Question about Dryers
Maytag dryer model cde8500 will not start and light does not come on. Have checked power and door switch.Where can I get a wiring diagram did not get one with dryer.
  • 3 Answers
Remove back/front panel; you may well find a service booklet with wiring diagram taped inside...I did in my Whirlpool
Posted on Jul 11, 2008
High heat sensor was open had to replace it.
Posted on Jun 16, 2008
The Dryer stop working. The Start button doesn't
You need to check to see it you have power coming out of the timer? There should be a wiring diagram inside the control panel.
Door switch should be checked with the timer set to run and start switch pressed down to start. Check for power at the motor see wiring diagram for which terminals.
If you give me the model # so I can look it up I can try to walk you through it.
Mar 22, 2010 | Maytag Dryers
Maytag dryer model PYE4558AYW. Stopped running, and no light in drum. Getting power. Timer switch continues to work. Fried Timer?
first off check to see if you don;t have a breaker tripped in your breaker box ! also make sure there is 220v going to the recept.
then with unit unplugged remove the back cover to see if there is a wire burnt on the motor start switch which is common will be a red or a orange wire. if all that checks out then sounds like a timer issue
Jan 12, 2010 | Maytag PYE4558A Electric Dryer
Maytag mde5500ayw,,,, have interior light and display will light up, but unit will not start???
hello. begin by looking closely at the latch on the door. if it has lint in it clean it thoroughly, vacuum the area and see it it will start up.
if not read on:
If your dryer doesn't work at all, it could be because of problems with:
Power from the house
Door switch
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Wiring Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Aug 17, 2009 | Maytag Dryers
No heat no start from my maytag neptune dryer
HI, check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
2. Door switch / Door switch actuator lever
The dryer will not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
4. Timer
Replace if defective (note: uncommon problem).
**The most common issue here will be a defective Thermal fuse
Aug 01, 2009 | Maytag MED6300TQ Electric Dryer
Maytag performa dryer quit while drying lost all power light will not even come on?
Below is a checklist provided by; www.repairclinic.com. They also offer disassembly diagrams and repair parts.
Door switch
Thermal fuse
Wiring
Jul 07, 2009 | Maytag Dryers
Electric dryer won't start
HI, check the following to address this issue you are experiencing.
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Jun 02, 2009 | Maytag MDE2600 Electric Dryer
DRYER DOES NOT DO ANYTHING
Check the following to address this issue.
Jun 02, 2009 | Maytag PYE2300AY Electric Dryer
Maytag Model PYE 2300 AYW Dryer will not Start
How about the controller that turns everything on? Check for power to it? Relays(if any) working?
Aug 28, 2017 | Maytag PYE2300AY Electric Dryer
No power after door is shut
Check all fuses and circuit breakers , test with a multimeter the door switch, ensure it is working, if this parts are fine, then the problem is with the control timer. In that case you will need to replace it.
See also the following website: What is wrong with your Dryer?
You can get replacements here, also insert model number to get schematics.
Sep 21, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Electric Dryer Stopped Working
Check spring tab behind door switch-if it's bent/out of adjustment, circuit will act like door is always open.
To confirm this, open door, set dryer to active setting, and hold in door switch; if it comes on, then it's either the spring tab, or the switch is malfunctioning
Mar 30, 2008 | Dryers
Dryers Logo
93 people viewed this question
Top Dryers Experts
