Question about Sanyo Televison & Video
I was watching my Sanyo HT27745 HD TV which has been good for 5 years and the show went off and I get a display that says to connect the inputs/antenna in the back and hit the up channel. Nothing was disconnected but now it will not do anything but search for inputs and then say nothing is hooked up. Cannot get the menu or get it to do anything else. Is it hopeless?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 64 Answers
Check the eeprom .you should upload the firmwer Sanyo HT27745
Posted on Nov 06, 2010
Sanyo ht27745
First be sure to unplug your TV, then you can check the power supply circuitry after removing the back from the unit.
most likely capacitors in the power supply circuit. You can detect these by the bulging at the top of them. Any caps bulging MUST be replaced.
Nov 25, 2013 | Televison & Video
PICTURE SEEMS TO BE BLURRED WHEN ITEMS MOVE FAST ON SCREEN, ESPECIALLY PERSONS IN CLOSE UP.
The Sony Bravia KDL-32BX320 generally gets excellent reviews (4.5 stars out of 5) from owners, so I have to wonder what you're watching.
This is an HDTV and should excel when provided an HD signal to display. SD (standard definition) signals often look worse on an HD display than on an SD display. An HD signal is only available via the following ways (reference the image below):9_27_2011_4_28_11_pm.jpg
1) An "over the air" (UHF / VHF) antenna is connected to the cable / antenna input and there is a broadcaster of HD content nearby (only an over the air antenna can input HD signals to this jack - no cable boxes, etc.).
2) An HD Cable TV, DirecTV or Dish Satellite set top converter, Blu Ray Disk Player (or other HD source is connected via HDMI or Component RGB jacks.
3) An HD video played back from a computer hard drive connected to the VGA jack (when the computer is equipped with a modern processor and video card).
You will NOT be able to view HD video if:
1) The source material is a SD (non-HD) source. An over the air antenna will not provide HD signals if the broadcaster does not have HD content to show or is not capable of broadcasting in HD. Digital is not necessarily HD.
2) The source material (other than over the air antenna) is connected via Antenna / Cable jack.
3) The source material is connected via Composite jacks.
The USB jack is generally not an input for motion pictures, but may display stills - depending on the TV's ability to play the format they are stored in (jpeg, gif, bmp etc.).
Hopefully, this will help you solve the problem you're having with the picture. Good luck!
Sep 27, 2011 | Sony Bravia KDL-32BX320
How do I get a owners' manual for my sanyo tv.
I think this is the manual you are looking for.
www.puxaki.com.br/.../Sanyo-Owner-s-Manual-HDTV-HT27745-HT28745-3015.pdf
Jun 24, 2011 | Sanyo HT28745 28" TV
When i plug my camera into the HD tv via HMDI port nothing shows up on the tv. what am i doing wrong?
On my HD Tv, I have to press the "Input" button on the remote - and that displays a list on the screen.... Aux, TV, PC, Game, HDMI. Find the equvalent button on your TV Remote and select the HDMI port as the "Input" and you should be good to go.
Jan 11, 2010 | Sanyo VPC-HD1010 Camcorder
How do I get rid of error message across top of TV that reads "Your television cannot support HDCP video over your high definition connection (H1001)".
Use component cables instead of hdmi cables. I know this isn't the best solution, but HDCP is not used over component and the video quality is just about as good.
Jun 04, 2009 | Westinghouse SK-26H240S Television
Do we have to manually set the pix set key for every station/show we watch? We loose scrolling writing at the top and bottom of the screen on my dad's new 32" lcd tv bought at Wal-mart. When we set...
Thanks for the offer but we cannot afford to pay additional money for something the Factory support service Should provide.
From what we have heard through the Verizon installer, our SANYO LCD TV probably does NOT have a Automatic picture adjust system. That would most likely be the reason for the maunual button on the remote control. The troublle is that with the FIOS service, you do NOT use the TV's remote control. That leaves to switching back and forth between two different remotes wiich can be vary confusing for someone that is not 88 years old.
It is bad enough that you have to remember which channels you have to go to to receive HD programming signals. If I were making a TV set, and or running a TV network/ cable service, I would transmit both HD and regular signals on the same channel number and let the TV and or the decoder box figure out if my set could display High Definition. Isn't that what we spend lots of money buying equipment and paying each month for service?
If anyone out there knows if the SANYO 32 inch LCD TV sold at Wal-Mart automatically adjust to the picute format, (PIX 1-4) we sure ould like to hear from you.
Jul 23, 2008 | Televison & Video
Surround sound 5.1
Does your rca cables go to a surrond sound amplifier or directly to the tv. The tv only has two speakers.If the signal is sent to a seperate receiver it must have a lisyen mode then set to 5.1 surround. The digital optic cable should go to receiver first.
Good Luck
big red
Feb 24, 2008 | Audio Players & Recorders
Magnavox 15" LCD TV
If the LCD only has coax, it will never display a HD picture quality. However, the Comcast HD Box will still display a picture using the coax connection. So, you could watch any HD channel, but the picture quality will not be high definition.
Jan 22, 2008 | Philips Magnavox 27MS343S 27" TV
32 in sanyo tv
no. the tv has to be built for hd. if you want to watch true hd you have to have an hdtv.
Jan 18, 2008 | Sanyo DS27510 27" TV
Televison & Video Logo
79 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
