Question about Whirlpool Dryers
I replaced a Thermocouple on a Whirlpool dryer model LE5800XKW1. Unfortunately I got the wires mixed up with the heating element. So I have four wires and don't know which to connect where. Two wires both red connect back to a common black, so I am expect one these goes to the heating element, and one to the thermocouple. I have a white and red wire left. Which goes where?
mikedurland
  • 481 Answers
SOURCE: I have to change the
  • green = ground (attach directly to the case, should be a green painted screw near the opening
  • red = hot 110v connect to the red on the dryer
  • black = hot 110v connect to the black on the dryer
  • white = neutral connects to the blue (only if the blue is in the middle)
  • neutral is always in the middle with a hot wire on either side of it.
  • also make sure all the connections are tight
let me know if you need more help Mike
Posted on Jul 02, 2008
jsrock516
  • 5911 Answers
SOURCE: changing a 3 prong dryer cord to a 4 prong dryer cord??
The information you need is provided in the following link:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
Read through the information carefully and if you need any further assistance, please let me know. I hope this helps.
Posted on Sep 01, 2008
docjohn174
  • 943 Answers
SOURCE: Maytag dryer MDE4000AYW change 3 prong to a 4 prong
HI thanks for your question. the red to red black to black white to white green goes to the fram of the dryer. thanks hope i was helpful. please rate my answer.
Posted on Oct 12, 2008
agitateme
  • 88 Answers
SOURCE: dryer sensor: white wire & blue wire hook up to what side of sens
The wire terminals may be different sizes, to only go on one way. If not, no big deal....the radiant sensor acts just like an in line switch, so it really will not affect the operation whichever way the wires go on.
Posted on Apr 21, 2009
jsrock516
  • 5911 Answers
SOURCE: I need to change the dryer power cord on my Amana
The two wires on either side of the power cord are your HOT leads. They are the voltage carrying conductors. These two wires will connect to the terminal block on the RED and BLACK wires. The middle wire is NEUTRAL and goes to the WHITE wire at the terminal block. Now...with a 3-wire configuration you will need to connect a grounding strap to the neutral wire and ground it to the grounding lug of the appliance. The following link explains:
The main difference between 3 and 4 wire configuration is how the neutral and ground wires are installed. In a four wire configuration these two are independent of each other. In a 3 wire configuration ground and neutral are connected together.
If you have any questions about this repair, please ask me. I hope this helps you.
Posted on Jul 17, 2009
I have a whirlpool gold model number geq9800lw0. I need to know how the thermal fuse and cut off are wired with the heating element. Think I may have gotten some wires mixed up.
They are usually wired in series, the wire comes from the control to the thermal fuse, then from the fuse to the thermostat and then from the thermostat to the heating element, then from the heating element to the control.
Jun 06, 2017 | Whirlpool Dryers
I am trying to replace heating element. my model has 1 wire coming from the bottom to the element. all videos I have seen show two wires. I am confused...
Tim, Could not find your model, look at attached video and see which wire you are not locating. maybe it fell off or is stuck in the body some were.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Google search your make and model# manual.
How To Replace Heating Element Whirlpool Dryer Repair 279838
Dryer Heating Element part 8544771 How To Replace
May 26, 2016 | Whirlpool LEQ9858L Electric Dryer
Won't heat during cycle
If you have a multimeter you can UNPLUG the dryer and open the back panel.
You can check the heater element if you have continuity and you don't see it burned up it is probably OK. This should read low ohms usually 24ish( rough guess, reasonably close is probably ok) as they do vary. Low number is prob good.
The thermocouple should be above it on the back of the vent usually higher up it will have 2 contacts more than likely. This shuts the heater coil off if it gets too hot. It will also keep the dryer heater in the dryer from turning on if it is bad. This should read infinite ohms no continuity cold. You can "ghetto test" this by heating it in a frying pan and seeing if it closes( 0+ ohms or continuity. You should also replace the thermostat. (looks kind of like the thermocouple 3+ contacts) at the same time. You can test the thermostat as well but these are occasionally different so I would need a model number.
If you find a bad thermocouple you need to make sure that metal vent area there behind it is clear of lint and other garbage. This is a fire hazard and if found is probably what caused the thermocouple to fail.
Hope this helps!
Jun 08, 2011 | Whirlpool Dryers
I have a whirlpool dryer model ler7646eqo i need to know the watts and voltage so i can install an outlet in my home what is it?
The motor is rated 1/6 hp (about 125 watts) @120VAC while the heating element is rated 5400 watts @240 VAC. Click on link below for some insights. The make are different but the wiring are the same
Three-Prong and Four-Prong Plug Wiring
Mar 07, 2011 | Whirlpool LER4634J Electric Dryer
My dryer is having a problem getting hot, Is there a heating element that can be replaced?
Good day,
The heating element could be your cause only if it is shorted. With the dryer unplugged, remove the 2 wires going to the heating element. Check each terminal to the case of the dryer. It should read zero ohms to either terminal. If it reads any resistance below 10,000 ohms then it will need to be replaced.
However, it is more likely that the venting system, both external or internal. causing your problem.
Here is how you get to the internal components.
http://www.applianceaid.com/whirlpool-dryers.html#four
Nov 20, 2010 | Whirlpool LEQ8611L Electric Dryer
I have a Whirpool Dryer model 3LEN 2000PW1 It runs but does not heat?? Four years old. Could it be the heating element?
Hello there:
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Sep 29, 2010 | Whirlpool Dryers
Whirlpool washer takes long time to dry clothes.
A dryer ( Whirlpool ) , either heats or no heat . If it heats , then the vent is partially clogged , either in the hose , or between the dryer and the outside . Disconnect the vent , and dry a load , checking the air flow . If good , then to the outside is restricted .
Mar 04, 2010 | Whirlpool LEN2000PW Dryer
I'd like to know how to change a heating element in my dryer (29' whirlpool) I'd like to know exactly how to take it apart and where to find the element. I'am not sure of the dryer #
first you nead to unplug the dryer,next you nead to remove the vent hose,next you nead to remove the back panal and the power cord cover,on the left side you will see the heater housing,at the bottom you will see the heating element,there are four wires,the two at the bottom are hooked to the element,you nead to pull them off,the other two wires are hooked to the high limit switch,you nead to pull them off,next there are two 1/4"screws,one on each side off the heating element,remove them,now pull out on the bottom of element,with element removed,remove the high limit switch from old element and put it on the new element,take new element and put it back in the heater housing and replace the two 1/4" screws,you will see that the two wires that go to the element are biger than the two going to the high limit switch,put the two wires to the element,now replace the two wires to the high limit switch,replace the back panal and the power cord cover,replace the vent hose,plug power cord in and check element out.
Nov 25, 2009 | Whirlpool LER5636P Electric Dryer
Heating element quit working on model # ler4624bw2 Whirlpool electric dryer
Hello there
Here is a couple of links that will help you replace the heating element along with some manufactures that can also help ok?
Best regardss michael
  1. Whirlpool Dryer Heating Element 279838 Kenmore | Estate ...unknown.gif ... REL4632DW0,LER6638DW0 LER4624BW2,LER7646AW2,KEYS677EZ0,REL4632DW1,LER6638DW1 ... Model: Whirlpool | Kenmore | Sears | Roper | Kitchen Aid | Estate. Shipping ...whirlpoolpartssurplus.com/cart/whirlpool-dryer-electric-h...
  1. How to Replace Your Electric Dryer's Heating Elementunknown.gif How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid. Electric Dryer's Heating Element ... 3 styles of heating elements in use for these dryers. ...www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm - Cached
  2. How to Replace the Heating Element in A Whirlpool Dishwasherunknown.gif How to article - how to replace the heating element in a whirlpool dishwasher. When your dishwasher heating element goes bad, your dishes will not dry quickly. Before...ehow.com/how_5337380_replace-heating-element-whirlpool-di...
  3. How to Replace the Heating Element in A Whirlpool Ovenunknown.gif How to article - how to replace the heating element in a whirlpool oven. If the lower heating element in your Whirlpool oven no longer gets hot, or if you n
Oct 15, 2009 | Whirlpool Dryers
Whirlpool Estate Dryer barely heating
Four wires on the new cord.
Red and Black go to outside screws on the terminal.
White goes to the middle terminal.
Green goes to the cabinet ground screw near the terminal plate cover.
Mar 11, 2009 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
162 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
