Question about ViewSonic PJ551 Multimedia Projector
My projector won't recognize my dvd player. I have tried both the component video cable and the s-video cable and a couple different DVD players. What could be the problem? it was working fine the last time I used it. It just stays on the main screen cycling through the computer connection, s-video, and component. Thanks!
5 Suggested Answers
Gurudristi
  • 98 Answers
SOURCE: dvd player to projector
Yes please.
You can connect it either thru the RCA Composite output(yellow) of your DVD or thru the S-Video or even thru the component out(YPbPR) connections. In the component out you would require three RCA cables and would give you the best possible picture.
Find a link below , which gives a review of the Viewsonic PJ 501.
http://reviews.cnet.com/home-theater-projectors/viewsonic-pj501/4505-7858_7-20722971.html
Hope this clarfies.
Please do rate this solution and thanks for using FixYa!
Posted on Mar 05, 2009
SOURCE: New ViewSonic PJ 513DB connected to laptop. Cannot see DVD
I think this is your laptops problem with putting out that on both displays at the same time try cloning or playing with those settings
Posted on Mar 10, 2009
  • 360 Answers
SOURCE: Hello my name is noel i am from belize i have a
It is working through RCA & not through computer indicates the problem either in source switching or analogue to digital converter. Also check whether the horizontal & vertical sync reaches A/D converter.
sonsunny
Posted on Jul 05, 2011
heathgr
  • 442 Answers
SOURCE: my projector won't project anything.
Disconnect all inputs to the BENQ and power on. Do the lights come on as per normal operation. Does the lamp come on when the power button is pressed. Does anything show when the menu is selected.
Posted on Aug 20, 2011
Denon AVR-4806 HDMI problem
Check which port you have the HDMI cable connected to, then go into the menu on the TV, look for it on screen and Enable it .
Good luck
Nov 16, 2013 | Denon AVR-4800 Receiver
Samsung DVD-V3650 DVD Player / VCR Combo no sound when connected via component cable
Component connections between your DVD player and TV (they will be colored red, blue, and green) carry video only. You will need to connect two more cables for left and right audio channels. The connectors for these audio cables will be colored white and red for left and white respectively.
Nov 04, 2017 | Samsung DVD-V3650 DVD Player/VCR
My dvd player is hooked up to t.v. but only plays movies in black/white
How is the DVD player connected to the TV? If you are using component video, check that the cables are connected correctly.
If you switch the order on two of the cables, the black and white result is common. So double-check that the red, blue and green connections (RPbPy) have been connected to both devices in the same order. Next try a different set of component video cables, in case one of the wires is damaged.
If possible, try a different type of connection to rule out a damaged input/output. Connect the TV to a different DVD player or the DVD player to another TV, if possible, to rule out similar damage.
Please add a comment with the connection type for additional support. I hope this helps.
Oct 07, 2012 | Vizio L37 Television
I have hooked up the composite video and rca stereo cords to DVD player and TV. Sound but no picture even after I tried pressing video on remote, and correct input on TV remote. Do I need an component...
yes to use component input you need the component cable they are very different from rca cables
good luck with it
sonic boom electronics australia.
Apr 21, 2010 | GPX DH109B DVD Player
Dell 1200MP works with PC but not the DVD player,
Hi.
If you have a replacement cable test the DVD using a different cable, you never know.
Try the following:
  • Unplug both projector and DVD from power.
  • Keep units connected together by video cable.
  • Connect back and restart the DVD first.
  • Restart the projector only once that DVD is ON.
If it still does not work , then there may be a fault.
Nov 09, 2009 | Dell 1200MP DLP Projector
I cant play my dvd on my infocus LP280 projector
Please provide us with more details like the DVD player make/model and what is the connection cable you are using.
Normally, you should be able to connect the DVD player through the AV out pins and connnect it to AV in of the projector.
Other options that can be used are:
S-Video connector, component video connectors, and DVI-D connections
Please reply for more help and clarifications. Thanks.
Aug 05, 2009 | InFocus Office Equipment & Supplies
Projector giving green picture it is ok with RCA inputs ok with S video input but if i connect component connector like 15 pin vga from dvd player it gives green picture but with same cable if i connect pc...
I think, the issue might be because of lenght of the composite cable. Not all projectors can "recognize the signal" on too long composite cables, try a "standard size" cable used on monitors, it is i THINK 1,8 feet long...? Dunno. Try two short cables and see if you get "green" - if not, then your cable is too long and gives the signal to much "resistance", so your projector can "read" only one of the color channels, in your case green. If your projector setup requires long cables (and it usually does ;) ), you will have to stick to Cinch connectors and analog video signal, which I have tested on 35m long cable without any visible quality loss. Hope this helps. ;)
Feb 20, 2009 | HP Compaq nx7010 Notebook
Denon DVD-1740 component video to RGB cable
YOU HAVE THE RIGHT CABLES FOR THIS INSTALL, GREEN, RED, BLUE FOR COMPENENT VIDEO AND RED AND WHITE FOR AUDIO UNLESS USING THE OPTIACL OR COAXIAL, FROM THE DVD PLAYER TO THE AMP OR TV.
ON THE FRONT OF THE DVD PLAYER IS A HDMI BUTTON PRESS THIS BUTTON UNTILL OFF IS DISPLAYED AND YOU SHOULD HAVE PICTURE
Jun 02, 2008 | Denon DVD-1740 DVD Player
No input detected on projector
it sounds like the A/V reciever does not upconvert the component signal to HDMI. Not many do. The Marantz recievers will (SR6001, SR8001, etc..). Also bear in mind that HDMI cables are finicky and may require amplification over a few meters long.
Dec 04, 2007 | Hitachi PJTX100 Multimedia Projector
BenQ PB6100 Component input problem
You can get high defintion by connecting a cable that is component video source on one end your (dvd) and VGA (to projector)on the other. This cable is available from cables to go.
Aug 24, 2007 | BenQ PB6100 Multimedia Projector
ViewSonic PJ551 Multimedia Projector Logo
69 people viewed this question
Top ViewSonic Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you a ViewSonic Office Equipment and Supply Expert? Answer questions, earn points and help others
