Question about ViewSonic N2750w 27 in. HD-Ready LCD Television
How do you connect High Def from cable box - ViewSonic N2750w 27 in. HD-Ready LCD Television
  • 11,361 Answers
You can use a set of component cable (RED/BLUE/GREEN with RCA plugs) and the RED/WHITE RCA plugs for the audio. Does the CABLE BOX have those outputs or it has HDMI.
Basic LCD monitor and LCD TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV, Monitors, Caps : http://s807.photobucket.com/home/budm/allalbums
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Nov 06, 2010
Only 1 hdmi outlet on TV . I have a high def cable box and a sony blue ray dvd player. How do I connect 2 hdmi cables fron the components to the tv?
Don't used the Blu Ray player on the tv HDMI out put hub.Used the connections for of the Blu Ray player connections by a S-Video cable for the video and the RCA component cable R,W for the connections for the audio out.The high Def.cable box will not work for high Def. this way,but the Blu Ray player will.
May 30, 2011 | Sony BRAVIA KDL-40S2400 40 in. LCD HDTV
Sylvania 15 inch digital/analog LCD TV HDTV. Once
try doing the auto search method on the cable remote. sometimes this works when the codes do not. if it doesn't then it is what it is.
Jun 26, 2010 | Televison & Video
How do I hookup LHT854 Theater System to tv if using comcast digital box? DVD player works fine with sound but but no sound if trying to watch tv.
most cable companies will provide you a high def. cable box for no additional cost. swap digital for high def box. run dvd into high def cable box and run hdmi output from cable box to lg input. hope this helps
Feb 01, 2010 | LG LHT854 Theater System
No picture but have sound
Make sure your not trying to watch a high def channel, you will get sound but no picture if tuned to a high def channel on a non high def input or cable box. Try a vcr or dvd player connected to the unit to varify the picture tube has not gone out.
Sep 25, 2009 | Televison & Video
Powersurge made my HD setting revert to low def.
Your TV plays High Def material through either Input 4 (uses component cables R,G,B) or through Input 5 (Uses DVI cable).
Today most equipment uses HDMI cable for High Def or it may have a component (RGB) output that you can use. The DVI hookup is best, so you need a HDMI to DVI cable or Component Cables (Red, Green, Blue). You need some source that OUTPUTS High def (ex. 1080i) either through HDMI or component cable. You need to either connect the component cable(R,G,B) from the source to the Input 4 on the TV or connect the HDMI to DVI cable from the source to the Input 5.
You need to set the AV source on the TV to AV5 (if you are using the DVI input) or AV4 (if you are using component cables).
If you want to play Highdef source like Blue Ray then you can just connect the output of the blu ray player to your Tv using either the HDMI to DVI cable or component cable (Red, Green, Blue) and set the TV input to AV5 (for HDMI/DVI) or AV4 (for component).
But if you are trying to get Free High Def from an antenna then you will need to have a component that can OUTPUT high def. The $40 converter boxes don't do this - they simply convert the Digital signal to Analog (non high def). What you need is a High Def TUNER that OUTPUTS High Def. I was looking for one for this same reason and ordered the centronics ZAT 502 HD. But it cost about $80. Then I saw that Tivo had an upgrade deal where I could upgrade my existing Series 2 Tivo to Tivo HD for $99. It has a High Def Tuner in it. So I cancelled my order with Centronics and got the Tivo. In any case if you want Over the air HD you will need a High Def Tuner that will OUTPUT 1080.
Jul 02, 2009 | Philips 55PW9363 55" Rear Projection...
Recording HD channels
well you would need to hook up cable box to dvd recorder. the only draw back first off is one you cannot get hd onto a dvd. you can down scale and it will seem a little cleaner than standard def but of coarse it will never be high def. I'm not to familiar with the motorola boxes but if they offer dvr's in your area i would suggestgetting one you can record all channels then afterwards transfer them to a outside device. but as i said before high def cannot fit onto a dvd unless you plan to copy one movie to 6-7 disc. Just keep in mind a standard high def channelcan only fit 2 max on one freq due to the amount of data transfer as opposed to 10 to 12 standard def digital channels
May 08, 2009 | Televison & Video
Recieving hy defintion picture
You need to do the following:
1: use HDMI cable to connect Cable box to TV
2: Call Cable company to activate HD service
3: Enjoy!
You can use component input, but the HDMI is best HD quality!
I hope this helps! please rate highly!
Mar 01, 2009 | Vizio L32 32 in. LCD HDTV
I was given this tv I need to connect cable
your t.v will hook up directly to cable. if you are asking how to hook to a digital box then you can hook it up the same as you had it hooked on your previous t.v. but if you want to get high def channels then you are going to have to take your digital box back to Time Warner and swap it for a high def digital box. or you can just call Time Warner and have a technician go to your house and swap/ hook things up for you. Hope this helps you.
Feb 02, 2009 | iLO 3200 32 in. LCD Television
I need to hook the vcr to a vizio to record a football game while i'm at work
If you have cable no problem. connect the coax to the in of the VCR and the out to the coax input of the tv. just like you did with a regular tv, they work the same way. if you have a cable box, then connect it between the cable box and the tv. If its a high def box, then you may have to use RCA cables and then read the manual for the VCR to learn how to record off the line input. If you have a Sat box then you should be to do the same thing with that as you did the cable box. The TV does not record anything, get a high def box with a DVR no one uses tapes anymore, wake up and smell the 2000's.
Jan 05, 2009 | Vizio L37 Television
Colors Off with High Def Comcast Cable
check your cable connections between tv and box, especially the red connector, try unplugging and plugging back in the cables.
Jul 09, 2007 | Sony Grand WEGA KDF-55XS955 55" Rear...
ViewSonic N2750w 27 in. HD-Ready LCD Television Logo
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
