Question about Nokia 6500 Slide Cellular Phone
The phone is over 2 years old and has problems switching-on with the answer and call-end key depressed. Any ideas?
    Problem Solver:
  • 12 Answers
Plz change ur key pannel from nearest repairing center....it will definitely works
Posted on Nov 06, 2010
I have a Nokia 5230 and in the last two weeks it has turned off completely for no reason. Now it has turned off and stayed off although it was fully charged. I can not turn it on at all now, any ideas...
Just follow the steps
Take a full backup.
First Try it:
You may try default phone and security code to remove it
Defalt phones codes is 12345 or 00000 you can use it
if the problem is same do the next,
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
If
Soft reset( factory setting)
On Sybmian phones:
*#7780# - Restore factory settings
*#7370# - Reformat your phone (back up your personal data with PC Suite or to the memory card first!)
Hard reset
Back up your personal data with PC Suite or to the memory card first!
Switch-off your phone.
1. Press and hold three keys at a time;it is called "3 finger reset" which is depress these three keys simultaneously "*" "3" "green phone" and then power on phone whilst keeping those same three keys depressed until you see formatting.
If you dont understand, again follow the step.
You will use three finger for pres three keys ."green phone"+ "3" +star( *) and pres the power on switch.
All switch will be pressed at a time.
Soon an formatting text, will appear ,then stop pressing those switch,
Remember.
2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory stetting.
Hope this helps.
May 01, 2011 | Nokia 5230 Cell Phone
Tip
How to reset Kyocera Zio m6000
Soft reset
Dial: ##4357*
Select view
Scroll down to select reset.
6 digit code: 000000
Click Ok
Should reboot.
Dial *228
Hard reset
1. Power down the phone
2. Hold down the volume up, end key, trackball and send key simultaneously.
3. Phone boots. After it vibrates you let go.
To reset Kyocera Zio try the following:
1. Remove battery and put it back after two minutes
2. Press and hold down the home button key while turning on the phone.
3. If by chance the phone starts , do Menu Button > Settings > SD Card USB MASS > Factory Data Reset
If it does not work, try:
Hard reset 2.
1. Power off the phone.
a. Press and hold red END key for 2 seconds >> Phone Options >> select Power Off >> Phone will shut down >> Ok
a)
2. Remove battery for 15 seconds & replace battery.
3. Power up the phone.
a. Press and hold red END key for 2 seconds and wait until the device powers up completely.
b)
4. Power off the phone.
Procedure, cont.
5. Press and continue to hold the Volume Up button using your left thumb.
6. While still holding the Volume Up key, use your right hand to depress the green Send key, the white Track ball and the red End key (sequential order).
7. Continue to hold all 4 until keys completely down until the handset vibrates twice then let go of the keys & track ball.
a. Formatting Data and Cache appears
1. If you do not see the above (Formatting Data and Cache) redo steps 1 through 7.
2. If you get a Fast Boot, Self Test or Blue screen redo steps 1 through 7.
3. Allow the phone to completely reboot. This may take a few moments.
4. The phone has now been re-set to factory default settings. Please proceed through standard set up and activation procedures.
If still no luck, call Kyocera directlyand report the problem.
on Sep 03, 2010 | Cell Phones
How do i reset my security, i forgot my old security code
Take a full backup.
First Try it:
If
On Sybmian phones:
Hard reset
Remember.
Hope this helps.
Mar 03, 2011 | Nokia X3 Cell Phone
Nokia 3110c music player updating problem
Take a full backup.
First Try it:
If
On Sybmian phones:
Hard reset
Remember.
Hope this helps.
Mar 03, 2011 | Nokia Cell Phones
Lg ku990. answer and delete key do not work
The "End" key on mine would not work at all, so I took the 6 screws out, pulled the inner part out, then the rubber keys, cleaned it all and it works fine now. Be sure your screwdrive is exactly the right size as the heads strip easily. No harm in trying as the thing is useless anyway. You could try a compressed air blowout first - it worked with my kids DS, but not with the phone.
Mar 21, 2010 | LG KU990 Viewty
Refrigerator not cooling adequately
The answer to the temperature range is NO. It should be 36-40. Could the thermostat be faulty? Are the doors sealing properly? Is the interior light remaining on, when the door/s are closed? Open the door and depress the door switch. See if the light goes out? Being 25 years old, technology has come a long way. Purchasing a new unit wouldn't be a bad idea.
Jul 13, 2009 | Refrigerators
Uniden cordless model DC7758-4
Does the Uniden cordless phone model DC7758 have an answering machine?
Sep 30, 2008 | Uniden Cordless Phone
White screen
Any answers to this,... I have had mine for 3 weeks and now can't use it!!! Due to the white screen HELP!!
Jun 15, 2008 | Nokia e65 Cellular Phone
Razr ccan't hear caller
there are tools to back it up on the net from motorola
1- try to reset it
if that doesn't do it
2- try firmware updates
Jan 01, 2008 | Motorola Mobility RAZR V3
Cordless phone doesnt disconnect?
one thing you could check immediately is the filter, they do go faulty sometimes, just swop it with another one that you know is a good one.
Jan 06, 2007 | Uniden TRU8885-2 Cordless Phone
Nokia 6500 Slide Cellular Phone Logo
13 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
