Question about Generac Power Systems Generac 5518 8 Kw AirCooled Standby Generator
Only 75 volts output - Generac Power Systems Generac 5518 8 Kw AirCooled Standby Generator
  • 26 Answers
Look at part number 66386 ...brushes and holder...repalce them and tell me if that doesn't help...does red LED appear on voltage regulator?
Posted on Oct 19, 2011
  • 44 Answers
How and were did you measure 75volts
Posted on Nov 06, 2010
99 fatboy stator output
Disconnect the stator plug from the regulator. Have your meter in Volts AC. Start the bike and watch the meter readings. typical output is 25 volts AC per 1000 rpm. So at 1000 rpm it should read around 25 VAC. At 2000 rpm it should read around 50 VAC. and finally 3000 rpm should produce around 75 VAC. Could be a little lower which is common.
Nov 12, 2013 | Harley Davidson Motorcycles
Power supply output for Yamaha p4500 secondary output for the power supply so that i could check the voltage
Hi Joel, although we've sourced detailed schematic for this P4500 amplifier, there are no many voltage details on it for manufactures sake. Anyway, mine findings are. Secondary winding on main transformer should supply no less than 2 x 75 volts which makes after rectifying and filtration no less than 2 x 90 volts on capacitors with amplifier without input signal. Also transformer has to be very "hard" , otherwise amp will start clipping before reaching stated wattage on output.
Oct 17, 2011 | Yamaha P4500 Power Amplifier 2-Channel
I don't get any front display or any sound when turned on.
Do you hear any clicks? If not, the standby transformer or related circuitry is bad. If you hear 1 relay click...the audio output section is most likely the problem. The first click you hear is the main power relay...and should see display.. the second relay click is the protection circuit relay engaging to let audio to your speakers...if the second click is not heard (it should occur in 3 to 5 seconds) there are shorted output transistors or a shorted output IC trying to blow your speakers with 50 to 75 volts dc. The protection circuit monitors the speaker lines for voltage. They should always read milli-volts only...not even 1 volt.Anyway, good luck
Sep 24, 2009 | Sony STR-DE525
Engine runs but no AC or DC output.
  1. Remove the rectangular snap-fit cover from end bell
  2. Start generator making sure it's at rated RPM
  3. Using volt meter test brush terminals.
  4. Use red+ lead on top or right brush black is - negative
  5. should see approx. 75 volts DC
If no voltage, need to flash with 12 volts DC same polarity as above, for 5 seconds
Aug 03, 2009 | Coleman Sport 1850 Generator
Lost power cord
Specifications:
  • Manufacturer: HP
  • Input: 100-240V, 50/60Hz
  • Output: 32V, 16V
  • You can get more information here:
    http://www.unitedsale.com/product_info.php?products_id=18583
    Please vote me if you like my post.
    May 25, 2009 | HP Photosmart 2610 All-In-One InkJet...
    Code: P1133
    P1133 - Heated Oxygen Sensor (HO2S) Insufficient Switching Bank 1 Sensor
    You will need to check the output signal from this O2 sensor, if the voltage low (.10-.25 volts) try spraying propane into the air cleaner to see if the O2 volts go up, it should go to around .75 volts, if nothing happens then the O2 sensor is bad, bank #1 O2 is on the same side as #1 cylinder
    PLEASE RATE THIS INFO.
    Nov 25, 2008 | 2005 Chevrolet Silverado
    I require a step down plug
    I'm disappointed that Dewalt does not have the full specs on their website so . . .
    Check the specifications on the charger's label; they should read something like 120 VAC or Volts AC and 2.0 (or similar) amperes or just 'A' after a numerical value.
    If the label does not give you an amperage value you can use the output value instead and substitute the output voltage at the high end if a range is listed.
    To get the adaptor (step-down transformer) wattage, multiply the AC values such as:
    120 X 2=240 watts input power.
    If these AC values are not available;
    Take the high end charge voltage if it is a multirange charger, and multiply those values;
    One we own DW9108 (- yours is 7.2 - 18) is spec'd at 9.6 to 18 volts and 2.8 amperes:
    2.8 X 18=50.4 watts.
    You can see that the values do not correspond but it is a multirange device so the maximum current taken from the AC line can be ~ 2.0 amperes but this is charging a specific pack and the peak input current is only momentary so the maximum output current and voltage are the values one should use as a guide. In other words, the output wattage is closer to the value needed.
    Since there are losses in any transformation (mostly heat), the required stepdown transformer must be capable of more than the indicated 50 watts.
    A safe factor would be 1.5 X 50 (W) or ~ 75 watts minimum to ensure the charger receives the 120 volts it wants.
    Anything that will step down your (?) 220 volts and is rated at 75 watts or more will do the job even if the Dewalt draws a little more current at your line frequency of 50Hz which it may.
    Oct 09, 2008 | Dewalt 7.2-18.0 Volt One Hour Charger
    Collector on horizontal output is 75 volts momentarily then to 0 volts.
    Never measure the collector of the horizontal output transistor. When the set is on that voltage is spiking upwards of 1000 volts and could seriously damage the meter and possibly shock you. Measure the B+ pin on the flyback instead, it should be 135 volts. Usually what I find is that the flyback itself is shorted, so when you turn the set on the B+ comes up and the horizontal output starts conducting, but the computer senses the extra current in the flyback and shuts the set back off. The red timer light on the front of the set will then blink a certain number of times to indicate exactly why the set has shut down. If you do not have experience analyzing the Sony shutdown circuit then have a qualified tech handle it for you.
    Nov 07, 2006 | Sony KP-53V75 53" Rear Projection...
    Generac Power Systems Generac 5518 8 Kw AirCooled Standby Generator Logo
    112 people viewed this question
    Top Generac Power Systems Electrical Supplies Experts
    John Trevino
    scj103
    richie46
    Are you a Generac Power Systems Electrical Supply Expert? Answer questions, earn points and help others
