Question about Optimus Audio Players & Recorders
Does not come on, bad fuse? - Optimus Audio Players & Recorders
    Scholar:
  • 71 Answers
Check the fuse if thats good check the plug if you have a volt meter
Posted on Nov 06, 2010
My Emerson Microwave MW9117W has lost power and was wondering if there was a fuse or something that needed replacing
There are fuses inside. The big thing is to figure out why the fuse went bad. either something shorted and blew the fuse, or it got hot and went bad due to bad connections at fuse holder. or maybe a bad door switch blew the fuse. I have also had fuses just get old and tired., and just needed to be replaced.
Aug 19, 2017 | Emerson Microwave Ovens
I have a Panasonic inverter microwave. Was working perfectly an hour ago. Now totally dead. There is no light or anything. Have checked plug and fuses. No smell or anything. Can you please help.
Could be a shorted inverter blew fuse and unit dead. Or bad fuse holder got fuse hot and melted fuse so now unit dead. Must check fuse first and if bad replace and try, if it blows as soon as it tries to heat probably bad inverter. If it works for a long while then quits maybe bad fuse holder not grabbing fuse tightly making it over heat. So then bad by temperature not amperage.
Jun 20, 2017 | Panasonic Microwave Ovens
Headlights won't turn on
Five most common possibilities:
1. The headlight bulbs are burned out
2. Blown fuse or fuses
3. Bad lighting relay
4. Bad light switch
5. Bad electrical connection; could be a bad ground, bad connection in a plug in the harness, bad connection to a switch or relay, wire worn through the insulation and causing fuse to blow
Feb 03, 2015 | Cars & Trucks
Digital display for weather and copass is out
check fuses
you blew one. if it is keeps blowing , that feed line has a short.
use voltmeter at fuse,
or remove the suspect fuse, and use ohms, 0 ohms good, infinity bad.
if fuse looks bad, it is
if fuse looks (eyes) good, it can in fact be bad.
Apr 06, 2014 | 2000 Jeep Grand Cherokee
Location of the turning signal fuse
GET A GOOD FUSE TESTER, TEST EVERY FUSE. 2 BOXES ONE UNDER THE HOOD & ONE INSIDE THE VEHICLE. THE FUSES HAVE TEST POINTS FACING OUT. POWER ON ONE SIDE, BAD FUSE POWER ON BOTH SIDES GOOD FUSE, POWER ON NEITHER SIDE, SPARE FUSE.IF THE FUSES TEST OK, YOU MAY HAVE A BAD FLASHER, OR BAD TURN SIGNAL { COMBINATION } SWITCH.
Jan 06, 2011 | Daewoo Lanos Cars & Trucks
Model 2002 the horn doesent work
3 possible problems, Horn is bad, fuse is out, wires fell off.
Locate horn in car, and check the wires leading to it. If they are attached, then check the fuse box. The fuses are labeled under the lid. Check to see if the fuse is bad. Remember fuses are themselves not bad, so if another fuse blows, there is a problem with the wiring or the horn is bad.
good luck and don't forget to vote!!!
Oct 10, 2010 | 2002 Honda Civic
My gas gauge is not working.
One of three things. Bad fuse, loose wire, bad gauge, or bad sending unit (located inside of fuel tank)
Sep 09, 2010 | 2002 Buick LeSabre
200 chevy blazer 4x4 is not workin it is push button and the indicator lights dont light up at all
Check the fuse in the fuse box first and replace if the fuse is bad. If the replacement fuse goes bad again, check the wire harness at the encoder motor on the transfer-case. Look for any damages causing a short making the fuse to go bad, once the harness and connectors are good. Inspect the encoder motor, check to see if it's not the problem causing the fuse to go bad and if it is. Replace the encoder motor, good luck and keep me posted.
Feb 21, 2010 | 2000 Chevrolet Blazer
Fuses part 2
If the fuse is bad get the ratings off fuse and go to radio shack. Cost under a dollar, In fact bring the bad one with you.
Mar 05, 2008 | RCA P60920BL 60" Rear Projection...
147 people viewed this question
Top Optimus Audio Players & Recorders Experts
Marvin
Marvin
Craig Butler
Craig Butler
Ben Armstrong
Are you an Optimus Audio Player and Recorder Expert? Answer questions, earn points and help others
