Question about Crown CE1000 2-Channel Amplifier
CE 1000 ... Inverting or Non-inverting???
I have a ce1000 driving the woofer towers of a pair of Infinity RS1b. The low pass on the crossover has a switch for "inverting" and "non-inverting. What is correct? I am using stereo mode with the din type click in amp inputs.
  • 1,512 Answers
Hi oldschoolrid
The inverting and non inverting is to phase the speakers correctly, particularly for low frequency reproduction. . If say you had the amp driving subs at the back of the room facing say for the example full range speakers at the front of the room, then you would need to invert the signal to prevent phase cancellation occurring. If everything is facing the same way, you need to use the noninverting setup for the bass towers.
am more than happy to answer any other questions you may have about it, just give me a hoy :) If you are still unsure, or have problems, then before you give a rating for this advice, please get back to me and we can try some more things. Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
Posted on Jun 19, 2008
KRK Rokit monitor has no sound from bottom speaker (the larger speaker for lows and mids) the unit powers up fine and i get sound through the tweeter.
What you are describing is a total component failure of something in the crossover board. You cannot really check a crossover without an oscilloscope and a frequency generator. In a lot of cheap speaker systems, there is no crossover board attached to the woofer. In your case it appears that a low pass filter is present on the woofer.
Sep 27, 2015 | KRK RP5G2 Pair Rokit G2 Powered 2-way...
What is a opamp
An opamp is an operational amplifer. The OPA134 is a single amplifier with differential inputs. The best way to describe this IC is that it is an ideal amplifier with infinite gain, with high input impedance and low output impedance making it both a voltage and current amplifier. The output signal is divided with resistors and provides feedback to the minus input to inject negative feedback. The ratio of this feedback basically determines the final gain. The input signal may go to the positive input for a non-inverting amplifier or to the negative input for an inverting amplifier. Roughly the voltage gain in dB will be 20 x log of Vout/Vin. There is a difference in the gain of 1 between inverting and non-inverting for accuracy sake, but that is the basics.
This particular part is very high quality in performance and should be replaced with the equivalent part or one from Burr-Brown. The power supply is typically +/- rails and ground is usually the virtual point between the split supplies representing 0V. Sometimes the input signal will not be referenced to ground and will be fed to both the plus and minus inputs which will be balanced (impedance wise) to form a differential input that rejects common signals such as noise. Pretty cool device, I couldn't live without them. OPA134 Precision Amplifier Operational Amplifier Op Amp Technical documents
Jan 10, 2014 | Texas Instruments OPA134PA IC, AUDIO,...
Tda8172&stv9379whats difrent
TDA 8172 & STV 9379 are pin to pin compactable vertical output ICs, and are equivalents. to each other. Ok
1-Inverting Input
2-Supply voltage
3-Flyback generator
6-Output stage supply
7-Non inverting input.
Dec 08, 2011 | Televison & Video
One of my polk audio RT800i tower speakers began smoking while watching tv I quickly disconnected it and it no longer works. how can it be fixed?
Since they're not self powered I wonder how much audio power they were absorbing at the time or maybe how mouch distortion, as THAT kills speakers faster than clean power. The only things that can burn up are the crossover and the individual drivers. I can't find anything about a fuse, which almost certainly would be blown, or should have. A blown crossover probably wouldn't affect the woofers. You COULD access each driver and test each with an ohmmeter for dead short or infinity.
May 01, 2011 | Audio Players & Recorders
Crown CE1000 amps, 1 dead channel - Can I diagnose via RJ-45?
Before asuming it is the power transistors check the power on relay first as mine had the same proble and it was because of the Relay that did not switch on the one channel or amp (remember this is a power amp and consist of two mono amps)
Nov 07, 2009 | Crown CE1000 2-Channel Amplifier
Need apair passive crossover for pair of maxp64 600 watts
You can easily make one yourself. All you need are two non-polar capacitors of about 1 Farad each. Radio Shack and any respectable electronic component store have them. For a high pass filter (AKA crossover) connect in series with the speaker wires. For low pass operation like a sub-woofer, use it in parallel with the speaker.
Oct 02, 2009 | Car Audio & Video
Can this all be hooked up?
There was never anything mentioned about the 18 yamaha sub in the hook up process
Aug 17, 2009 | Crown CE1000 2-Channel Amplifier
Do you have instructions for wiring install on volfenhag GX8200??
Amplifier Class AB
Number of Channels 2
RMS Power (4 ohms) 120 watts x 2 channels
RMS Power (2 ohms) 200 watts x 2 channels
RMS Power (1 ohm) Not Stable
Bridged RMS Power 400 watts x 1 channel
Total RMS Power Output 400 watts
Peak Power Output 1000 watts watts x 1 channel
Minimum Impedance Unbridged 2 ohms
Minimum Impedance Bridged 4 ohms
THD at Rated RMS Power 0.1%
Speaker Level Inputs No
Preamp Outputs 1 pair
Built-in Crossover High-pass (HP), Low-pass (LP), Full (AP)
High-Pass Crossover Frequency 40 - 250 Hz
Low-Pass Crossover Frequency 40 - 250 Hz
Subsonic Filter N/A
Signal-to-Noise Ratio N/A
Channel Separation N/A
Bass Boost 0 - 18 dB
Bass/Gain Remote Yes
Fan Cooled Yes
Fuse Rating 20A x 2
Dec 24, 2008 | Volfenhag ZX-8200 Car Audio Amplifier
Car stereo crossovers
you should be able to remove the passive in-line crossover, but since it is blocking everything below 3500 hz, there is no need. leaving the passive crossover in place will also help protect the tweeters if something fails in your setup as any amped frequency below 3500 can seriously damage them.
Nov 11, 2007 | Infinity Kappa 10.7t 1'' M.M.D. Dome...
Crown CE1000 2-Channel Amplifier Logo
95 people viewed this question
Top Crown Audio Players & Recorders Experts
Are you a Crown Audio Player and Recorder Expert? Answer questions, earn points and help others
