Question about Maytag Washing Machines
Washing machine went into an unbalanced ( bumping mode) I stopped the machine. redistributed the load. I started it again it continued on spin cycle. I stopped the machine to attend to something else. About an hour later I attempted to start the machine. It would not start on ANY cycle whatsover. I checked the power supply ( wall plug) it was 'live' also checked the house fuse box - all O.K. Is there a reset button??? I looked, I can't find one. Any help/suggestions you can give me will be MOST appreciated. I live in VICTORIA BC CANADA. Can you recommend a repair company. Thank you Ian Marshall.
    President:
  • 2,712 Answers
Try a hard reset first: Disconnect from power supply, turn of breaker switch/fuse for about 10 minutes. Then reconnect everything and try.
If that doesnt work, the fuse on the machine must have blown. Try replacing that and see..
BTW, is your machine under warranty?
Posted on Jun 14, 2008
  • Swilin Sampson
    Swilin Sampson Jun 14, 2008
    Do you have a display panel on your model, and if so, do you get any error messages? Or does your machine not start at all?
    Check
    to see whether power is getting to the washing machine. Is it plugged
    in? Has a fuse blown or is a circuit breaker tripped
    Also check the lid switch. If
    the lid switch is defective, your washer can't spin and may not
    function at all. The switch is inside the washing machine main housing
    near the door frame. Often you have to raise or open the top or front
    of the washer to get to the switch. If it's defective, you need to
    replace it.
    Some machines have a special lid-switch fuse near
    the lid switch, inside the control panel. If this fuse blows, the unit
    won't fill with water until you replace the fuse.
  • Swilin Sampson
    You could try this page to locate a Maytag service center nearby:
    http://www.servicebench.com/servlet/WebS...
    However, any repair center should be able to resolve this issue, if its a matter of checking the fuses, motor , etc..
    If you found my answers helpful in any way, kindly take a moment to "Accept" my solution. Thanks!
  • 1,879 Answers
The motor probably burnt out, chk these sites:
westcoast appliance
allpages.com
    Master:
  • 638 Answers
Wait while i assist u in a minute
  • 3 more comments
  • hemant somaiya
    hemant somaiya Jun 14, 2008
    its problem with ur machines power supply.check the contact wires of ur machine too
  • hemant somaiya
    give me ur zip code to assist u about any reparing technician
  • hemant somaiya
    any normal tecnician will repair ur machines power supply at a negligible cost nothing much to worry.rate this solution as fixya if it helped u understand ur problem n encorage us to solve more problems n queries. thanks for using fixya. feel free 4 further assistance
  • hemant somaiya
    for all details n more solutions regarding this check the following link.:
    www.applianceaid.com
    or
    www.applianceblog.com
  • hemant somaiya
    dont forget to accept the solution. thanks in advance.
My whirlpool duet washer hammers very loud when it spins. The outside of the machine doesn't seem to vibrate much but it is very loud.
That is a common occurrence with dryers such as this one. Even though it sounds bad, it is harmless. If it really bothers, you can re-balance the load and it should reduce the vibration.
Jul 29, 2008 | Whirlpool Washing Machines
Whirlpool washing machine make loud noise after spin cycle quits. Noise continues until cycle winds down. Sounds like a machine gun being fired
Hello,have to tell you that most noises from a washing machine occur during the spin cycle. If you hear loud thumping noise during the spin, the load of cloth may have become unbalanced. Stop the washer and redistribute the cloths, then restart the machine. Repeat these steps if necessary.
Thanks
Jun 04, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Noise hear during washing cycle?
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Mar 28, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Washer does not finish cycle..it stops at spin and it displays a 'dc' code...what is this
The Service Manual for reference. Sears Parts Direct for reference.
dC code from the Service Manual = Distribute Clothes: The load is unbalanced, preventing high speed spin. Redistribute clothes.
Your wash tub is banging around during the spin cycle correct?
You can redistribute the wash basket load until the cows come home the issue will only continue to get worse. Maybe start throwing uC error codes to the console display for continuous unbalance error code.
Your FAV6800A or FAV9800A has a Clutch malfunction. It can be corrected if you are handy see this DIY fix Clutch Fix. post.
If you decide to dive in I will help you through the fix………Rich
Feb 07, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Noisy when trying to spin. display uL instead of time remaining. Stopped, opened lid and redistributed load. Started up again. cycle continued but still displaying uL. Not sure if load still unbalanced?...
REPLACE YOUR SUSPENSION RODS. You can get them at a discount applicance parts store online for about $60. Our washer is about 8 years old and has been getting unbalanced on every load. I replaced the suspension rods tonight and and it solved the problem.
Jan 24, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Makes loud noise when on spin cycle
Jan 09, 2010 | Amana 3.2 cu. ft. Top-Load Washer
Excessive noise during the spin cycle. we have owned the washer for 16 months. problem started 1 wk. the machine is level.
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Jan 03, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Vibration of wash machine
Hi!
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary. If there's a loud thumping noise during the spin cycle, the load of clothes has probably gotten unbalanced. Open the lid, redistribute the clothes in the washer, then re-start it. Repeat these steps if necessary.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
May 22, 2009 | Danby Washing Machines
Noisy Spin Cycle
hi there,
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping/or sound
Jun 12, 2008 | Whirlpool LSR9434PQ Top Load Washer
Washing Machines Logo
61 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
