Question about RTO Atwood Water Heater - 6 Gal LP
I have an atwood water heater in my 94 motorhome and when it is cold and dark it won't turn on . It also makes a bussing noise like the pilot is tring but can't . I can turn it on when the sun comes up . What is up with it or what do I check first ?
  • 8 more comments
  • Mike Butler
    Mike Butler Nov 06, 2010
    Can you give me a model number of heater, so I can tell if electronic ignition etc.? label on heater behind cover on outside. Are you sure it's getting 12 volts? Is there a solar panel on your motorhome ? Did this just suddenly start to happen?
  • kimsautorepa Nov 06, 2010
    It is a 6ga7e model . I do have a solar panel on the a/c unit .There is normally one or no lights on and we are on 110v line.I have cleaned the connections and now it seems to come on and only heats for 30secs if no water is being used .It has been like this for a while and when camping we sometimes had to start the engine for it to work
    What is the lowest volt reading I should have if I cover the solar panel and test it at the heater ?What wire is the incoming power ?
    94 searcher jamboree I have to pull up the seat
    voltage at w/heater is 12.6 v but I didn't cover panel yet
    I'm checking things when I can inbetween jobs
  • kimsautorepa Nov 07, 2010
    OK Ihave 12.4 v and no voltage at ignitor . The w/heater did start up when I pushed on the conector at controll module . Is it the module or conector .I did clean it before
    Thanks I'll try that today and check it tonight .The buzzing does come from the ignitor board .
  • kimsautorepa Nov 08, 2010
    Well I cleaned with pencil and electrical spray but it still did it . I'm going to try and find a connector before tonight .
  • kimsautorepa Nov 21, 2010
    Sorry took so long but I had to replace the module and good so far . Thanks
  • RTO Master
  • 6,674 Answers
Does it have electronic ignition ? I'm presuming it does. Do you use a solar panel anywhere on your motorhome?
Posted on Nov 06, 2010
  • 14 more comments
  • Mike Butler
    Have you tried shutting all other 12 volt sources off such as lights at night to see if that makes any difference? Also, do you have a multimeter to test for proper voltage at connector on circuit board?
  • Mike Butler
    You need to check converter, I suspect it's not supplying 12 volts . There may be blown fuses or something in converter. All your 12 volt system runs off converter when plugged in, or should be .
  • Mike Butler
    When you start engine, it provides 12 volt charge to auxiliary batteries as well to power 12 volt items. When your plugged in, converter is supposed to take over, and charge batteries as well. That explains why it works when sun is out only, because solar panel is supplying enough power to allow heater to run properly.
  • Mike Butler
    What type,make, model of motorhome? Did you find converter?
  • Mike Butler
    Also, make sure all your breakers are on, just in case one that supplies 110 AC (hydro) power to converter is off, then converter obviously won't work.
  • Mike Butler
    just check at auxiliary battery, or cigarette style receptacle in motorhome, for 12 volt TV, or cell phone charger
  • Mike Butler
    Should be 13 volts or over if converter is working.
  • Mike Butler
    Best place to check is right at converter for output voltage. Can you locate it?
  • Mike Butler
    Check under dinette seats, or somewhere close to breaker panel etc. What make is your breaker panel/ converter have on it?
  • Mike Butler
    I Have to step out for a couple of minutes, but will check back shortly to see what you found.
  • Mike Butler
    OK I'm back, any news?
  • Mike Butler
    Find anything, or did ya give up for now?
  • Mike Butler
    DId you check voltage when water heater trying to ignite/running?
  • Mike Butler
    No need to cover panel, just see if you can get a voltage reading from one of the lights or something with all lights turned on, or in one of those 12 volt sockets, or auxiliary battery even, but make sure all lights are on if you can so I can see what you get with a load on the system. Also, pull connector off circuit board at water heater and check for corrosion, and clean contacts on board with a pencil eraser.
  • Mike Butler
    ok, no problem. I had to step out again, so I thought I might have missed something.
  • Mike Butler
    Mike Butler Nov 07, 2010
    See if you have any WD-40 or similar to pull connector(s) off and give it/them a good spray to remove any rust.corrosion that may be in there as well as try to push wires further in to connector, as they sometimes will work their way out a little and not make good contact with igniter board. Do it before and after you put connector back on board. I see you cleaned it already but double check down inside that connector and give contact points on board another rub with eraser, or even a light rub with fine steel wool is good too. 12.4 volts should be sufficient to operate properly. If that doesn't cure it, check at any RV dealer/ service dept, and they should have another connector you can buy for a few bucks, and try that before replacing ignitor board. I haven't run in to too many boards with bad connectors, only dirty, and cleaning usually cures that, but it's possible, but I'd try changing that connector first as it's a much cheaper fix if it works. Keep me posted. Good luck.
Pilot will light after 30 seconds when you try to move knob to on position the pilot goes out and heater won't ignite.
You need to replace the thermocouple.
When you light the pilot it is supose to heat the thermocouple.
the thermocouple produces a small electric current which allows the gas valve to open and keep the pilot going. and allowing the main burner to come on.
Jun 21, 2011 | RTO Atwood Water Heater - 6 Gal LP
Hot water tap creates an annoying noise in the mh. The noise is coming from the Atwood hot water heater. (2007 Coachmen Mirada).
Like a buzzing noise? Check valve where water lines connect at back will make a buzzing noise, if you only hear it when running hot water and not when running cold. Remove and replace it after shutting water off, and draining tank down. Be sure to shut off any hydro to electric element prior to draining.You can buy a replacement check valve, or just put a short 1/2" pipe nipple in there instead and reconnect your line, and refill it. noise should be gone .
Jun 09, 2011 | RTO Atwood DSI-RV Water Heater-6 Gallon
I have an Atwood 6 gallon electronic start water heater in my 1999 Pace Arrow Vision motorhome. The ignition spark does not operate when I try to turn on the heater from the control panel in the RV. I can...
Open following link for Atwood troubleshoot resources to identify product and look at manual with parts lists.
http://waterheatertimer.org/Atwood-water-heater-resources.html
Add a comment to this thread saying how you solved problem to help others who have same issue
Jan 25, 2011 | RTO Atwood Water Heater - 6 Gal LP
The pilot on My atwood water heater will not stay lit after I release the knob. I have replaced the thermocouple and have a nice blue flame.
Did you make sure the connection between the thermocouple and the control is tight and that the tip of the thermocouple is in the flame?
Jun 28, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
I have atwood pilot relight model gc6aa-8 pilot will light but after tank heats up & there is no call for hot water,pilot is out and very hard sometimes impossible to relight.
So are you saying that the first initial lighting of the pilot, without turning to on, works o.k., good flame etc, ? If not sure, try lighting pilot only, and leave setting at pilot only, and see if it's a good flame, and get back to me.
May 25, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
RTO Atwood Water Heater - 6 Gal LP Logo
66 people viewed this question
Top RTO Water Heaters Experts
Jim Goldsmith
Jim Goldsmith
Mike
Are you a RTO Water Heater Expert? Answer questions, earn points and help others
