Question about Whirlpool RBD275PD Electric Double Oven
Oven does not work at all sometimes it beeps and has a fault code that reads E6 F2
  • 2,382 Answers
Hi, to fix this error code follow the instruction below...
  • Check keypad connector for firm connection (keypad connects to control board).
  • Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Posted on Nov 06, 2010
How to remove side panels on a whirlpool Gold double oven, in order to remove control panel. I would like to reconnect the control panel, it may reset the panel to work again
Hello Ms Jackson,
An E6-F2 is a very common control board failure. The control board in your appliance will need to be repaired or replaced.
Read more below about common Whirlpool oven Fault codes and what they mean. FixYourboard.com can repair this issue quickly and economically. We also back our workmanship with an industry leading two year warranty. http://blog.fixyourboard.com/2015/08/20/gbd-rbd-whirlpool-oven-problems-causes-and-solutions/
I've also attached a link on how to remove your Whirlpool oven control board How to Remove Whirlpool Oven Control Board
Feb 10, 2017 | Whirlpool Ovens
Our oven read a problem # E6 F2 what that's mean?
The E6-F2 error code means that the control board thinks there is a problem with the cancel button on the touch pad. Sometimes its due to a loose connection from the ribbon cable on the touch pad. You can push cancel and clear it and if within 5 or under the error code returns the touchpad needs to be replaced. But first check/have the connection checked to make sure its tight. The way modern things work though is grand and Whirlpool say if after replacing touchpad the error code returns once again the clock/control board is what needs to be replaced.
Gene
Aug 11, 2011 | Whirlpool RBD305PD Electric Double Oven
Received E6 and F2 code. repair man replaced the control panel key padand it worked for a while. stopped working and got same codes E6 and F2. Repairman saw the control's behind the key pad needed to be...
Hello & Welcome to FixYa
F2-E6 error code indicates an open/shorted oven temperature sensor and to solve this problem the temp.sensor needs replacement. If you want to be sure then before replacing the sensor you can test it with a voltmeter for around 1100ohms....if it reads more then 1120 ohms then it needs replacement however, if the reading is between 1080-1120 ohms then it is the control board that needs replacement. However, after reading your problem it seems that the sensor is causing this and replacing it is recommended repair. Please get back to me if you have any other questions.
Kevin
Mar 15, 2011 | Whirlpool GBD307PR Electric Double Oven
I have a whirlpool oven which has an error code flashing "E6 F2" the display is coming and going
F2 is most likely the oven temperature sensor. I cant find any reference for E6
Sep 15, 2010 | Ovens
My oven is giving me an error of E6 F2, what does that mean
Equipment is Whirlpool double oven RBD305PDS14 built-in. After a very stormy summer 2007, I thought a power surge may have zapped the control board. Problem initially presented on display as error & fault "E6 F2"; simply pressing "Timer Off" would usually clear this error & fault code.
However, some months later, the display would often go completely blank followed by the beep sequence "short-long-short-short-short" (Morse code: dit dah dit dit dit). No error & fault code would appear. Pressing any keypad oven control did not work at all in this condition. When power was cycled at the breaker panel, the usual "PF" with clock display did not appear.
[TURN OVEN POWER OFF AT BREAKER!!!]
After following the excellent information on "how to remove the control panel" posted in this forum, I first tested the "control panel thermal fuse" (refer to the tech sheet that should be behind the control panel once it is removed). It showed a closed circuit.
I turned my attention to the "flexible" keypad connector cable (error & fault code "E6 F2" is a keypad or keypad connector problem; again, refer to tech sheet). The control panel has a board mounted female connector with two tabs that may be gently pulled upward to release the flexible cable.
I cleaned the flexible cable contact area (it seats into the board mounted female connector) carefully with a Q tip and some isopropyl alcohol. I reinserted the flexible cable and gently pressed down on the two tabs (noted above) on the board mounted female connector. VERY GENTLY tug on the flexible cable to insure it is gripped by the connector.
After all of this monkey business, I re-mounted the control panel display panel on the oven and restored power. So far, so good. After applying power, the "PF" with clock display always appears. I am able to set the clock and press "Start". Over functions normally. The clock displays as normal and I no longer observe the problem I described above.
BTW, I noted the incoming 240V has transient suppression (no surge protection, however
RATE THIS SOLUTION
RNJ VINOD KUMAR
Sep 19, 2009 | Whirlpool Ovens
Whirlpool oven model RBD275PDT12 display showing error code E6 F2 after display out for 12 hours. My daughter was cooking Friday night. She said she saw the display say ''end''. On saturday morning display...
We see this error very frequently at www.fixyourboard.com. It is sometime accompanied by a display that goes blank. The boards can be fixed quickly, reliably and with a long warranty.
Jun 03, 2009 | Ovens
Whirlpool RBD305PD has error F2E6 error on control panel
When this code appears and display is going blank too, it is always the control board. The only option is to buy a new one or get it repaired. It can be fixed quickly and reliably. www.fixyourboard.com
Apr 02, 2009 | Whirlpool RBD305PD Electric Double Oven
Double oven will not work sometime
Mobley, F2-E6 code is cancel key drive line open. The tech sheet I have on this recommends reseating the keypad connector. It then states to press cancel. If the error comes back within 60 seconds replace the keypad....Catriver..post back.
Sep 16, 2006 | Whirlpool GBD307PD Electric Double Oven
Whirlpool RBD275PD Electric Double Oven Logo
132 people viewed this question
Top Whirlpool Ovens Experts
ashburton
Sal De
Oloyede Monsuru
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
