Question about Samsung SyncMaster 720N Monitor
My Syncmaster 720N randomly shuts off. Can it be fixed?
  • 11,361 Answers
That can be due to bad DC filter caps in the power supply, worst case will be the lamp assemblies.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Learn about bad caps: Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you
Posted on Nov 07, 2010
HOW TO DELETE BRIGHTNESS BOX FROM MONITOR ON SAMSUNG SYNCMASTER 720n
If your trying to get out from the brightness option. Please follow this steps...
Go and click this manual, then at the left side of the manual look option that says for "Adjusting your monitor" then look for user controls.
I hope it helps you a lot :)
Feb 03, 2011 | Samsung SyncMaster 720N Monitor
Have samsung syncmaster 720n monitor. adjustment menu blinks on/off. how to stop?
Trying the hold down power button for count of ten (did count of twenty just to make sure) didn't work. Menu came back up. Will try unplugging control chip next (this fix doesn't make sense to me ) will see if monitor will work without chip>
Aug 13, 2010 | Samsung SyncMaster 720N Monitor
Resolution and refresh rate
1280x1024 native and will go to 75hz x 81khz
I'd probably look more at what your video card supports.
Jan 08, 2010 | Samsung Syncmaster 17" 720N Monitor
Syncmaster 720n
OK, I've figured it out! There's something wrong with the control chip, so if you don't have it under warranty, here's what you can do:
1. Turn off the monitor
2. Unscrew the face of the monitor
3. Remove the bottom part of the face from the backside, so you can see the chip
(the control chip is located on the face of the monitor, under the buttons)
4. You will see a small white connector about 5mm wide, UNPLUGG it
5. Put the small cable that you've unconnected under the front, so you can close the monitor back
6. Close the monitor and plug it back in
That's it. You won't be able to change your settings (they autoadjust anyway), but you won't have to throw the monitor away!
Peace.
Sep 01, 2009 | Samsung SyncMaster 720N Monitor
Samsung 720n power light blinks, no picture.
hi
I am a technician-informatic. I have repaired about 60 Lcd Samsung monitors with this problem - not optimal resolution mode and dark screen problem. So i decided to made manual how to repair lcd samsung monitors.The repair process is very easy and simple 10-30min. does not need a lot of experience in electronics and expensive instruments.
if you are interested check it.
Samsung monitor repair manual guide 710n,913v,510n more
or just enter number in search field: 220409788372
thank you
Apr 20, 2009 | Samsung SyncMaster 720N Monitor
Samsung Monitor 720N
check the resolution of the system make it as 600*800.
Jan 06, 2009 | Samsung SyncMaster 720N Monitor
Samsung prob
Here's a link to a troubleshooting guide
Maybe you should try re-setting it to factory settings.
Apr 04, 2008 | Samsung Syncmaster 17" 720N Monitor
Samsung SyncMaster 720N Monitor Logo
407 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
