlet.
2. Check the Pre-Motor Filter and Post-Motor Filter for dirt accumulation.
3. Remove any clogs.
4. When the vacuum is unplugged and motor cools for approximately 30 minutes, the thermal protector should automatically resets and cleaning may continue.
5. If the thermal protector continues to activate after following the above steps, your cleaner may need servicing. Call Bissell Customer Service:
http://canada.bissell.com/Contact_Us.aspx
Mar 20, 2011 | Bissell 6591 Power Trak Revolution Bagless...
Is blowing dust out as I vacuum
In your manual:
Visible dirt escaping from cleaner
Possible Causes: Remedies:
1) Dirt Container full 1) Empty Dirt Container
2) Filters missing or installed incorrectly 2) Check Upper Tank, Pre-Motor and Post-Motor
Filters for correct installation
3) Dirt Container installed incorrectly 3) Pull out and re-insert Dirt Container correctly
Feb 01, 2011 | Bissell 6591 Power Trak Revolution Bagless...
The brush is clean and spinning but it isnt picking up anything and just pushing pet hair around.
You mentioned pet hair. Remove the brush cover and check for a plug (possibly pet hair). Sounds as though you have a plug somewhere and it's not allow the suction to pull it through. Also check your filter and clean or replace as necessary. Hint; Never let you container get over half full, it reduces the suction.
Nov 02, 2010 | Bissell 6591 Power Trak Revolution Bagless...
Bissell proheat 2x leaves dirty water spots
Your belt for the brush might need to be changed, that or the suction parts is clogged with hair or fuzz, check that clear part of the front of the machine to see if theres anything clogging it
Sep 14, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
My first time using this..I just want to know where the water goes and where the soap goes..I don't have directions..I was looking for the directions on here but don't see it.. This is a bissell proheat...
hi,
okay the under the lid of the big tank has a place for regular hot water theres a flexible inner bladder inside the main tank- fill that with hot water. When your shampooing the dirty water fills in around it, also between the back wheels theres where the resolve/bissell detergent goes. we use regular washing machine liquid diluted 50/50 in the soap dispenser , its cheaper and does the same thing..also, if you have pets, the bissels have a brush roller mechanism that gets clogged with pet hair quickly and will self destruct, every few rows stop and see how much pet hair is around those rollers and remove it.
J
Jul 11, 2008 | Bissell Vacuums
Vacuums Logo
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
